Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Old 10-17-2006, 08:23 PM   #1
miwise's Avatar
miwise is an unknown quantity at this point
Question Trying to make tiny xp from my Windows XP Disc with nlite
I used the Tiny XP Guide from exPerience, and I keep getting this message in nLite, what am I doing wrong here? I'm using WinXP service pack 2 disc home edition.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.IOException: Cannot create a file when that file already exists.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.__Error.WinIOError()
at System.IO.FileInfo.MoveTo(String destFileName)
at ..()
at ..(Object , EventArgs )
at System.Windows.Forms.Control.OnEnter(EventArgs e)
at System.Windows.Forms.Control.NotifyEnter()
at System.Windows.Forms.ContainerControl.UpdateFocuse dControl()
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINNT/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
nLite
Assembly Version: 1.2.0.1
Win32 Version: 1.2.0.1
CodeBase: file:///C:/Program%20Files/nLite/nLite.exe
System
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
nLite
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
cablib
Assembly Version: 1.0.2459.36134
Win32 Version:
CodeBase: file:///C:/Program%20Files/nLite/cablib.DLL
msvcm80
Assembly Version: 8.0.50608.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINNT/system32/msvcm80.dll
nlgw
Assembly Version: 1.1.0.0
MCDBNET2
Assembly Version: 1.32.0.0
Win32 Version: 1.32.0.1302
CodeBase: file:///C:/Program%20Files/nLite/MCDBNET2.DLL
Accessibility
CodeBase: file:///C:/WINNT/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Here is the configuration script I'm using from LAST SESSION.INI:
[Tasks]
Remove Components
Patches
Tweaks
Options
[Components]
;# Applications #
Accessibility Options
Briefcase
Charmap
ClipBook Viewer
Defragmenter
Games
Internet Games
NT Backup
Pinball
Screensavers
;# Drivers #
Asynchronous Transfer Mode (ATM)
Cameras and Camcorders
Display Adapters
IBM Thinkpad
InfraRed
ISDN
Logitech WingMan
MultiFunctional
Portable Audio
Printers
Scanners
SCSI/RAID
Sony Jog Dial
Tape drives
Toshiba DVD decoder card
;# Hardware Support #
ATM Support
Brother Devices
Gravis Digital GamePort
Logical Disk Manager
Multi-port serial adapters
Secure Digital host controller
Smart Cards
Sony Memory Stick
Teletext codec
Video Capture
Windows CE USB Host
Windows Image Acquisition (WIA)
;# Multimedia #
AOL ART Image Format Support
DirectX diagnostic tool
Images and Backgrounds
Intel Indeo codecs
Luna Theme
Media Center
MIDI audio support
Mouse Cursors
Movie Maker
Music Samples
Old CDPlayer and Sound Recorder
Speech Support
Tablet PC
Windows Media Player
Windows Media Player 6.4
Windows Sounds
;# Network #
Client for Netware Networks
FrontPage Extensions
IP Conferencing
MAC Bridge
Map Network Drives/Network Places Wizard
MSMail and MAPI
MSN Explorer
Netmeeting
NetShell Cmd-Tool
Network Monitor Driver and Tools
Network Setup Wizard
NWLink IPX/SPX/NetBIOS Protocol
Peer-to-Peer
Synchronization Manager
Windows Messenger
;# Operating System Options #
.NET Framework
16-bit support
Administrative Templates
Administrator VB scripts
Color Schemes
Command-Line tools
Desktop Cleanup Wizard
Disk and Profile Quota
Disk Cleanup
Document Templates
DR Watson
File and Settings Wizard
File System Filter Manager
Help
Input Method Editor
Logon Notifications
Manual Install and Upgrade
MS Agent
Private Character Editor
Remote Installation Services (RIS)
Save Dump Utility
Search Assistant
Security Center
Service Pack Messages
Shell Media Handler
Task Scheduler
Tour
Web View
;# Services #
Alerter
