Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 05-04-2006, 10:25 AM   #1
proximo is on a distinguished road
Error installing .Net framework 1.1.4322
Hi!
Im having a problem installing .Net framework on an nLited winxp version.
The error occurs right after the install program has extracted its files and is ready to begin. Since i have a norwegian version of Windows, ill have to translate it as good as i can:
"The installation program for Microsoft .Net Framework can not write to the installation log."
I click "OK" and the installation stops.
I tried using the "dotnetfx.exe /T:<temp folder> /C" switches, and the installation started and finished without errors.
Next I tried to install Centrafuse 1.6, but the installation program said that it needed .Net Framework 1.1.4322 to continiue. The same message you would get without having .Net installed at all.
So I guess the problem is with the install log issue?
Here is a cutout of the most relevant information from the nLite latest session file for the windows installation i used. Is there anything in this config that can be the source of the problem?
(still in norwegian but i guess you recognise most of it)
Quote:
;# Operativ System Innstillinger #
Color Schemes
Disk and Profile Quota
Diskopprydding
Document Templates
FAT to NTFS converter
Fil og Oppsettguide
Hjelp
Input Metode Editor
Jet Database Engine
Manuell Installering og Oppgradering
MS Agent
Oppgave Planlegger
Private Character Editor
Remote Installation Services (RIS)
Sikkerhets Senter
Skrivebord Oppryddings Veiviser
Søke Assistent
Tur
User Account Pictures
Ut av Boks hendelse
Web Visning
Zip Kataloger
;# Service #
Advarsler
Autoupdate
Avbruddsfri Power Supply
Beep Driver
Faks Service
Feilrapportering
Fjerninnstill Register
Flyttbar Lagring
Imapi
Indekserings Service
Messenger
System Gjenoppretting
Telnet Server
Terminal Service
Volume Shadow Copy
WebClient
Windows Tid
;# Compatibility #
Compat02
Compat06
Compat12
[KeepFiles]
msconfig.exe
[RemoveFiles]
blastcln.exe
clock.avi
[Options]
ClassicSetup
BlackSetupBack
GuestName = ""
AdminName = ""
ProfilesDir = "%SystemDrive%\Documents and Settings"
TargetPath = "OS"
temp_dir = %USERPROFILE%\Lokale innstillinger\Temp
AdvTweaks
isovol = WinLite
isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
[Patches]
TcpIp = 10
UsbPoll = 125
DoUxTheme
DoSFC
[Services]
Themes,2
StiSvc,3
AppMgmt,3
AudioSrv,2
CryptSvc,2
EventLog,2
HidServ,4
HTTP,3
HTTPFilter,3
IpNat,3
NDProxy,3
NetDDE,4
NetDDEdsdm,4
Netman,3
PlugPlay,2
ProtectedStorage,2
SamSs,2
seclogon,2
SENS,4
SharedAccess,2
SysmonLog,3
TapiSrv,3
TrkWks,2
Wmi,3
xmlprov,3
LanmanWorkstation,2
RasAuto,3
RasMan,3
RemoteAccess,4
IpFilterDriver,3
IpInIp,3
Ip6Fw,3
ALG,3
DHCP,2
DNSCACHE,2
PolicyAgent,2
NLA,3
LMHosts,2
Browser,2
NetLogon,3
RpcLocator,3
NtLmSsp,3
LanmanServer,2
proximo is offline   Reply With Quote
Old 05-04-2006, 11:03 AM   #2
After some reading around on the net i found that missing IIS is probobly the reason why .Net wont work.. ?
Old 05-04-2006, 12:22 PM   #3
v8 scimitar's Avatar
v8 scimitar is on a distinguished road
I dont have IIS anywhere near my PC but I still have .net loaded both 1 and 2
v8 scimitar is offline   Reply With Quote
Old 05-04-2006, 11:01 PM   #4
willisan's Avatar
willisan is on a distinguished road
I had this problem also....I finally got it to work by downloading an old version of 1.1 from some russian site...yes, I know....but it worked.
willisan is offline   Reply With Quote
Old 05-19-2006, 05:07 AM   #5
tanqueray is on a distinguished road
.net error
I had this same problem as well. I was using minlogon. I solved the problem by restoring winlogon, installed .net, then re-established minlogon.
good luck
tanqueray is offline   Reply With Quote
sendMessage from a .Net App ruairi Road Runner 15 09-30-2007 01:32 PM
Archive liquid_smoke PhoneControl 387 07-23-2006 05:01 AM
Using Destinator SDK with .NET BrainCore Map Monkey 2 05-08-2006 05:53 AM
nLite without .NET possible now ! nuhi WinNT Based 4 01-18-2005 03:58 PM
C++: GUI Programming with >NET Framework [iG] Software & Software Development 3 05-24-2004 07:57 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
