08-29-2008, 07:13 PM
#286
Quote: Originally Posted by blbrchnk
OK so I got the OS copied over to the new CF card, but it seems rather slow and freezes when I try to hibernate/shutdown/restart. Programs do work in windows, and I have disconnected all the peripherals I could to make sure it wasn't a conflict with those. Any ideas?
The sandisk you got, is the fastest one. What CF adaptor are you using, could be it doesnt support the fast speeds?
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
08-29-2008, 07:43 PM
#287
The IV is the fastest, and there have been plenty of people that have used the III without problems. I have tried two CF adapters, one is generic from ebay and the other is from logic supply.
09-01-2008, 10:21 PM
#288
High Voltage
I picked up a new intel D945GCLF motherboard myself along with a 4gb extreme III and I have a few adaptors laying about so I will let you know if I have an issue with the mobo also.
09-02-2008, 06:28 AM
#289
Good Deal. Thanks.
09-08-2008, 09:00 PM
#290
2 cards 1 install (full)
Want to get two 4 or 8 gb CF cards. 8gbs prob. My question is this. Has anyone put a full install of XP on a CF. I want to put FULL installs on both cards. The cards I am looking at are Transends and have a lifetime warr. I figure I'll get two (one fails RMA as I use the other). I will only have OS, GPS, and RR. Music and other stuff on a USB (removable) drive. Don't care about speed (too much) but, I am trying to get my rig size down as well as a little more resistant to cold and heat.
AND YES I DID
09-09-2008, 07:32 AM
#291
keep in mind that Navigation software requires gigs of data to hold the maps and POI DB. I would recommend to test your full install on a HDD or in a VM first to see how much room you actually need.
EWF, HORM, MinLogon on XP.
CarPC:
Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
Win Embedded Std 2011 RC
OCZ Vertex Turbo 30GB SSD
Lilliput 629 Transflective, WRX Screen Mount
BlueSoleil BT, BU-353 GPS, DirectedHD Radio, Andrea Mic
VoomPC 2
09-09-2008, 11:09 AM
#292
On like a chicken bone.
Thanks SFiorito for the reply. Although I haven't checked my current HD the specs on my assortment of boxes (Garmin 1.5 gb,XP home 1.5 gb and various other progs >1 gb) leads me to think 8 gbs will be fine. I will double check though. Thanks again.
10-25-2008, 06:49 PM
#293
Quote: Originally Posted by Raimis01
Hy,
I am a new one in here!
I have read a lot about OS tweak, last weeks, and I tried to make embed XP with HORM function, everything was ok, until the finish line.
Problem:
When resuming from hibernating Windows says: The last attempt to restart the system from its previous location failed... And I have 2 possibilities to choose:
Delete restoration data...
Continue...
How can I disable this dialogue?If I choose Continue, everything goes ok!
I tried to search about something similar, but I didn't find anything!
And, yes, I have deleted bootstat.dat
please help!
and thank's for this great forum for inspiration!
Did anyone find a solution for this? I am experiencing the same issue.
10-29-2008, 11:33 PM
#294
High Voltage
Well I finally completed the JK pc, everyhting is running perfect including EWF from the hard drive.
The problem I am having now is with the SanDisk Extreme III 4gb cards, I bought 2 and both are doing the same thing. When setting the cards up under DOS to make them bootable, I am getting some weird errors. When I try to format with the /s switch to test them, DOS complains about not enough memory then ends with "divide overflow" The drive actually does format but it is not boot able and DOS is not installed to it. I have tried now on 2 different PC's and a couple different versions of DOS, same thing on both cards. Both machines I tried have 1 gig of RAM. What I am thinking is that maybe I need a machine with at least 4gb of RAM in order to format and bootprep the 4gb flash card. I have a small 32mb older sandisk that I just tested and it works perfectly. So does anyone using a 4gb+ CF actually have a system up? If so any tips?
10-30-2008, 06:10 AM
#295
Nope, I had issues with my 8GB Extreme III as well.
10-30-2008, 12:37 PM
#296
High Voltage
The same types of errors?
I think I am going to try installing XP from CD to the CF, then if it works add EWF and go on from there.
10-30-2008, 01:04 PM
#297
I don't think I got those kinds of errors, just for some reason I had a hard time getting the CF card to transfer any faster than 2MB/sec from any of the three cf-ide adapters I was using at the time. Two of them I bought from the recommended stores on this forum. If I hooked the card up via USB they transferred just fine. Never did figure it out and just used a HDD and I haven't had any problems so far.
10-30-2008, 01:57 PM
#298
High Voltage
Interesting. I have no problems with I/O throughput through my CF >IDE adapters, I bought 6 or so different styles from Taiwan. Problem seems to be with the Extreme III cards being boot able. Ill report back in a bit i'm setting up something a little different to install win.
**EDIT**
IT WORKS!  Patience is virtue.
I have the 4GB extreme III up and running XPE minlogon and EWF using NTFS, My install method is very different from the posted instructions but it worked like a charm. I will post some instructions shortly. I also took a video, 20 second cold boots from hitting the on button to explorer GUI.
...may try running tiny vista with EWF on flash
Reason: SUCCESS!
12-07-2008, 09:20 PM
#299
High Voltage
OK what I did was install TinyXP ISO directly on the CF card from a SATA CD rom drive. This is the only possible way I could get XP on my 4gb (or higher) CF card. Having the CF plugged into the IDE port with a female adapter (no cable)
Before I installed I formatted the card with NTFS using a different windows machine. When the installer asks you will not need to format, just install directly to the card. After installed disable paging file, add the drivers and software, add EWF, minlogon and the system is good to go. I suppose you could make a slipstream XP ISO, and install it the same way. Anyway the system has been in use for a couple weeks now and it is stable and FAST as heck!
Specs:
INTEL D945GCLF Mini-ITX MoBo ATOM processor
1Gb RAM
266x speed 4Gb PNY Optima PRO UDMA Compact Flash on the master IDE
M2 ATX
Cold boot to desktop 20 seconds, clean shutdown 3 SECONDS!!!
Also for the record, I am using a 4gb PNY module now, a bit faster than the Extreme III Sandisk. XP also see this setup as a true hard disk for those wanting to use some features that need this option. All the SanDIsk I have used worked well but XP always see's it as a removable disk. Not so with the PNY, as far as XP knows its a true hard disk.
12-23-2008, 12:23 PM
#300
CF adaptor
blk02si, which CF to IDE adapter are you using?
VIA VB7001G mobo with C7-D 1.5GHz CPU, 1 Gig DDR2 533Mhz RAM,
| Thread Tools |
| Display Modes |
Linear Mode
