04-12-2008, 05:30 PM
#241
you don't need SDI disks for EWF unless you can't partition your drive (like removable CF disks). Just partition your drive (30GB and 220GB partitions) and configure EWF to protect the 30GB partition. What exactly happens after you unmount the larger partition and try to hibernate? Nothing at all, lock up, BSOD?
04-18-2008, 12:33 PM
#242
Guys, is there a way of clearing the memory used to track the changes (overlay)? I use Adobe Flash for my interface (don't ask), and it tends to create a lot of files, especially when playing videos etc, filling up memory really fast. I don't want to reboot the machine just to play another video, so I am hoping there is either a way of telling Flash to just stream the file (no buffering), or somehow wipe the EWF buffer.
05-06-2008, 10:08 AM
#243
Looking to upgrade my carpc to this.
What CF should I go with and with what size? I want to put microxp on a CF and using a CF to SATA connection as the IDE is used by the DVD burner and the second SATA will have a 2.5" 120GB HDD to store all my music, photos, etc so I can EWF my CF for fast bootup.
I don't know how many GB CF card would I need. There are some drivers (for the BT, GPS, VGA, and RR) and the GPS software will be on the external HDD. I got a few 150x 2GB around the house, but I can order Lexar 2GB or 4GB 300x UDMA CF or Kingston Ultimate 266x CF (or others in that range on buy.com)
Any reccommendations? What boot time could I expect?
05-06-2008, 11:59 AM
#244
Easiest way to figure it out how much sapce you'd need is to do a test setup on a hard drive. Set it all up exactly how you'd do it on the CF card. See how much space you need.
05-06-2008, 12:18 PM
#245
what about type of card? Should I go with a kingston 266x or a lexmark 300x UDMA?
05-28-2008, 12:43 PM
#246
Will this speed up my CarPC boot times at all if used on a 2.5" hard drive? It currently takes me 46 seconds to boot.
05-28-2008, 01:46 PM
#247
You can pretty easily try minlogon and if it doesn't work out switch back to the normal winlogon. Same with EWF. I didn't notice a big difference with them on a hard drive.
You'd probably get more out of OS optimization and registry tweaking. Or switching to hibernation.
05-28-2008, 01:51 PM
#248
For some reason I can't get my PC to work with hibernation. I'm not sure if it has something to do with TinyXP or my VIA EPIA CN-13000G motherboard. I would love to use hibernation, though, if I could get it to work. It's not on the shutdown selection menu and I couldn't when I went to enable it, the tab was not there. Any ideas?
05-28-2008, 01:55 PM
#249
I was looking at the info file for TinyXP Rev 09 this morning and the creator has a batch file that you need to run before you enable hibernation. I'm not sure when the creator started doing that though, Rev 03 didn't have that issue.
05-28-2008, 02:03 PM
#250
I run rev 05.. can't seem to find anything without downloading rev09
05-28-2008, 02:07 PM
#251
It could be your hardware, but I don't anything about your motherboard.
05-28-2008, 02:16 PM
#252
i dont see why it wouldn't work and i'm afraid to try to update my video drivers because i've read about people having problems booting after updating video drivers on this mobo
05-28-2008, 02:22 PM
#253
I'm going to PM you some OS optimization stuff that another user here sent me. He gets 20 second cold boots now.
07-28-2008, 09:05 PM
#254
I tried searching for my problem but all I could find was one other person with the same problem as me, and he had no replies to his thread, so here it goes.
I have everything configured the way I want it and was ready to copy the stuff over to the CF card. I put the CF card on the adapter as master, the cd-rom as slave and my HDD that has everything set up on it connected via usb. Everything gets picked up normally by BIOS, ntfs DOS, etc. I copied it all over with symantec ghost and when I restart (I disconnect all other drives to avoid confusion) I just get a blinking cursor. Any ideas?
07-28-2008, 10:03 PM
#255
Try to boot into DOS from a floppy or bootable cdrom. Run FDISK and set the Hard Drive partition (CF Card) where Windows is installed as ACTIVE. Sometimes when you ghost a drive it doesn't set the destination partition as Active and it won't boot.
If you have more than one partition on the CF, the one with the system files should be set to Active. Good luck.
Mustang 2000 GT Silver
LCD: 7' Xenarc TS
Slot DVD-RW
| Thread Tools |
| Display Modes |
Linear Mode
