The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Operating System Optimization > WinNT Based
Thread Tools Search this Thread Display Modes
Old 05-16-2007, 01:28 AM   #31
My Photos: (0)
does anyone have aim, who could give me a little more info on this, i tried reading and i have a somewhat understanding of how it works, but for some reason i just cant seem to understand if i should install window embedded in my regular computer and then everything is going to get transferred on to the cf and placed in my carputer or should it all be done on the actual carputer my aim is aimfaberz hit me up if you have some time so i can get a better understanding of this. thanks everyone in advance
faberz is offline   Reply With Quote
Sponsored Links
Old 05-29-2007, 05:11 AM   #32
My Photos: (0)
You should install a full Windows Xp version on your carputer mb (use an hd in this phases), then run tap.exe on it to have a full devices description.
Then you can work on your regular computer using "Component Database
Manager" and "Target Designer" from Microsoft Windows Embedded Studio
Microsoft.
Once created the image of your target carputer you con copy on hd to
speed up FBA. After you installed all needed sw you can copy all on a cf.
There some intermediate steps you need to do...
Let me know,
Gianni
giovgall is offline   Reply With Quote
Old 05-29-2007, 11:57 PM   #33
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Does a CF need to be formatted with FAT16 to boot? Or does FAT32 work? I have a SanDisk Extreme III 4gig that I'm planning to boot with. My first try with XP didn't work though, won't boot.
crooper is offline   Reply With Quote
Old 05-30-2007, 11:14 AM   #34
SFiorito's Avatar
Vehicle: 2006 Impreza WRX Limited
My Photos: (0)
FAT32 is fine
SFiorito is offline   Reply With Quote
Old 06-01-2007, 03:37 AM   #35
My Photos: (0)
Quote: Originally Posted by Machinist View Post
List of flash media cards I have confirmed to boot XPe with:
note: I have not yet found a CF card that was not able to boot XPe.
Transcend Industrial CF with Fixed Disk UDMA4 2GB (TS2GCF45I-D) - this one formatted NTFS using an XP CD, definitely one of the fastest FBA, boot, and operation in comparison to the other cards I have tested so far. I did the FBA through the Addonics IDE to CF Adapter, but afterwards I ran the card using the Addonics SATA to CF Adapter without problems. I assumed prior to doing this that I would come across device driver related issues, but there was none. I was unable to notice any difference in terms of speed compared to my 2.5" IDE drive, though HD Tach benchmarks showed otherwise.
A-DATA CF Turbo 8GB 120x - this one was detected Removable, I just did fdisk -> format -> bootprep and copied contents over. This one was slow speed
SanDisk CF 512MB - removable, fdisk -> format -> bootprep, slowest speed
SanDisk CF 4GB - removable, fdisk -> format -> bootprep, slowest speed
Transcend 4GB 120x(TS4GCF120) - this one was Fixed Disk - able to be formatted as both NTFS and FAT32 through regular means.
SanDisk Ultra II 4GB - removable, fdisk -> format -> bootprep, slow speed
SanDisk 256MB SD Card - removable, fdisk -> format -> bootprep, I used the Addonics flash media to IDE adapter for this one(capable of dma!). FBA was slow, but bootup was very fast. The Windows loading screen only loaded 3/4 of the bar before the Welcome Screen showed. I can't imagine the speed with a faster SD card.
Seagate 4GB 3600RPM MicroDrive - removable, fdisk -> format -> bootprep, high speed image transfer and Hd Tach benchmarks but slow FBA. A noticable lag time for applications.
Hi,
Thanks for this one, had to register to this forum also.. I've been running my nlited winxp mediacenter machine with a-data 120x cf, fat formatted, pagefile disabled, ewf and so on for a while.
