The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Display Modes
Old 08-02-2006, 08:18 PM   #1
_
RedGTiVR6's CarPC Specs
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Problems with BootSkin and CarPC
Welp, I think I've done it. Go me!
I have been wanting to change the boot screen for some time now, just never got around to doing it.
I had a few spare minutes today at work so I decided to test it out on my laptop.
I followed this post: http://www.wincustomize.com/articles.aspx?aid=58737&c=1
Everything worked like a charm on my laptop. It's the guinea pig.
So then I go to make the change on my CarPC.
I remoted into the carPC with my laptop (ad-hoc) and transfered the .exe for the BootSkin install. Once it installed, I just copied over the folder that I had created on the laptop that had the bootskin image and status bar as well as the .ini in it. All installed to the same location on both machines.
Go to reboot the CarPC to see the new boot screen in action, and what happens? Absolutely nothing.
It will go through the VIA splash screen, then when the normal Windows XP boot screen should come up, it just goes black.
Nothing.
The PC is still running, but no one is home.
So I plug in my USB keyboard and restart, hitting F12, F8, and F2 (restarted 3 times - one for each key). Nothing. I can't even get to the point where I can see a screen that tells me to his X keys to get to Y.
So I go up to my home pc, unplug the PS2 keyboard and plug it into the CarPC. Reboot and the lights on the keyboard light up, but still, no one is home.
So I put a Windows CD into the USB cd drive and reboot. Nothing.
Same with the EPIA drivers cd....nothing.
I'm stuck.
I can't get into the BIOS, I can't get into safe mode, I can't get into last known good configuration.
Anyone?
Jan Bennett
If you're needing someone to tell you what to buy, how to install it, or how to make it sound good, I charge a consulting fee.
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 08-02-2006, 08:51 PM   #2
Neither darque nor pervert
DarquePervert's CarPC Specs
DarquePervert's Avatar
Vehicle: 2003 Toyota Tacoma X-Cab
My Photos: (26)
Press DEL to enter the bios setup.
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 08-02-2006, 08:53 PM   #3
_
My Photos: (73)
shut up
Jan Bennett
Old 08-02-2006, 08:58 PM   #4
_
My Photos: (73)
finally got in to boot to last known good config....after realizing that del would take me into the bios, where I could then disable the splash screen and actually see the POST, at which point hitting F8 would actually do something and allow me to see the menu where I could boot to last known good configuration.
thanks for the hint Darque....brain farts suck
now to figure out why it wouldn't work....
Jan Bennett
Old 08-02-2006, 09:14 PM   #5
My Photos: (26)
We're working on it.....
For anyone following this ongoing drama, VGA mode from the F8 menu crapped, as well.
Next stop: Repair fromt he Windoze CD.
My Worklog
Old 08-02-2006, 09:40 PM   #6
Para Laura
thanatos106's CarPC Specs
thanatos106's Avatar
Vehicle: Xterra SE supercharged
My Photos: (0)
So when you are booting the laptop, it ask you which system or what ever you want to boot in right? and you .ini file look like something like this but with a second line pointing to the new images)
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOW S
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Micro soft Windows XP Professional" /fastdetect /NoExecute=OptIn
Or are you using a third party app?
or you reshack the ntoskrnl?
I did read that article but I still don't understand how that guy introduce the new bootscreen.
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 08-02-2006, 09:48 PM   #7
_
My Photos: (73)
you introduce the new boot screen using the bootskin program.
when booting the laptop, everything works fine. Just boots like any other normal system, just with a new windows splash screen.
ini file looks like the one in that how-to.
Jan Bennett
Old 08-02-2006, 10:06 PM   #8
Para Laura
My Photos: (0)
Best thing to do if you don't want to do a windows repair form the CD (like DP said) is to go in safe mode and edit the .ini file back to the way it was (or if you just add a new line for multiple bootscreens, just delete it)
Just a pice of advice, don't use third party programs to manage your bootscreen (no when reshaking the ntoskrnl is so aesy) cuz the build of the bootscreen in fact change every once in a while with some windows updates.
Thanatos.
Nissan Aux-in MOD
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
