Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 06-02-2005, 03:46 AM   #91
TimmyM's Avatar
Quote: Originally Posted by Kyalamikid
I have downloaded XP Embedded SP2, but get a prompt to enter the key. However, I didn't get one with the download. How do I get and eval key?
Its on disk 1.
TimmyM is offline   Reply With Quote
Old 06-10-2005, 11:33 PM   #92
Quote: Originally Posted by UK_MP3Car
@masch - do a search in the registry for autocheck - delete the value within the autocheck key.
I found one key
BootExecute
Type REG_MULTI_SZ
Data autocheck autochk*
Do I empty the data field?
(there are 3 of these keys actually, all looks identical)
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 06-12-2005, 04:56 PM   #93
SFiorito's Avatar
look at the document linked at the beginning of this thread... yes, you want to clear the bootexecute value
SFiorito is offline   Reply With Quote
Old 06-21-2005, 11:26 AM   #94
Quick question ---
I have followed the instructions and everything has worked very well, thanks SF
I am at the step where i am about to copy my install to the CF card, but cannot figure out a way to copy all the hidden and sys files. I have a USB CF card reader and I also have a dual boot on my Carputer, in addition I have a 1.0 GB USB pen drive that I can temporarly store the install on. What would be the easiest way for me to copy my install setup. I have heard people speaking about xcopy but I dont know what it is.
And please the more simple you can make your instructions the better I will do,
THANKS!
Also has anyone done any testing using prefetching as momanz described on page 2.
dudical266 is offline   Reply With Quote
Old 06-21-2005, 12:02 PM   #95
IntellaWorks's Avatar
You need another operating system. So this is what I typically do, install the os on the car pc with a regular IDE harddrive make sure EVERY thing is 100% working. I then take the IDE drive and connect it to my PC (to make things easier I stole a USB 3.5" hdd kit from work) I also connect the CF card to my PC with a CF reader. I then hit "select all" and copy from the IDE drive to the CF card. Before you do this step you want to make sure your CF card can boot. You can do this my taking all drives off the carpc system, but the CF card and format the disk with format c: /s, then reboot, hopefully you should get a command prompt. You also want to make sure that both drives (IDE,CF) are the same file system before copying.
I know it seems weird or not possible to be able to just select all and copy over but I assure you it works if you've followed the steps to prepare the CF card.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 06-21-2005, 12:03 PM   #96
SFiorito's Avatar
you have a couple of options:
1) If you have a dual boot set up already boot into your second installation and then just copy the files from the drive onto the CF card. This has to be done from another installation of XP though, because Windows will not let you copy files from the currently running OS.
2) Use a BartPE bootable CD with xcopy installed.
3) Use a Knoppix CD and copy the files (may cause problems with hidden files no longer being hidden after you copy over).
4) I have a USB enclosure for my 2.5GB HDD so I usually plug both the HDD and the CF card into another system and copy them that way. Not the fastest, but it's the easiest for me.
Old 06-21-2005, 01:17 PM   #97
I think i will use by dual boot's second installation and just copy all files from the HD to the CF. About them being the same format. The HD is NTFS and the CF will be FAT(I dont have the CF yet, I ordered it today) But i will prepare the CF as per SF's instructions
Edit ----
I tested it today and everything worked. Last time I forgot to disable the hiding of system files. Thanks for the help
Old 07-30-2005, 06:51 PM   #98
ok guys
i just did ewf on my xp sp2
and now i tried to apply HORM
but i cann't skip the resetting hibernation
so after one time boot from hibernation it boots normally...
i confirmed that ewf is working i disabled then make a file named 'resmany.dat'
then enabled ewf and then hibernated...
what am i missing here?
iPal is offline   Reply With Quote
Old 07-31-2005, 10:14 AM   #99
SFiorito's Avatar
you need to disable ewf, create the resmany.dat file, enable ewf, reboot so ewf starts up again, and then hibernate.
Old 07-31-2005, 03:19 PM   #100
oh... so even if ewf is enabled... can i hibernate?
i thought ewf will disable writing on the disk what so ever...
how can it create hibernation image?
hmmm... i will try it anyways and let you know...
one more question on my CF card, i couldn't boot with 'ewfntldr' renamed 'ntldr'...
so i changed back to normal 'ntldr' and still ewf works...
do i need ewfntldr to skip resetting hibernation?
so i copied 'ewfntldr' on harddrive and it boots...
if i copy whole drive into CF will it boot ok now?
i have kingstion elite pro 2gb...
i had to use fat... cuz i formated in fat32 and didn't boot up...
anyway i will try this on the harddrive...
thank you...
Old 07-31-2005, 06:52 PM   #101
i tried to hibernate after ewf enabled...
i found interesting thing...
i works but after i shut down normally...
it boots up normal...
so i think it still writes states when shutting down...
but ewf looks working nothing else changed...
what did i do wrong or miss?
Old 07-31-2005, 09:16 PM   #102
SFiorito's Avatar
you created the resmany.dat file on your C drive with ewf disabled, re-enabled ewf, and rebooted? you have the ewf version of ntldr installed? when you run ewfmgr it gives you a good status?
Old 07-31-2005, 10:51 PM   #103
yes
yes
yes
somehow i hibernate twice in a row then now it seems like doing HORM
but after couple of boots from HORM i get blank screen then no response...
Old 08-19-2005, 03:57 PM   #104
will the ewf method work on windows 2003 with minilogon?
xtra is offline   Reply With Quote
Old 08-19-2005, 04:19 PM   #105
SFiorito's Avatar
it might...haven't tried it myself though.
Using minLogon to speed up booting and decrease footprint SFiorito WinNT Based 260 07-25-2008 01:55 AM
