Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 01-30-2006, 04:06 PM   #1
CF boot. CF Shows up as D:
After following Sfiorito's EWF guide down to every tiny detail, there is one problem that i just cant sort out. My CF boots fine into DOS, and apparently transferring the files from HD to CF is done correctly. However, when I do my initial boot from CF, it almost resumes from hibernaion in complete, but always leads to a BSOD. Pressing F8 while booting gives me the option to "delete retoration data" and do a "fresh" boot. Doing this makes my CF appear as drive D, and obviously the drive is no longer "protected" by EWF..
Any ideas?
Best regards, Ketil.
ketilmorstoel is offline   Reply With Quote
Old 01-30-2006, 06:53 PM   #2
SFiorito's Avatar
do you still have the HDD plugged in when you boot up?
SFiorito is offline   Reply With Quote
Old 01-31-2006, 12:39 AM   #3
No other drives connected, only the CF which is set as master.
Ps: Thanks for sharing your knowledge and spending time with us here SFiorito. Its highly appriciated!
All the best, Ketil.
Old 02-09-2006, 08:38 AM   #4
I had the same problem this week.
Here is a fix:
http://www.petri.co.il/change_system...windows_xp.htm
It worked for me.
KiLLERHOLiC is offline   Reply With Quote
Argh! Two Problems: USB HD wont read on boot, only after, and CF prevents boot also.. wardemon666 General Hardware Discussion 10 04-17-2006 05:23 PM
I cant get my computer to boot my CF Card csnowman00 General Hardware Discussion 5 03-15-2005 12:10 AM
XP Pro on CF card working!! knubile WinNT Based 48 01-03-2005 06:48 PM
CF universal Boot Hardrives !!! chuckctv General Hardware Discussion 14 09-04-2004 10:27 PM
boot from CF? etrik General Hardware Discussion 5 02-09-2002 01:08 PM
