The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Display Modes
Old 12-13-2004, 07:05 PM   #1
knubile's CarPC Specs
knubile's Avatar
My Photos: (0)
CF card procedures?
I've been digging through the posts and am having a hard time finding a definitive solution for setting up a CF card.
I have a Lexar and there's no utility to set it as a fixed disk. From what I understand using bootprep and FAT32 gets you around this. Is that right?
These are the instructions from SFiorito. Are these still relevant? Or is this old experience?
Quote:
1) Get a DOS bootdisk and put bootprep from XPe on it.
2) I set up my system with the CF card by itself on the primary controller and my DVD and HDD on the secondary controller. Since my slim DVD can only be master, my HDD was slave.
3) Boot up to DOS and run fdisk, then format c:, and finally run bootprep /dc (/dc denotes the c drive, /dd d drive, and so on).
4) Copy the files from your HDD to your CF. I used knoppix to do a copy. Don't just use the DOS copy command because it'll ignore hidden files. Using knoppix it was pretty quick. Originally I tried partimage on knoppix until I realized it wasn't worth the extra steps.
5)Shutdown and remove your HDD. Reboot and it should boot into XP from your CF card. The first time you boot it MAY not load EWF properly. I think this happened for me because I had my HDD still plugged in, but I just shutdown, removed it, rebooted, and EWF was back fine.
knubile is offline   Reply With Quote
Sponsored Links
Old 12-13-2004, 07:08 PM   #2
SFiorito's Avatar
Vehicle: 2006 Impreza WRX Limited
My Photos: (0)
Yeah, you just need to run fdisk, then format, then bootprep, then copy files over. Try just booting to DOS first to make sure it works. Just run fdisk, then format c: /s, then reboot. If it doesn't boot into DOS then you've got problems.
SFiorito is offline   Reply With Quote
Old 12-13-2004, 07:28 PM   #3
knubile's Avatar
My Photos: (0)
I have it set up on as a secondary master with my laptop drive(with OS) as primary master.
Think all this will work if I do by booting from the laptop drive?
Old 12-13-2004, 07:37 PM   #4
SFiorito's Avatar
My Photos: (0)
Can you boot to DOS? If you can boot to DOS then you're fine. Just make sure your do fdisk, format, bootprep in that order when you're ready to set up XP. You need to remove your HDD before you boot XP from the CF card so you might as well set the CF card as primary master and the HDD as secondary slave.
Old 12-13-2004, 10:15 PM   #5
knubile's Avatar
My Photos: (0)
I put the CF card as primary and the HDD as secondary.
fdisk format bootprep... all good.
Used ghost partition to partition to copy the EWF enabled image from the HDD to the CF card.
When I try to boot, no dice. It just hangs.
I reboot and try safe mode. I can get to that prompt with F8(how far into the XP load process is that?).
I can see it loading drivers and it hangs part way through, not always the same driver. I'm so close. Not sure what it is.
Any thoughts?
Old 12-13-2004, 10:18 PM   #6
knubile's Avatar
My Photos: (0)
BTW. The file system I'm using is FAT32.
I wonder if this my problem is caused because I don't have a util to make the CF card appear as a fixed disk.
Old 12-13-2004, 10:23 PM   #7
SFiorito's Avatar
My Photos: (0)
Can you try just copying the files over rather than ghosting? I tried partimage one time (from the Knoppix CD) and it screwed up the boot sector. Well, at least you're getting to NTLDR so that's a good sign. I wonder if maybe it's the same IDE cable issue I was having? Are you using a 40 conductor cable or 80 conductor cable (80 is for ata66+ drives). I was told that IDE-CF adaptors need the 40 conductor cable. Also, try messing with your DMA settings in the BIOS. Do you know if your card supports DMA or not?
*EDIT*: You should still be able to boot with a removable drive.
Old 12-13-2004, 10:28 PM   #8
knubile's Avatar
My Photos: (0)
definitely a 40 conductor cable. I'll check out DMA settings and try a straight copy. What should I copy with? xcopy?
Old 12-13-2004, 10:32 PM   #9
SFiorito's Avatar
My Photos: (0)
yeah, xcopy with support for hidden files. If not just use a knoppix cd to copy or just unplug the two drives and put them in another windows pc.
Old 12-14-2004, 07:21 AM   #10
knubile's Avatar
My Photos: (0)
No dice. I tried xcopy with hidden files. Similar errors. Then one of the tries resulted in an error saying windows could not be loaded because windows\config\system is corrupt. My windows\config\system folder is empty. Not sure what's going on.
When I boot into the HD the CF card appears as removable media. I really get the feeling it's because of this.
Or maybe the CF - IDE adapter. It seems to hang the system sometimes. Acronis TrueImage(kinda like ghost) seems to die when it tries to analyze the CF card. I couldn't restore the HD image made by it. I had to use ghost and drive image to try.
Good thing I have another CF adapter on the way.
If that doesn't do it, I don't know what will.
Sponsored Links
Old 12-14-2004, 08:04 AM   #11
SFiorito's Avatar
My Photos: (0)
Which adapter did you use? I've successfully used both the acscontrol adapter and the one from L0gic Supply.
Old 12-14-2004, 08:32 AM   #12
SlashEMc2k's Avatar
Vehicle: 04 Roadster Coupe
My Photos: (0)
I doubt it could be because of this but.. ..
SFiorito is using the SanDisk CF Card which is a bit slower and Knubile is using the Lexar 80x CFC.
Is there a speed limit on the IDE adapter for reading / writing to the CF`s?
I`ve ordered my Lexar CFC, so will try that see if I get the same problem as you guys when it comes.
Also are there any IDE differences between a laptop and desktop system?
I havent purchases the IDE adapter but will probably go ahead and get the acscontrol.
SlashEMc2k is offline   Reply With Quote
Old 12-14-2004, 08:46 AM   #13
SFiorito's Avatar
My Photos: (0)
Actually, the SanDisk is faster: http://www.robgalbraith.com/bins/mul...?cid=6007-6133 I'm thinking it's either a DMA issue or the files are getting corrupted somehow on transfer.
*Knubile*: Sorry I ask again, but you're sure you're using the right IDE cable? Because that's the same type of behaviour I was seeing when I was having problems. You said you were able to boot to DOS at least, right? Another thing you could do is check and make sure all your files actually did make it over. Is the used space the same on the CF as the HDD?
Old 12-14-2004, 08:55 AM   #14
SlashEMc2k's Avatar
My Photos: (0)
Sorry yeah, your totally correct, I was looking at different review pages
Old 12-14-2004, 06:05 PM   #15
knubile's Avatar
My Photos: (0)
Yes, it boots into dos. It even boots the first part of windows XP. I can select safe mode if I want. I dies at some point during the load process.
I'm going to try the whole procedure for the CF card again from scratch right now.
Sponsored Links
vB code is On
Trackbacks are Off
copyibf to cf card arise360 WinNT Based 7 12-12-2004 11:58 PM
Hibernate file on CF card? TrickerZ General Hardware Discussion 17 11-20-2004 04:09 PM
for those that use CF card.. 5GB card in Rio Carbon Don 944 LA General Hardware Discussion 4 09-28-2004 07:54 AM
CF Card for Windows XP OS boot??? englsh General Hardware Discussion 18 07-26-2004 01:03 AM
Autorun CF card on insert??? Ill1 General MP3Car Discussion 4 07-09-2004 09:19 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
