search helpers: nLite settings, settings.ini, safe nlite, safe settings, optimized windows xp
This will give you Wireless Internet, Mp3 audio playback, DVD playback, Internet Browsing (after you install a browser of your choice: explorer, *Mozilla) You must install Framework 1.1 if you want to run .net apps..
After you install this OS, Remove pagefile.sys to reduce the footprint to about 350MB. Then install your applications test and retest everything. Then when your satisfied install Minlogon and EWF. From here you can point your OS to a new shell, by regedit->find->winlogon, from here change the "shell" key to point to your new shell.
edit:
Winamp users be sure to include "midi" support
Ok, for those of you new to nLite, here is a little more in depth of an explanation of whats going on here. Basically, you grab windows (copy and paste the entire CD on to your harddrive) then open nLite and point it to the newly copied windows xp. From here you have a choice to "slip stream" a service pack. You must have already downloaded the approriate service pack to your machine. (There's no need to uncompress it) just make sure you point nLite to the .exe you downloaded.
After nLite has done its thing you will get a list of things to unCheck, don't be fooled because unchecking things means those things stay and everything checked goes. Behind the scenes this creates a file in the nLite folder a settings.ini file. Basically all it does is tell the nLite application what you have removed from the windows configuration. You can view this and either copy and paste my settings.ini or write down the things I have removed.
Here is something I have found that might help you guys out. Once you have finished a configuration and burned it to a cd and found out there was something missing or something isnt working properly. When you open nLite back up to make a "NEW" configuration you cannot use what it remembers, you must start the WHOLE process over again. Meaning copy all the files and folders from the windows cd again, and also re-slipstream the service pack. And then choose what you want to remove again.
Once you have finished your nLite configuration it creates an .ISO file. For those of you who are not sure how to get this to a CD check this program out.
http://isorecorder.alexfeinman.com/isorecorder.htm
This application basically works just like windows xp cd-burning does. You right click on the .ISO that nLite created and click "Copy image to CD" after this application is installed and it will do the rest. It makes the CD bootable and everything. Keep in mind that its a beta app and it will have its days where its kind of buggy but for the most part I haven't run into any major troubles with it, it has been reliable (I've used it to make about 30 bootable ISO's).
Code:
[Main]
Env = 0.99.7 beta.1.1.4322.2032.Microsoft Windows NT 5.1.2600.0..en-US
Target = Windows XP Professional SP2 - build 2180
[Pages]
Integrate a Service Pack
Remove Components
Unattended Setup
Options and Tweaks
Create a Bootable ISO
[Components]
;# Applications #
Accessibility Options
Briefcase
Calculator
Charmap
ClipBook Viewer
Games
Internet Games
NT Backup
Pinball
Screensavers
Wordpad
;# Drivers #
Battery
Bluetooth Support
Cameras and Camcorders
Display Adapters
Display Adapters (old)
Ethernet (LAN)
Firewire (1394)
IBM Thinkpad
InfraRed
ISDN
Modems
MultiFunctional
Multi-port serial adapters
Portable Audio
Printers
Scanners
SCSI/RAID
Sound Controllers
Toshiba DVD decoder card
Windows Image Acquisition (WIA)
;# Internet Utilities #
Client for Netware Networks
Communication tools
FrontPage Extensions
Internet Connection Wizard
Internet Explorer
Internet Information Services (IIS)
MSN Explorer
Netmeeting
NetShell Cmd-Tool
Network Monitor Driver and Tools
NWLink IPX/SPX/NetBIOS Protocol
Outlook Express
Peer-to-Peer
Synchronization Manager
Vector Graphics Rendering (VML)
Web Folders
Windows Messenger
;# Multimedia #
Images and Backgrounds
Luna Theme
Media Center
MIDI audio support
Mouse Cursors
Movie Maker
Music Samples
Old CDPlayer and Sound Recorder
Paint
Tablet PC
Windows Media Player
Windows Sounds
;# Operating System Options #
Administrator VB scripts
Desktop Cleanup Wizard
Disk Cleanup
DR Watson
File and Settings Wizard
Floppy Support
Help
Manual Install and Upgrade
MS Agent
Printer Support
Search Assistant
Security Center
Shell Media Handler
Task Scheduler
Tour
Web View
;# Services #
Alerter
Application Layer Gateway
Autoupdate
CTF Loader
Distributed Link Tracking Client
DNS Client
Error Reporting
Fax Services
Imapi
Indexing Service
IPSEC Policy Agent
Messenger
Network DDE
QoS RSVP
Quality of Service (Qos)
Remote Registry
Removable Storage
Secondary Logon
Service Advertising Protocol
SNMP
System Restore
TCP/IP NetBIOS Helper
Telnet Server
Terminal Services
Uninterruptible Power Supply
Universal Plug and Play
Volume Shadow Copy
WebClient
Windows Firewall/Internet Connection Sharing (ICS)
Windows Time
;# Language Support #
Arabic
Baltic
Central Europe
Chinese Simplified
Chinese Traditional
Cyrillic
Georgian
Greek
Hebrew
Indian
Japanese
Korean
Thai
Turkish
Vietnamese
Multilanguage Support (LANG dir)
Service Pack Messages
Input Method Editor
;# Directories #
DOCS
SUPPORT
VALUEADD
[KeepFiles]
[RemoveFiles]
[Options]
;# Desktop,Taskbar & Startmenu #
;# Experimental #
;# Explorer #
;# Security & Privacy #
;# Speed #
Disable Automatically search for network folders and Printers
;# Visual Effects #
ProfilesDir = "%SystemDrive%\Documents and Settings"
;#ISO maker#
isovol = WInLITE
isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
