Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 02-11-2005, 07:11 AM   #1
t00h0t is on a distinguished road
CF fixed disk utility
Does anyone have the utility that tells a CF card that its a fixed disk drive? I believe its called atcfwchg.com
I've cant seem to run bootprep on my 1GB cf card. It keeps saying the drive is protected. I can fdisk and format it though. Anyone have this file? Thanks
t00h0t is offline   Reply With Quote
Old 02-11-2005, 08:45 AM   #2
SFiorito's Avatar
SFiorito is on a distinguished road
what card do you have? I've run bootprep on removable drives before and I never got such an error. are you using a 40 conductor cable with your ide adapter?
SFiorito is offline   Reply With Quote
Old 02-11-2005, 09:06 AM   #3
I have a SanDisk Ultra II 1GB, using the CF slot built into my mobo, its using the slave position on the secondary IDE channel. Its a permission error of some kind. I can see the CF as if it were a fixed disk in DOS, but in windows is still shows as a removable drive. Is this correct?
Old 02-11-2005, 09:13 AM   #4
SFiorito's Avatar
yeah, it's just Windows that has the issue with fixed vs removable. what letter does your drive get assigned? whichever that is, that's what you need to use, i.e. "bootprep /dn" n being your drive letter. your mobo's cf slot doesn't have some kind of write protection does it? you sure the cf slot is on the IDE bus, right?
Old 02-11-2005, 10:38 AM   #5
I'm running bootprep correctly, its assigning C to the drive. I wouldnt think its write protected if I can fdisk and format it. The CF slot is on the secondary IDE channel, I've tried master and slave. Do you have that utility?
Old 02-11-2005, 05:21 PM   #6
IntellaWorks's Avatar
IntellaWorks is on a distinguished road
What system board to you have ? If MII10000 then I don't think BIOS will see the drive as an IDE device.. therefore poot prep wont work..
edit: If my hardware has arrived I'm doing this tonight... I hope it goes smoothly !
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 02-11-2005, 05:26 PM   #7
My board supports booting from the CF slot. I just need the utility.
Old 03-06-2007, 10:07 AM   #8
sammydafish is on a distinguished road
I'm in need of this too, I'm using the slot built into my MB, I can boot to it, but need to mark it as fixed. could someone send it to me please
sammydafish is offline   Reply With Quote
Old 03-10-2007, 05:29 PM   #9
Scuga is on a distinguished road
Didn't notice this thread.....
I'm would like a copy of the utility too.
michaelergud at gmail.com
/Michael
Scuga is offline   Reply With Quote
Old 03-20-2007, 01:41 AM   #10
gregwoods2k is an unknown quantity at this point
I could use a copy of this too if it's still going around.
gregwoods2k at gmail.com
many thanks
//gman
gregwoods2k is offline   Reply With Quote
Old 03-29-2007, 02:02 AM   #11
Road_Dog's Avatar
Road_Dog is an unknown quantity at this point
Bootprep is part of Microsoft's WinXP embedded. I would download from their sit the trial software and install it.
EXE: http://download.microsoft.com/downlo...edded_sp2e.exe
ISO: Download details: Windows XP Embedded SP2 Feature Pack 2007
I haven't read the EULA enough times to state that the BOOTPREP can be distributed outside of XPe or by non MS folks. However, there are other good programs wrapped up in XPe.
Road_Dog
Road_Dog is offline   Reply With Quote
Old 04-03-2007, 04:05 PM   #12
Kresson is an unknown quantity at this point
So does anyone have a link to the actual fixed disk utility?
Kresson is offline   Reply With Quote
Old 06-15-2007, 01:34 PM   #13
maloosheck is an unknown quantity at this point
Can I turn any CF card into fixed drive?
InDashPC
maloosheck is offline   Reply With Quote
Old 06-20-2007, 05:34 PM   #14
negativex is an unknown quantity at this point
Ask and Ye shall receive......
http://www.dynx.net/images/prog/ATCFWCHG.COM
negativex is offline   Reply With Quote
Old 06-27-2007, 04:01 PM   #15
sebberry is on a distinguished road
I have one of these: http://www.seagate.com/ww/v/index.js...&reqPage=Model
And it's marked "removable", yet it is detected and partitionable by FDISK.
I have tried using the ATCFWCHG util on it, but it didn't work. I was able to install Windows onto it a couple of times, now I just get a disk error on first boot even tho I can still see it fine as a drive. (Yes, I have used an IDE-CF adaptor, etc...)
I emailed Seagate and got this reply:
Quote:
Thank you for your enquiry.
Please beware, Microsoft does not support there operating system installed on an USB drive.
Seagate does not have the special partitioning utility to modifiy the partition table on your micro drive.
Should you require any further assistance please do not hesitate to contact us. In order to allow us to deal with all enquiries as efficiently and accurately as possible we would ask that you include any previous emails when replying to us.
I don't think he knows what he is talking about.
Any ideas from the MP3car crew?
Thanks.
sebberry is offline   Reply With Quote
Flash card bootable drive? The Durango Kid General Hardware Discussion 51 03-16-2005 09:20 AM
Sandisk Extreme III cannot be set to fixed disk knubile WinNT Based 5 01-06-2005 03:01 PM
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 07:48 PM
Flash OS BiohazrD General Hardware Discussion 18 12-04-2004 09:57 AM
Fixed disk 0: Fujutsi ..... Jaymz General Hardware Discussion 1 03-04-2001 02:26 PM