After reading this: http://www.storagesearch.com/ssdmyths-endurance.html i'm planning to put cf cards to use with my desktop machine also. Probably with 2 transcend 120x 2GB cards on a raid. I bought 2 gigs more ram, total of 4GB so i could put pagefile to ramdisk as i want to have pagefile on my desktop machine. And i do understand that for example cf cards 80% filled migth mean that transcend cards write endurance could drop. Those cards have spesification of 1 000 000 erase/write cycles. I think cf cards last like long enough if i dont use ewf but disable indexing service, ntfs last accesed and so on. Does anyone (dis)agree?
Does anyone have any experience on a Kingston cf cards? Brand sounds quite good.
Miitsi is offline   Reply With Quote
Old 06-01-2007, 02:50 PM   #36
Machinist's CarPC Specs
Machinist's Avatar
My Photos: (3)
Problem is that Kingston always has removable CF cards. They also don't have any UDMA cards, their fastest card right now is only 133x.
I really suggest that instead of setting up RAID with the 120x, use the Transcend 266x CF card instead. The 266x is the best CF card I have used yet. The pricing is almost identical to the 120x, yet it has more than double the transfer rate. It is great for booting, it can format NTFS, create RAID, hibernate works, and it is faster than the Extreme IV. The XP boot was ridiculously fast. The Windows loading screen didn't even get to begin the progress bar. I tested the time for a reboot timing from desktop to desktop, and it was about 20 seconds with that previous target machine. If you're coming from an A-Data 120x, you will definitely be amazed by this card.
I've been testing booting from a Transcend 150x SD card, and the boot is just as fast compared to the Transcend 120x CF. To answer your question about the program/erase cycles, with EWF enabled you could even set the hardware locked write protect on the SD card and still function perfectly fine. Of course, you wouldn't be able to commit any changes to the SD card, but it just shows that you can operate your system without writing to the drive at all. If you don't use EWF, I suppose you could use FAT, disabling a load of services, system restore and all that, but I wouldn't really recommend it for your desktop system.
Machinist is offline   Reply With Quote
Old 06-02-2007, 10:19 PM   #37
Vehicle: BMW
My Photos: (0)
Microsoft.
Does anyone have full instructions for this?
Where do you find tap.exe?
Any tutorials for the Component Database Manager and Target Designer?
From my understanding, all we need to do is install WinXP on a HD, install all necessary software, then copy everything into the target CF card while booted on a different OS. I also assume that this needs to be done on the target computer (because you need to install the video drivers, via4in1 etc). Is this right?
New Lilliput EBY701 For Sale http://www.nusantech.com/index.asp?c...at=TOUCHSCREEN
SiRF3 Bluetooth GPS http://www.nusantech.com/index.asp?cat=GPS
masch is offline   Reply With Quote
Old 06-04-2007, 01:34 PM   #38
Machinist's Avatar
My Photos: (3)
Check out MSDN for full instructions:
http://msdn2.microsoft.com/en-us/library/ms940811.aspx
XPe works differently from WinXP. You would run tap.exe to identify devices on your target machine, then you would be build the image from software installed on your development machine, then you transfer the files onto the hard drive (after it is properly formatted).
For standard XP that method you specified is correct.
Old 06-04-2007, 11:12 PM   #39
crooper's Avatar
My Photos: (0)
Wouldn't it be faster to use that 4 gigs of ram and turn off the pagefile? I get away with no pagefile with 2 gigs with no problems, unless I'm running Photoshop or some ram-hungry games. My carpc runs fine w/o a pagefile with 512 megs ram.
Old 06-07-2007, 09:04 AM   #40
My Photos: (0)
My media center also works fine with 512 or 1024 and pf disabled. Some applications/games just doesn't seem to work without pagefile enabled nevertheless how much ram i have and even if half of it is not in any use. Or at least used to do so, and as i'm constructing desktop machine i like not to think whether thats the problem or not. Ram sticks are so cheap that this makes sense.
Sponsored Links
Old 06-08-2007, 07:51 AM   #41
My Photos: (0)
Hello forum.
Originally I was interested if these 266x CFs really work with declared speed on CF to ide adapters. Since You make that clear for me I was thinking of making an RAID 0 array with four 8 GB 266x CFs.
