Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 01-10-2005, 07:00 PM   #1
Nobias's Avatar
Nobias
nLite making me nSane: Frodoplayer issue
I have all my devices working now but i keep getting a Frodoplayer database connection error. I've disabled/enabled everything I thought might matter but i just cant get the combo right. I left MDAC, framework, and speech support. What am i missing to get frodo support?
Here's my settings.ini from nLite:
Code:
[Main] Env = 0.99.6 beta.1.1.4322.2032.Microsoft Windows NT 5.1.2600.0..en-US Target = Windows XP Professional SP2 - build 2180 [Pages] Integrate a Service Pack Remove Components Unattended Setup Integrate Hotfixes Options and Tweaks Create a Bootable ISO [Components] ;# Applications # Accessibility Options Briefcase Calculator Charmap Games Internet Games NT Backup Pinball Screensavers Wordpad ;# Drivers # Battery Cameras and Camcorders Display Adapters Ethernet (LAN) Firewire (1394) IBM Thinkpad InfraRed ISDN Modems MultiFunctional Multi-port serial adapters Portable Audio Scanners SCSI/RAID Smartcards Sound Controllers Toshiba DVD decoder card TV Tuner Wireless Ethernet (WLAN) ;# Internet Utilities # Client for Netware Networks Communication tools FrontPage Extensions Internet Connection Wizard Internet Explorer Internet Explorer Core Internet Information Services (IIS) MSN Explorer Netmeeting Network Monitor Driver and Tools NWLink IPX/SPX/NetBIOS Protocol Outlook Express Server Printing Support Synchronization Manager Tcp/Ip Version 6 Vector Graphics Rendering (VML) Web Folders Windows Messenger ;# Multimedia # Images and Backgrounds Luna Theme Mouse Cursors Movie Maker Music Samples Old CDPlayer and Sound Recorder Paint Windows Sounds ;# Operating System Options # Administrator VB scripts Desktop Cleanup Wizard Disk Cleanup DR Watson File and Settings Wizard Floppy Support Help Manual Install and Upgrade MS Agent Out of Box Experience (OOBE) Printer Support Search Assistant Shell Media Handler Task Scheduler Tour Web View Zip Folders ;# Services # Alerter Application Layer Gateway ClipBook CTF Loader Distributed Link Tracking Client Error Reporting Fax Services Imapi Indexing Service IPSEC Policy Agent Messenger Network DDE QoS RSVP Quality of Service (Qos) Remote Registry Removable Storage Secondary Logon Service Advertising Protocol SNMP System Restore TCP/IP NetBIOS Helper Telnet Server Uninterruptible Power Supply Universal Plug and Play Volume Shadow Copy WebClient Windows Time Wireless Zero Configuration ;# Language Support # Arabic Baltic Central Europe Chinese Simplified Chinese Traditional Cyrillic Georgian Greek Hebrew Indian Japanese Korean Thai Turkish Vietnamese Multilanguage Support (LANG dir) Input Method Editor ;# Directories # DOCS SUPPORT VALUEADD [KeepFiles] [RemoveFiles] [Options] ;# Desktop,Taskbar & Startmenu # Disable Baloon Tips Disable Group similar taskbar buttons Disable Hide incative icons Disable Start Menu delay Disable Status Messages Don't use Personalized Menus Enable Administrative tools in Start Menu Expand ControlPanel Expand Network Connections ;# Experimental # Disable Logging & Reboot on System Failure Disable Page File Disable paging of kernel and core-os Disable Prefetch-Cache Disable saving Last Good state at boot Remove Windows-Keys Support Set Internet Explorer to accept 10 connects a time ;# Explorer # Add CMD SHELL:> to all Drives and Folders Advanced Search: preconfigure options Change Explorer Folder View to: details Disable Autorun Remove Shared Documents Set sound scheme to No Sounds Show All Files And Folders Show Statusbar in all windows ;# Security & Privacy # Classic Logon Disable LM HOSTS lookup Disable Shutdown Tracker Disable User Process Tracking Remove Alexa Spyware ;# Speed # Classic Control Panel Disable Automatically search for network folders and Printers Disable Display file size information in folder tips Disable Optimize harddisk when idle Disable Tracking of Broken Shortcut Links Disable Warn on low disk space Do not cache thumbnails Faster Shutdown Use Windows classic folders / No Tasks Sidepanel ;# Visual Effects # Disable: Animate windows when minimizing and maximizing Disable: Fade or slide menus into view Disable: Fade or slide ToolTips into view Disable: Fade out menu items after clicking Disable: Show shadows under menus Disable: Show shadows under mouse pointer Disable: Show translucent selection rectangle Disable: Show windows contents while dragging Disable: Slide open combo boxes Disable: Slide taskbar buttons Disable: Smooth edged of screen fonts Disable: Smooth-scroll list boxes Disable: Use a bachground image for each folder type Disable: Use common tasks in folders Disable: Use drop shadows for icon labels on the desktop Disable: Use visual styles on windows and buttons ProfilesDir = "%SystemDrive%\Documents and Settings" ;#ISO maker# isovol = WInLITE isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
Status: 40%
Car: 2006 Scion tC (Buying)
CPU: AOpen Pandora/1.5 Cel M/1GB DDR2/Ipod Vid
Screen: Lilliput 7"
Power: Carnetix 1900
GPS: Deluo GPS
Software: nLiteXP, RR, IG, PhoCo
XM: XM Direct
http://www.chrispuckett.com/mp3car/
Nobias is offline   Reply With Quote
Old 01-11-2005, 07:55 AM   #2
knubile's Avatar
knubile is on a distinguished road
I'm not sure if it's it or not, but I left in the COM+ stuff.
knubile is offline   Reply With Quote
Old 01-11-2005, 09:20 AM   #3
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
Well, not sure what kind of database frodoplayer uses.. did you think about ODBC or ADO. (Jet's typically used to make a connection to a database)
registerring the Microsoft DAO 3.6 .dll
which is a COm+ object.. so leave that stuff in if you want to make a new nLite XP
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 01-13-2005, 01:09 AM   #4
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
I use a JET database though ADO.
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
FrodoPlayer 109t3 issue with Flash.ocx Oracle FrodoPlayer 3 01-03-2005 01:10 AM
nlite requirements for FrodoPlayer knubile FrodoPlayer 2 12-02-2004 08:22 AM
cant change skins??? Hell-Stopper FrodoPlayer 19 11-05-2004 11:10 PM
Bug Reports 1.09 frodobaggins FrodoPlayer 279 10-22-2004 11:24 PM
Bug Reports frodobaggins FrodoPlayer 168 10-16-2004 01:25 AM