Application Layer Gateway
Autoupdate
Background Intelligent Transfer (BITS)
Beep Driver
COM+
Distributed Link Tracking Client
Distributed Transaction Coordinator (DTC)
DNS Client
Error Reporting
Event Log
Fax Services
Imapi
Indexing Service
IPSEC Policy Agent
Management Instrumentation (WMI)
Message Queuing (MSMQ)
Messenger
Network DDE
Network Location Awareness (NLA)
Performance Logs and Alerts
QoS RSVP
Quality of Service (QoS)
Remote Registry
Removable Storage
Secondary Logon
Service Advertising Protocol
Shell Services
SNMP
System Event Notification (SENS)
System Monitor
System Restore
TCP/IP NetBIOS Helper
Telnet Server
Terminal Services
Text Services Framework
Volume Shadow Copy
WebClient
Windows Firewall/Internet Connection Sharing (ICS)
;# Directories #
DOCS
SUPPORT
VALUEADD
;# Compatibility #
[KeepFiles]
msconfig.exe
[RemoveFiles]
clock.avi
[Options]
CABRecompress
ClassicSetup
BlackSetupBack
GuestName = ""
AdminName = ""
ProfilesDir = "%SystemDrive%\Documents and Settings"
TargetPath = "WINDOWS"
temp_dir = %USERPROFILE%\Local Settings\Temp
isovol = WinLite
isoatt = -allow-multidot -no-iso-translate -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
[Patches]
TcpIp = 16777215
UsbPoll = 125
DoUxTheme
DoSFC
[Services]
StiSvc,3
AppMgmt,3
AudioSrv,2
CryptSvc,2
HidServ,4
HTTP,3
HTTPFilter,3
IpNat,3
NDProxy,3
Netman,3
PlugPlay,2
ProtectedStorage,2
SamSs,2
SCardSvr,3
TapiSrv,3
UPS,3
xmlprov,3
LanmanWorkstation,2
RasAuto,3
RasMan,3
RemoteAccess,4
IpFilterDriver,3
IpInIp,3
DHCP,2
Browser,2
NetLogon,3
RpcLocator,3
NtLmSsp,3
LanmanServer,2
miwise is offline   Reply With Quote
Advertisement Sponsored links
Old 10-17-2006, 08:24 PM   #2
miwise's Avatar
[Tweaks]
Desktop-Internet Explorer icon-Hide
Desktop-My Computer icon-Show
Desktop-My Documents icon-Hide
Desktop-My Network Places icon-Hide
Desktop-Recycle Bin icon-Show
Explorer-Add 'CMD Shell' to all Drives and Folders
Explorer-Advanced Search: preconfigure options
Explorer-Change Explorer Folder View to: details
Explorer-Classic Control Panel
Explorer-Disable Beep on errors
Explorer-Disable Prefix: Shortcut to
Explorer-Remove Send To on context menu
Explorer-Show all files and folders
Explorer-Show Drive Letters in front of Drive Names
Explorer-Show extensions of known file-types
Explorer-Show Full Path in Address and in Title-Bar
Explorer-Show Statusbar in all windows
Internet Explorer-Disable information bar when popup is blocked
Internet Explorer-Disable Market Place bookmark
Internet Explorer-Disable Media Player 6.4 created bookmarks
Internet Explorer-Disable sound when popup is blocked
Internet Explorer-Enable Google URL-Search
Internet Explorer-Keep IE URL-History for-50 Days (max recommended)
Internet Explorer-Set Homepage-www.google.com
Internet Explorer-Set Internet Explorer to accept 10 connects at a time
My Computer-Add Control Panel to Context Menu
My Computer-Add Device Manager to Context Menu
My Computer-Add Services to Context Menu
My Computer-Add Software to Context Menu
My Computer-Remove Shared Documents
My Computer-Show details in Device Manager
My Computer-Show non-present devices in Device Manager
Network-Disable automatic search for network folders and printers
Network-Disable restoring mapped network drives on logon
Network-Disable Simple File Sharing
Privacy-Clear most recently opened documents list on logoff
Privacy-Disable and Remove Documents List from Start Menu
Privacy-Remove Alexa Spyware
Security-Always show Updates under Software
Security-Disable Screensaver
Security-Disable Web Open With prompt
Speed-Disable Optimize harddisk when idle
