Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 12-23-2008, 04:54 PM   #301
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
I am using a fairly generic Asian adapter found on ebay. I've tested this model over and over on different boards and different CF cards and it always gives good results. I usually buy like 3 or 5 at a time because they are so cheap shipped from overseas. Here is a link to a similar auction:
http://cgi.ebay.com/Lot-5pcs-Compact...QQcmdZViewItem
blk02si is offline   Reply With Quote
Old 01-01-2009, 05:58 PM   #302
jwy2k2 is an unknown quantity at this point
I have a dual CF IDE adapter that is working well using a fast UDMA card with EWF and HORM. I would like to use the other slot for another slower card but if I do this it slows down everything to the speed of the slower card. Does anyone know if there is any way to avoid this? I'd like to get an even larger capacity card that is not as fast (cheaper) but I don't want to lose the speed of the fast card.
-winxp on an old laptop
-UDMA card: PNY Optima (fixed)
-slower card: Sandisk extreme2 (fixed/removable using atcfwchg)
jwy2k2 is offline   Reply With Quote
Old 01-10-2009, 06:31 PM   #303
whitworker is an unknown quantity at this point
ewf installer
Hello,
I had trouble installing the ewf. I have put together an installer to make this easier for others. It's been tested on an EEE PC 2g fat32.
All you do is click on ewf.exe, it will ask you what you want.
defaults are enable, disable, remove and press enter.
pressing enter will install ewf.
After the install you can type "ewf enable", or "ewf disable" in cmd to install software, etc.
If you get that annoying windows restore menu at bootup, go to System Properties>Advanced>Startup and Recovery>Uncheck Time to display recovery options.
Obviously you need to disable & restart, then you can remove ewf.
The remove function only works properly from ewf.exe, and not from ewf.bat
Enjoy.
whitworker is offline   Reply With Quote
Old 01-16-2009, 12:12 AM   #304
Zysen is an unknown quantity at this point
Is anyone else running a USB drive as a writeable partition? Im running the following hardware:
-4GB CF on a CF to IDE adapter with EWF
-80Gig IDE HDD (just holds all the installation files for setup, wont be in final build)
-16GB USB Flash
-VIA EPIA-M 1GHZ Nehemiah
-512 MB RAM
The CF runs Xpe on EWF
The IDE HDD has XP sp2 on it with Target Designer
My problem is that if any USB flash drive is present XPe will not hibernate. But it will hibernate when the 80gb IDE HDD is present. So the problem isnt that there is an unprotected drive present, but that there is a USB drive present.
Any ideas?
Edit: Problem Solved
If any of the USB booting components exist in your design (in Target Designer) then you will not be able to hibernate with a USB Key present.
Zysen is offline   Reply With Quote
Old 03-04-2009, 06:05 PM   #305
CraziFuzzy is an unknown quantity at this point
Don't know what I'm doing wrong. First time (well, second) trying to get EWF working, and both times it trashed my registry, causing instant reboot after recovery options screen. Thinking I might have corrupted copies of the ewf files. Anyone else ever see this situation? Guess I'll be doing a fresh install, while I search for the latest ewf files. Anyone got a download link for them? Thanks.
2000 Ford Expedition Eddie Bauer - Bi-Fuel Gasoline/CNG
Intel D945GCLF2 w/512MB RAM, CL Audigy w/KxProject, M2-ATX, Lilliput EBY701
CraziFuzzy is offline   Reply With Quote
Old 07-12-2009, 01:44 PM   #306
freeflashstuff's Avatar
freeflashstuff will become famous soon enoughfreeflashstuff will become famous soon enough
How do I get HORM to work? Do I need to disable EWF, create the resmany.dat and hibernate then restart EWF?
Geek, Hacker, and EcoModder!
Project Turtle
[☺☺☺☺☺☺☺☺☺☺] Install 50%
Finalizing Fan Bay
Re-hiding wires: 75%
Dead MoBo -50%...
Please help me build my REP!
Avatar from: Gates vs. Jobs
freeflashstuff is offline   Reply With Quote
Old 10-21-2009, 04:49 PM   #307
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Freaking SFC (System File Checker)!!!!!! I cannot get SFC disabled in Windows.. I have modified a 5.1.2600.1106 version of SFC_OS.DLL and copied it over to the system32 and dllcache directories and I've changed the regsitry entry HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SFCDisable to FFFFFF9D.
Still, when I rename winlogon.exe to winlogon.old and go to copy over minlogon freaking windows already has copied back over winlogon.exe!?!?
WTF!?
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Old 10-21-2009, 06:17 PM   #308
Do you have EWF enabled? If so, turn it off.(Start-->Run-->CMD and run ewfmgr c: -commitanddisable -live) THEN do the regedit tweaks and reboot. Replace the file, turn EWF back on(Start-->Run-->CMD and run ewfmgr c: -enable) and reboot. That should do it.
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 10-21-2009, 07:27 PM   #309
Raw Wave
tbird2340's Avatar
Nope.. Fresh install of XP and I do the minlogon before I do EWF so I haven't even gotten to that yet..
Old 10-21-2009, 07:29 PM   #310
...hmm... OK, there's a freeware tool that will disable SFC for you... Let me find it and get back to you.
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 10-21-2009, 07:31 PM   #311
Raw Wave
tbird2340's Avatar
Awesome. That would be great!
Thanks!
Old 10-21-2009, 07:36 PM   #312
OK, I couldn't find the program, but I think this'll do the trick as well. I'll continue searching for the program, but until then: "How to completely disable Windows System File Protection (SFC) in Windows XP (all versions and Service Packs)"
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 10-21-2009, 07:45 PM   #313
Raw Wave
tbird2340's Avatar
Wow.. If it's really that easy I'm going to kick myself for going through all the hex editing, hours of googling, etc trying to get it disabled..
I'll try that tomorrow (took the PC to work).
Thanks again!
Old 10-21-2009, 07:55 PM   #314
This program works, it's not the one I was thinking about, because the one I was thinking about just did the registry hack for you. This one lets you replace SFC protected files.
NOTE: I have not checked this program for viruses! And if this program messes up your computer, I'm sorry!
WFP Replace
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Using minLogon to speed up booting and decrease footprint SFiorito WinNT Based 264 04-05-2009 08:09 AM
