This is the info about the new build *from the site listed above*
eXPerience Presents...
Windows TinyXP Professional SP2 Revision 04 Unattended CD
This revised edition of TinyXP combines the small size of
older versions, but with almost all of the functionality
of later versions. This is primarily a fast gaming OS
There are no Microsoft games in this edition.
There are no third party programs included in
this edition. You are however still able to open
zip files, they will have a normal yellow folder
but with a zip.
There are no languages left apart from US English.
The keyboard layout is United Kingdom, system locale and
timezone are also set for the UK. This can be changed in
Regional and Language Options in Control Panel - all
"keyboard layouts" are left in.
There are no networking command line tools - this increases
security dramatically and stops businesses from using
TinyXP for their networking. If you're running a business
then hey - BUY WINDOWS XP. I have no sympathy with you
people.
It is important to note that TinyXP started out as a
gaming OS that you can surf the net with, and use most
programs with it. It ended up revised to the point that
you might as well use normal XP. This however was always
because it fully supported networking when it didn't need
to for the purpose it was meant for - home use.
In this edition, netstat.exe and other command line
networking tools and a few more networking type features
are now removed, TinyXP is back again to a very small
footprint (365Mb), a very fast install (7 minutes) and
uses far less RAM than Rev03 did - about 20Mb less.
This edition has Internet Explorer included, (not just
the core but the whole explorer). It also includes the
DHCP service, Wireless LAN drivers and is still compatible
with "Microsoft Office" and supports printers, joysticks,
firewire etc.
HINT: If you are in any doubt about the functionality
of TinyXP Rev04 - get hold of a program called "VMware"
and install TinyXP into VMware - this only takes about
as long as an install on your real PC would.
Then install "VMware tools" in VMware and drag whichever
programs into VMware you need to install them and give
the operating system a complete test before you actually
use it.
This edition DOES NOT work with "Sisoft Sandra".
Sisoft Sandra seems to rely on a lot of Windows components,
it was not worth the extra RAM and hard drive space needed,
just to support Sisoft Sandra.
This ISO is designed to be the ULTIMATE TinyXP, being
very small and VERY fast, whilst still giving you the
full functionality (almost) of normal XP - but without
as many networking features.
This edition does include "Active Directory" and basic
networking between two PC's will work fine, as long as
you enable "Simple File Sharing" under "Folder Options"
in "Control Panel". This "Simple File Sharing" is
disabled in this edition, so you can access the
"Security" tab on your file and folder properties.
EXE File Size in Bytes.......................... 127,774,258
Extracted ISO File Size in Bytes............ 152,016,896
Files on ISO........................................ 2,320
Folders on ISO..................................... 86
SHA-1 Checksum utility (fsum.exe) is provided with a
batch script to check the EXE file and the ISO file.
You must of course extract the ISO file from the EXE
file to check the ISO checksum!
The checksum codes for both the EXE file and the ISO file
can be found at...
http://www.retestrak.nl/Board/
Look under the section called Releases Only (P2P) and find
the thread for TinyXP Rev04.
If any of the above sizes, file & folder totals, or SHA-1
checksums are different to what you have, DO NOT USE THIS
EXE OR ISO FILE! You have a fake (repackaged) eXPerience
release! Most probably repacked with a trojan, or other
malicious worm/virus/rootkit.
Windows Performance Info...
Operating System RAM Memory Usage = 45Mb (▒ 5Mb)
WINDOWS Folder = 366.2Mb
Running Processes on First Install = 14
Install Time for Windows = Seven Minutes
Windows XP Pro Custom Added Features
eXPerience Spectrum Wallpaper
Integrated Service Pack 2 (WindowsXP-KB835935-SP2-ENU.exe)
Registry Tweaks For Performance/Gaming/Internet
Windows Media Center 2005 Beta Version Theme (Royale)
Integrated Critical and Recommended Post SP2 Hotfixes
(Windows Updates) up to 28th March 2006...
IE6.0sp1-KB905915-Windows-2000-XP-x86-ENU
WindowsInstaller-KB893803-v2-x86
WindowsXP-KB873333-x86-ENU
WindowsXP-KB873339-x86-ENU
WindowsXP-KB883939-x86-ENU
WindowsXP-KB884020-x86-enu
WindowsXP-KB885222-v2-x86-ENU
WindowsXP-KB885250-x86-ENU
WindowsXP-KB885835-x86-ENU
WindowsXP-KB885836-x86-ENU
WindowsXP-KB886185-x86-enu
WindowsXP-KB886677-x86-enu
WindowsXP-KB886716-v2-x86-ENU
WindowsXP-KB887472-x86-enu
WindowsXP-KB887742-x86-ENU
WindowsXP-KB887797-x86-enu
WindowsXP-KB888113-x86-ENU
WindowsXP-KB888240-x86-ENU
WindowsXP-KB888302-x86-ENU
WindowsXP-KB889527-v3-x86-ENU
WindowsXP-KB890046-x86-ENU
WindowsXP-KB890175-x86-ENU
WindowsXP-KB890859-x86-ENU
WindowsXP-KB891781-x86-ENU
WindowsXP-KB893066-v2-x86-ENU
WindowsXP-KB893086-x86-ENU
WindowsXP-KB893357-v2-x86-ENU
WindowsXP-KB893756-x86-ENU
WindowsXP-KB894391-x86-ENU
WindowsXP-KB894395-x86-ENU
WindowsXP-KB896344-v2-x86-ENU
WindowsXP-KB896358-x86-ENU
WindowsXP-KB896422-x86-ENU
WindowsXP-KB896423-x86-ENU
WindowsXP-KB896424-x86-ENU
WindowsXP-KB896427-v3-x86-ENU
WindowsXP-KB896428-x86-ENU
WindowsXP-KB896626-v2-x86-ENU
WindowsXP-KB898461-x86-ENU
WindowsXP-KB898900-v2-x86-ENU
WindowsXP-KB899587-x86-ENU
WindowsXP-KB899589-x86-ENU
WindowsXP-KB899591-x86-ENU
WindowsXP-KB900725-x86-ENU
WindowsXP-KB900930-x86-ENU
WindowsXP-KB901017-x86-ENU
WindowsXP-KB901190-x86-ENU
WindowsXP-KB901214-x86-ENU
WindowsXP-KB902400-x86-ENU
WindowsXP-KB903234-x86-ENU
WindowsXP-KB904706-v2-x86-ENU
WindowsXP-KB905414-x86-ENU
WindowsXP-KB905749-x86-ENU
WindowsXP-KB905915-x86-ENU
WindowsXP-KB908519-x86-ENU
WindowsXP-KB908521-x86-ENU
WindowsXP-KB910437-x86-ENU
WindowsXP-KB911927-x86-ENU
WindowsXP-KB912919-x86-ENU
WindowsXP-KB913446-x86-ENU
Enjoy this fine release from eXPerience
Build Date: 13.04.2006
Release Date : Spring 2006