Speed-Disable Tracking of Broken Shortcut Links
Speed-Do not cache thumbnails
Speed-Use Windows classic folders / No Tasks Sidepanel
Start Menu-Disable Highlight newly installed programs
Start Menu-Disable popup on first boot
Start Menu-Reduce popup delay
Start Menu-Remove My Music
Start Menu-Remove Search the Internet from Search
Start Menu-Remove Set Program Access and Defaults
Start Menu-Remove 'Windows Catalog' from Start Menu
Taskbar-Disable Balloon Tips
Taskbar-Disable Group similar Taskbar buttons
Taskbar-Disable Hide inactive icons
Visual Effects-Animate windows when minimizing and maximizing-Disable
Visual Effects-Fade effect on menus and tooltips-Disable
Visual Effects-Show shadows under mouse pointer-Enable
Visual Effects-Show translucent selection rectangle-Enable
Visual Effects-Show window contents while dragging-Enable
Visual Effects-Slide open combo boxes-Disable
Visual Effects-Slide taskbar buttons-Disable
Visual Effects-Smooth edges of screen fonts-Enable
Visual Effects-Use common tasks in folders-Disable
[Unattended]
UnattendMode = DefaultHide
ComputerType = Automatic
MaximumDataStorePercentOfDisk = 12
ProgFilesPath = "C:\Program Files"
[GuiRunOnce]
[Drivers]
[Hotfixes]
Old 10-18-2006, 06:11 PM   #3
miwise's Avatar
figured it out yesterday. It seems that the program I used didn't change the attributes from read only, so after changing attributes, the process worked great! Just have to install now.
Old 10-18-2006, 06:49 PM   #4
fatejd is on a distinguished road
Please provide an update on how it works - I don't think I'll ever do the nLite thing, but I figure the more feedback on how well it works the better
Carputer Progress:
Re-do fabrication of screen [DONE]
Upgrade screen and PC [70%]
Wood faceplate for computer in glovebox [0%]
fatejd is offline   Reply With Quote
Old 10-19-2006, 04:46 PM   #5
miwise's Avatar
Well, I just burned the cd today. I'm in the process of installing it on my laptop now. I'll post more when done. It cut the on-cd size down to about 235 mb. This is xp home service pack 2 that came witht the laptop. So far it has given me messages about some missing files on the cd.
Old 10-19-2006, 06:07 PM   #6
miwise's Avatar
Alright, the setup hung up when it was detecting and installing devices. I made a new cd (it was about 10 mb heavier) and we'll see what happens. Going to look around and see if I can find any more info on the subject here in the board.
Old 10-19-2006, 06:09 PM   #7
miwise's Avatar
got streamui error, buty I just OK'd through it and it finally finished detecting devices this time.
Old 10-19-2006, 07:34 PM   #8
miwise's Avatar
Alright, got no frills windows xp running after downloading a couple of drivers. It seems to be running on about 53 mb of ram without roadrunner going (nothing else running) plus about 85 mb of disk cache going. I have 512 mb of ram, so this is nothing. I turned off virtual memory, so it seems to run pretty well like this. . .so far. I used my service pack 2 disc and installed it on the laptop I just got off ebay. I just used the key that was on the laptop (I had the disc for the laptop I got, but it had the original windows xp on it). So far so good.
Windows XP w/wireless Linksys USB vs NetStumbler trying to wardrive clean customs Wireless Communications 8 01-07-2009 12:18 PM
Software Review: Windows XP Media Center 2005 Edition! nFiniteTuning The Review Palace 180 05-01-2007 12:54 PM
installing windows xp or 98 on 1GB CF arise360 Software & Software Development 5 11-11-2004 07:13 PM
How do I make ME reads the mp3s ID tags instead of windows' XP? nl4jy Media Engine 11 10-08-2004 08:59 PM
