Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 08-03-2005, 05:18 PM   #1
bLindmOnkey's Avatar
bLindmOnkey is on a distinguished road
Using Windows Server 2003 for CarPC
Was wondering if anyone's ever thought of this or acually done it. Afterall, it runs great on slower systems, is more stable than xp due to a newer kernal, and there are complete guides to make Server2003 run just like an XP workstation such as this one:
http://www.msfn.org/win2k3/
bLindmOnkey is offline   Reply With Quote
Old 08-05-2005, 12:40 PM   #2
strohj's Avatar
strohj is on a distinguished road
it loads more stuff during bootup though... therefore you have longer boot times.. which is something we are trying to eliminate...
however.. if you do use hibernate/standby it can be a viable option... although in my experience.. its not XP that causes a pc to crash.. its more often than not the software you run on it...
strohj is offline   Reply With Quote
Old 08-05-2005, 12:46 PM   #3
techeros's Avatar
techeros is on a distinguished road
Interesting... but my first reaction was WHY?
We run 14 2k3 servers here all are pretty stable untill either a patch for M$ is applied or we do something to hork it up. I know a ton of services can load on 2k3, and it looks like it can be scaled down it that article.
Is xp home/pro THAT unstable to have to install server 2k3?
03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
Carputer Planning |---------*|
Overall Implementation |---------*-|
(Stereo complete)
Computer installed and working
techeros is offline   Reply With Quote
Old 08-05-2005, 01:40 PM   #4
LittleDragon is on a distinguished road
I use 2003, it's fast on bootup. The main reason is I don't want to use a keyboard and if XP chokes in restoring the hibernation file, you get prompted to continue booting or delete the hibernation file. 2003 doesn't do that, if it chokes, it'll just try restoring the file be default, no need for a keyboard.
LittleDragon is offline   Reply With Quote
Old 08-05-2005, 10:25 PM   #5
mattress is on a distinguished road
Windows 2003 is a very sleek and sexy operating system! I used to run it as a desktop OS after following a guide like the one mentioned to make it more like a workstation OS.
I'd still be running it today, if it weren't for games like Doom3 that *REQUIRE* windows XP, and won't run otherwise (unless you get a patch..)
I wonder if we could get a project like nlite started for Win2k3 ... but probably not likely, since Windows Vista is right around the corner..
mattress is offline   Reply With Quote
Old 08-06-2005, 03:06 AM   #6
bigman1 is on a distinguished road
nlite already works for win2k3
bigman1 is offline   Reply With Quote
Old 08-06-2005, 08:21 AM   #7
Clint is on a distinguished road
Actually you can grab Application Toolkit @ MS for free and then emulate XP when installing....it's a matter of minutes and you will be able to install pretty much anything on a 2003 box
The stayaway's are AV's ofcourse...but apart from that...no prob.
Clint is offline   Reply With Quote
Old 08-09-2005, 02:05 PM   #8
if by around the corner you mean a year or two, then yeah maybe vista is around the corner, but vista still runs like crap on today's systems (which by the time vista comes out will be)
Old 08-13-2005, 03:05 PM   #9
Don 944 LA's Avatar
Don 944 LA is on a distinguished road
I have a dual boot on the car system
Win 2003 Server
Win XP Pro w/ Mac U/I ( default 3 sec delay )
Don 944 LA is offline   Reply With Quote
Old 09-17-2005, 06:38 AM   #10
xxxomxxx is on a distinguished road
other Apps needed
hi all
if i use Media Portal as shell, i just dont know how to get the other prgrams running....
im using the following as a frontend:
C:\Program Files\Team MediaPortal\MediaPortal\MediaPortal.exe
But i need following Startup entries to start
C:\Program Files\SOUNDGRAPH\iMON\iMON.exe /startup (<-dont know if i need the startup command)
C:\Program Files\Motherboard Monitor 5\MBM5.exe
C:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
help would be greatly apreciated...
xxxomxxx is offline   Reply With Quote
Old 09-17-2005, 10:02 AM   #11
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
Quote: Originally Posted by xxxomxxx
hi all
First, this has nothing to do with this thread.
Second, this has been brought up already. Go check out the FAQ Emporium. I believe the answer you seek is there.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 09-17-2005, 11:28 AM   #12
camsgs3 is on a distinguished road
interesting, but wouldnt you still have to hit f8 to bring up the prompt thats gives you the option to continue booting or delete the hib. file
camsgs3 is offline   Reply With Quote
Old 09-17-2005, 02:25 PM   #13
The Vauxhall Vectra Project
ccsnet's Avatar
ccsnet has a spectacular aura aboutccsnet has a spectacular aura about
ou do have a point but it is a little overkill as you have the reset button if all else fails.
Terran
ccsnet is offline   Reply With Quote
Old 09-25-2005, 02:14 AM   #14
foltster is on a distinguished road
Terran
What he is talking about is the situation when the XP recover from hibernation mode fails. After this, XP will not boot until you plug in a keyboard and choose either "delete hibernation file and boot normally" or "try again". Win2k3 deletes this file by default and boots normally if hibernation fails(i think).
I really hate this in XP, becuase it is the only thing I ever need a keyboard for during "normal" operation of my CarPC.
foltster is offline   Reply With Quote
How to: Change windows shell IntellaWorks WinNT Based 39 10-13-2008 04:41 PM
File/web/print Server Quattro Off Topic 7 04-15-2005 10:26 PM
Programming for Pocket PC (Windows Mobile 2003 Second Edition) DjBac Software & Software Development 4 01-04-2005 03:36 PM
Windows Freeze When Crank, Crank again windows unfreeze antimatter Power Supplies 37 07-27-2004 01:40 AM
A few observations in OS and why I'm now using Windows 2003... Mastiff Software & Software Development 12 01-21-2004 10:11 AM