Can someone (Miitsi / Machinist) please report results in HD Tach of two CFs in RAID 0 array.
goko is offline   Reply With Quote
Old 06-08-2007, 11:13 PM   #42
Machinist's Avatar
My Photos: (3)
Only got this one Transcend 266x. So I RAID an ExtremeIV with the Transcend, and ended up with:
which was just a bit disappointing, as the Transcend by itself was:
Old 06-10-2007, 06:46 AM   #43
My Photos: (0)
Wow! Those results are amazing.
Old 06-11-2007, 04:23 PM   #44
My Photos: (0)
... I really suggest that instead of setting up RAID with the 120x, use the Transcend 266x CF card instead. The 266x is the best CF card I have used yet. The pricing is almost identical to the 120x, yet it has more than double the transfer rate. It is great for booting, it can format NTFS, create RAID, hibernate works, and it is faster than the Extreme IV. ...
well it seem's you've had great succes using transcends cards. I am currently testing Debian/Ubuntu on CF in my tabletpc (Toshiba M200) with two SanDisk Extreme IV 2GB Cards (for testing) in an Addonics Dual CF-IDE Adapter.
As it stands now i am unable to boot my laptop from the Extreme IV card in any possible configuration (only one, master, slave) as the computer hangs itself before loading grub. it's seems it tries to find the mbr but doesn't succeed (cpu fan kicks in and hdd light is constantly on)....
However i can boot from an an old SanDisk Ultra II 1GB card. it's even possible to boot Linux on the Extreme IV if grub is installed on the Ultra II, the Ultra II is inserted as Master and the Extreme IV as Slave. I know that even dual Extreme IV works, but then i have to boot from Network.
My conclusion (after reading this thread) that my tabletpc bios has some serious problems with "removable" type cfs.
- But are Ultra II cards fixed type? (And if no one knows : is there a way to obtain the info from the cf?)
- you mention a "fixed disk tool". Is this a tool to set a cf's typ to fixed? if so, where can one obtain this tool?
- about transcend's cards: is there a difference between the consumer 266x and the industrial "fixed" card regarrding type? i couldn't find speed ratings for the industrial cards, can you share how fast they are?
i know it's quite a bunch of questions but i'd be really nice if you could answer :-)
[Edit] i can boot from the Extreme IV cfs in another pc so it's definitively the bios...
bernstein is offline   Reply With Quote
Old 06-11-2007, 05:23 PM   #45
Machinist's Avatar
My Photos: (3)
So the tablet PC BIOS does identify the Extreme IV during POST? Have you tried copying everything from the UltraII to the ExtremeIV (including boot sectors)? Laptop BIOS are generally more difficult with these kinds of issues, they aren't really designed for accomodating CF. However, It is really odd if the CF card is detected, yet it doesn't boot. Not sure if this is related to removable/fixed compatibility. You selected IDE hard drive as opposed to CF in CF-IDE adapter in the Debian install?
to answer those questions,
- the UltraII is removable by default from manufacturer
- the fixed disk tool sets to either fixed or removable, but SanDisk will no longer give it to you unless you are an OEM (they will ask you a lot of information for confirmation).
- the industrial is detected as UDMA4, they say its 45x, it gets a little bit less than 20MB/s on hd tach. However, its great for booting and has 2m program/erase cycles.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Issues With Latest Update GizmoQ WhereIsMyGPS Online Tracking 1 06-23-2006 12:53 PM
Latest Maps Version?? studly_steve007 Map Monkey 25 11-24-2005 08:46 PM
Digistar-X V2 Instructions BLOWNZO6_pc General Hardware Discussion 0 09-15-2005 06:35 PM
Latest (for now) Linux kernel on Epia M10k rubicon Linux 4 05-26-2005 01:58 AM
DWW-7VGA: Just got it, but no instructions!? Almost a Ghost LCD/Display 8 05-12-2004 04:42 PM
Sponsored Links
Ad Management by RedTyger
