Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 11-11-2005, 05:02 AM   #1
Help Neede @ My Life End With Cf & Xp
Yeah i am a n00b and i have searched but i need help.
I am 4 CF cards and a few CF-IDE connectors down and alot of money down the drain lighter.
I cant install XP and get it running on CF.
SP13000.
Kingston high speed 4BG CF.
Tranquil pc IDE-CF Adapter.
1:-I have tried to install stright to CF but i cant get the paging file active so i cant update windows or install net-framework,autoroute etc etc
2:-I have installed onto a normal harddrive and then tried to ghost it over, cant get it to work. closest i get it is stuck on the window screen.
HOW THE HELL DO I DO IT !!!! after 15 installs of window 98, ME, XP , XP PRO, XP HOME, XP TALBLET, XP CORP etc etc ...
Please help noob newbie to achive his goal. MAYBE AN IDIOTS GUIDE.
Thanks in advance from the UK
scooby8272 is offline   Reply With Quote
Old 11-11-2005, 05:15 AM   #2
Confusion Master
Enforcer's Avatar
Bloody hell, weve had double posting before and even three, but four in the same forum??????
Edit make that 5
Enforcer is offline   Reply With Quote
Old 11-11-2005, 05:17 AM   #3
Fox_Mulder's Avatar
Posting the same thing 5 times is not a good way to attract attention around here!
Fox Mulder
2001 Toyota Avalon Vxi
Toshiba TE2000 Laptop 1Ghz BU-353 Black Xenarc 700TSV HD & Analogue TV FM DVD/CDRW Car2PC Adaptor
2004 Toyota MR2
Intel Dual Core 2.0Ghz 1Gb DDR2 160GB SATA2 M4ATX Lilliput 7" TS BU353
Fox_Mulder is offline   Reply With Quote
Old 11-11-2005, 05:26 AM   #4
Sorry my PC froze and as usual i hit send a number of times...
SORRY GUYS Please help...was not done on purpose
Old 11-11-2005, 05:30 AM   #5
Fox_Mulder's Avatar
As long as it wasn't intentional!
I dont know too much about installing windows on a cf card but here goes:
It seems windows has a problem with the page file being on the cf card, this may be because the cf card has a limited number of read/write cycles. But then windows should just treat it as any normal drive and just use it untill it eventually dies from to many reads/writes.
It's a mystery to me!
Fox Mulder
2004 Toyota MR2
Old 11-11-2005, 05:31 AM   #6
Confusion Master
Enforcer's Avatar
<insert comment about the truth being out there>
<insert comment about it being a conspiarcy>
Old 11-11-2005, 05:39 AM   #7
Fox_Mulder's Avatar
a conspiarcy
I was waiting till I had some proof of aliens (and of course the government) preventing him from loading XP on the CF Card
Fox Mulder
2004 Toyota MR2
Old 11-11-2005, 06:05 AM   #8
MySQL Error
jcdillin's Avatar
You can install windows onto the drive, but you must get a utility from the card maker to switch it to fixed disk mode so that windows will not freak out on it. The other thing your going to need to do is install EWF (Enhanced Write Filter) or your cards are going to be dead within a few days.
If you can find it your much better of going with Windows XP embedded, i've got it running on a 1gb flash card with no problems at all.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 11-11-2005, 07:33 AM   #9
SFiorito's Avatar
http://osf1.gmu.edu/~sfiorito/eXPinstall.htm
SFiorito is offline   Reply With Quote
Old 11-11-2005, 08:41 AM   #10
Is the embedded way a big hasstle.
I just want the pc running with miniml apps.
can somebody point me to the link which is entiled " how to install windows xp to cf in easy steps"
Worth a try
cheers
Old 11-11-2005, 09:24 AM   #11
MySQL Error
jcdillin's Avatar
Thumbs up
Quote: Originally Posted by SFiorito
thanks!
肚子笑痛了
S60 Install
Old 11-11-2005, 12:10 PM   #12
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Dupes deleted. Good luck.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 11-11-2005, 02:29 PM   #13
Do you have to use the embedded route.
I take it i install windows 1st onto a clean drive then do the above ?
How do you prep the card for the copy over ?
Old 11-11-2005, 03:09 PM   #14
IntellaWorks's Avatar
Read SF's documentation. But to simplify the process here you go :
1.) Install a Stable Nlited version of XP on a regular IDE harddrive
2.) Optimize the XP installation by deleting uneeded stuff, disabling pagefil.sys install ALL drivers and make sure every device you plan to use in the car is working properly with XP on the IDE drive. I can't stress enough how important this is.
3.) Go ahead and Get EWF and Minlogon enabled into your XP. Make sure ALL the devices you plan on using are CONNECTED
4.) Reboot the machine to ensure EWF + MINLOGON is working properly and all your devices (including your USB ones) are still working properly.
5.) Now REMOVE ALL DEVICES, except the 3.5" floppy drive. This include the IDE harddive
6.) Connect the CF - IDE adapter with CF card and run bootprep from a FLOPPY. Note: BOOTPREP must be run from a floppy, don't try it from a bootable cd or dvd or usb flash device because it won't work.
7.) Format your CF card with Format c: /s and reboot your machine
8.) If you see a command prompt you're almost home free. Now type the command format c:
9.) Connect your CF card and IDE drive to another computer and boot to windows.
10.) In explorer select all from the IDE harddrive and copy it to the root of the CF card. In the end both drives should look identical. You may want to enable the viewing of hidden files if your windows machine doesn't have it enabled already.
11.) Plug the CF card back into your carpc and boot it up!
12.) Check to see if EWF is working properly, if its not you may have to re-do the EWF procedure to get it working.
oh yah, your CF card doesn't have to be considered a fixed disk in order for XP to work. However if your planning a setup that will hibernate or go into standby then you do. XP freezes when a shutdown/hibernate/standby message is given to the system its a known issue and there's no workaround...
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 11-11-2005, 03:21 PM   #15
Thats awesome man helps alot,
where do i get bootprep from
FAQ: Boot directly into your front end d_sellers1 The FAQ Emporium 95 09-29-2008 12:34 AM
can a carputer replace a high end av dedicated system? turbocad6 Car Audio 85 07-09-2007 04:44 AM
Damn visual basic BiohazrD Software & Software Development 2 02-04-2005 01:10 PM
Telematics.net IntellaWorks Software & Software Development 40 11-05-2004 08:20 PM
BASIC Stamp question Banderon General Hardware Discussion 18 05-07-2004 08:33 AM
