Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 05-31-2006, 03:05 AM   #1
Ram issues
so i just got my carputer and installe dmy 1gb pc2100 ram but in tinyxp rev 4 it only reads that there is 499 mb is there a driver that i need to install i hvae a via mobo
allahsone is offline   Reply With Quote
Old 05-31-2006, 03:33 AM   #2
v8 scimitar's Avatar
doesnt sound like a driver issue, what does the bios report as the ram size? It could easy be half the stick isnt working.
v8 scimitar is offline   Reply With Quote
Old 05-31-2006, 05:40 AM   #3
Neither darque nor pervert
DarquePervert's Avatar
It's more like the motherboard shares system RAM for video RAM.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 05-31-2006, 05:44 AM   #4
WarDriver's Avatar
I know this sounds like a dumb question but what speed of ram does your PC take? I've put slower ram in a PC with a faster bus speed and it registers as half.
-WarDriver-
Real Men Pay With CA$H
My DC to AC Inverter Mod
My Laptop Remote Switch
WarDriver is offline   Reply With Quote
Old 05-31-2006, 12:58 PM   #5
mother boeard takes up to 1 gb. but it wouldnt take 500 mb for vedio.
Old 05-31-2006, 01:10 PM   #6
Fusion Brain Creator
2k1Toaster's Avatar
no but it could take up to 256mb on via mobos. I say do as scimtar suggested and look when it post's to see how much ram is being registered at the simple level. make sure you disable quick boot too so that it actually scans the ram and doesnt just assume what it is (saves time, hence quick boot!). if in the post it says 1024mb, then obviously software related. I know that in 98, it only supported 512, even though a 4gb stick could be in there. Could be a driver. If it does not show up at booting, then run memtestx86. (its called something like that). its free and will check your ram. good luck.
Old 05-31-2006, 02:09 PM   #7
how do i change my bios settings
form quick to normal.
Old 05-31-2006, 02:11 PM   #8
nm found out how.
Old 05-31-2006, 02:50 PM   #9
well hte bios says its only 491mb is it possible that this is caused by the fact that it is a cheapo ram off of ebay high density.
Old 05-31-2006, 03:57 PM   #10
2k1Toaster's Avatar
Yup. That can do it...
Old 05-31-2006, 04:09 PM   #11
F**K oh well i might as well just spend 90 on a gig. do you kow anything bout tft i'm having issues. its hella blurry. and i dunno what to do.
Old 05-31-2006, 04:15 PM   #12
2k1Toaster's Avatar
There are lots of lcd's that have a blurry image. I have yet to find a cure. We tried on this thread though: http://www.mp3car.com/vbulletin/lcd-display/74600-7-xenarc-extremely-blotchy-video.html
As for the RAM, it could be because it is Dual something RAM. I forgot the name of it, but it is the "high density" stuff that alot of boards won't recognize. Therefore you only get half, which is what you are getting. Try a non-dual layer.
Old 05-31-2006, 04:24 PM   #13
on your setup do you have the display settings as lcd or tv thanks
Old 05-31-2006, 04:34 PM   #14
2k1Toaster's Avatar
as lcd.
for tv, it uses RCA, and that is very very blurry.
Old 05-31-2006, 05:21 PM   #15
so how do you have your lcd plugged through the vga port. because my screen only has rca ports. thanks
Another crazy mod: RAM booting XP (no, not EWF) SFiorito WinNT Based 11 01-18-2007 07:39 PM
Having instability issues with your M7NCG 400 and/or XP install? wallaceacura General Hardware Discussion 0 07-20-2005 01:29 AM
FS lots of ram kderedwolf Classified Archive 10 04-29-2005 06:28 PM
Power issues in 03 Mustang tj!2k4 Power Supplies 17 12-22-2004 01:16 PM
Any Standby to ram issues with Frodoplayer required files? Lattice FrodoPlayer 1 04-30-2004 07:04 PM
