Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 07-14-2006, 12:53 AM   #1
ppgt94's Avatar
Adding components (modem support) that were removed on nlite install to current XP
Ok, here's the deal. A few months ago I made what I thought to be the perfect custom XP install using nlite. At the time I thought I'd never need dial-up modem support in the car. That was all fine and dandy until I wanted to use my LG-235 as a modem via bluetooth.
I know the phone will pair with the BT dongle and have connected to the Internet using the phone as a modem on my laptop with a OEM XP install.
I know according to nlite's FAQ say you can't really add a component once it's been removed. Supposedly the only way to do such a thing is to import a previous session to further refine the selections made in that previous session to include what you removed. Then of coarse I would presume that would call for a re-install of the entire newly modded OS
So does anyone know of a method/hack to add this dial-up modem support into my current very stable and highly personalized XP install? All my 'net scouring left me mostly empty handed and discouraged. I'm holding out for a mp3car hero to save the day. ....Please?
ppgt94 is offline   Reply With Quote
Old 07-14-2006, 08:06 PM   #2
ppgt94's Avatar
Bump?
Old 07-17-2006, 04:02 PM   #3
Couldn't you just install the driver from the install CD that came with the phone (or the latest updated version from the website)?
or use the add hardware wizard and select the driver if it still works on your install?
your computer is bored - give it something useful to do!:rosetta@home
dcdc is offline   Reply With Quote
Old 07-18-2006, 02:51 PM   #4
ppgt94's Avatar
Normally, I could but it's like windows doesn't even know what a modem driver is.
Old 07-18-2006, 02:58 PM   #5
IntellaWorks's Avatar
Oh man. Me thinks you're scr3w3d. The only suggestion I have is to try "add / remove hardware" If thats even in your nLite build.
Actually some more suggestions are comming as I'm typing this. What does the device show up as in System?? If it's showing up as unknown you may have a chance. Try selecting the modem's .inf file from system.
If I remember correctly though most nlites posted (including the one I created and I think was modifed a few times) takes out modem support... You might have to slipin the drivers on a new nLite plus enable modem support... it might be quicker to re-build an nLite.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
IntellaWorks is offline   Reply With Quote
Old 07-18-2006, 03:00 PM   #6
Raw Wave
Tidder's Avatar
Could always build a new cd with nLite then run a repair on your current XP install... maybe you wouldn't loose much.
Tidder is offline   Reply With Quote
Old 07-18-2006, 05:37 PM   #7
or if that fails, create a new nlite CD with modem support, and then install that and your original onto different partitions and compare the registry differences and file differences between them with a 3rd party app. The modem support entries should be the only differences...
Beyond Compare is excellent for comparing directories.
Old 07-18-2006, 05:41 PM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
If you still have your sessions file, you can recreate the nlited OS.
There is no way to add it, even with the control panel. I know cause I tried with the exact same thing. I was using TinyXP, but couldn't get my Blackberry to work because it removed the modem.
Good Luck.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Safe nLite setting.ini IntellaWorks WinNT Based 150 02-26-2008 08:04 PM
XP System Builder SFiorito WinNT Based 120 03-19-2007 05:13 AM
Why can't I install windows XP ? please help ? shinjetko Newbie 24 09-19-2006 02:02 PM
Tinyxp vs nlite vs sensible install geeky_hawkes WinNT Based 5 06-15-2006 03:55 PM
Tech Support Calls Rafster Off Topic 8 06-12-2006 11:49 AM
