The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Display Modes
Old 12-17-2004, 07:33 AM   #1
SFiorito's Avatar
Vehicle: 2006 Impreza WRX Limited
My Photos: (0)
New EWF + MinLogon and CF instructions
Okay, I tried to make it as simple as possible in the time I had. I'm pretty sure I covered everything in this doc.
http://granturing.blogspot.com/
**EDIT** New Link
SFiorito is offline   Reply With Quote
Sponsored Links
Old 12-17-2004, 07:39 AM   #2
Registered User
mpattonm's Avatar
Vehicle: Renault Laguna II
My Photos: (0)
Is this link working for somebody?
mpattonm is offline   Reply With Quote
Old 12-17-2004, 07:41 AM   #3
My Photos: (0)
it works put you have to be a member of msnuser
smenard is offline   Reply With Quote
Old 12-17-2004, 07:48 AM   #4
SFiorito's Avatar
My Photos: (0)
sorry guys I thought it would've let anyone in. Usually does with pictures at least...Put a new link up there.
Old 12-17-2004, 10:35 AM   #5
SlashEMc2k's Avatar
Vehicle: 04 Roadster Coupe
My Photos: (0)
quick question
With Windows XPE Web Install do you download all the products?
Or just the Windows XP Embedded SP2 257mb?
SlashEMc2k is offline   Reply With Quote
Old 12-17-2004, 10:46 AM   #6
SFiorito's Avatar
My Photos: (0)
You need the tools (for bootprep) and data files for the Repositories so unfortunately thay may mean all the products.
Old 12-18-2004, 11:08 AM   #7
SlashEMc2k's Avatar
My Photos: (0)
Tip..
XP SP2 Disabling System File Protection:
To replace the winlogon.exe upload minlogon.exe to C:\WINDOWS\system32\dllcache,
rename and minlogon.exe to winlogon.exe.
Rename C:\WINDOWS\system32\winlogon.exe to winlogon.exe.bak
Copy the new 15-17kb Winlogon.exe from dllcache to system32 directory.
if windows file protection pops up hit cancel.
The old Winlogon file will not overwrite your new winlogon and you will still have windows file protection enabled
Old 12-18-2004, 11:25 AM   #8
SFiorito's Avatar
My Photos: (0)
Actually, I think I know now why it never overwrote my file... I ran "sfc /purgecache" and "sfc /cachesize=0" after I did an nLite install. Of course, with the new nLite you can completely disable SFC.
Old 12-18-2004, 11:52 AM   #9
SlashEMc2k's Avatar
My Photos: (0)
ok up to 9. Reboot system.
When I reboot it just restarts gets to the windows xp loading animation and restarts from boot.
I can get to XP if I load up last good known configuration.
I have checked the registry and it matches the ewf.reg file.
All I can think is the ArcName might be different on my system.
Would this be causing it to reboot and not load into XP?
Old 12-18-2004, 11:59 AM   #10
SFiorito's Avatar
My Photos: (0)
Could be. The Arcpatch needs to match the drive you want protected.
multi(0)disk(0)rdisk(0)partition(1) == Primary IDE channel, master, 1st partition
How is your EWF drive hooked up? You made sure ewf.sys is in the right spot?
Sponsored Links
Old 12-18-2004, 12:34 PM   #11
SlashEMc2k's Avatar
My Photos: (0)
Just checked.
I have the 20 GB HD setup as the primary IDE.
ewf.sys is located in windows/system32
When I boot into last good configuration I get this error?
Net Service Configuration
The Specified service does not existas an installed service could this be because of the ewf.sys? do I have to install it someway into the system32 directory?
Old 12-18-2004, 12:42 PM   #12
SFiorito's Avatar
My Photos: (0)
ewf.sys is in System32? Reread step 4 under EWF.
Old 12-18-2004, 12:48 PM   #13
SlashEMc2k's Avatar
My Photos: (0)
woops.
My Bad..
where does the protected drive get set?
when I run ewfmgr c: from console
I get the error:
Failed getting protected volume configuration with error 1
any ideas?
I have checked the registry and this is fine and matches up with the registry in the document. ewf.sys is also now in the correct folder.
Old 12-19-2004, 10:36 AM   #14
SlashEMc2k's Avatar
My Photos: (0)
is this correct?
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Session Manager]
BootExecute=""
Old 12-19-2004, 10:44 AM   #15
SFiorito's Avatar
My Photos: (0)
yes, that registry value just prevents automatic scandisk on bootup. so you have EWF installed now? And your reg values are all correct? Did you remove all other harddrives from your system when you booted up? Is your EWF drive the c: drive?
Sponsored Links
vB code is On
Trackbacks are Off
Using minLogon to speed up booting and decrease footprint SFiorito WinNT Based 260 Today 01:55 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
