Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 04-16-2007, 03:18 PM   #16
BarryWoods's Avatar
Can you post a picture that's not quite that blurry?
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 04-17-2007, 01:01 PM   #17
scaff's Avatar
I scrapped the idea of using pcmcia card as it keeps freezing comp for some reason, so im gonna open a usb stick, i'll post some pics when its done.
Ok pics below damn its easier to scan it than take a photo
it's a TP-link TL-WN320G
What I want to do is fix a cable to it so I can plug in or remove the external antenna as required
scaff is offline   Reply With Quote
Old 04-18-2007, 01:09 AM   #18
BarryWoods's Avatar
Not going to happen with that one. The little ufl hirose connector isn't made for repeated insertions and removals. Even with the proper pigtail you migt need to disable the built in antenna. So unless you can pick up a second wifi adapter, I'd leave it alone.
Old 04-18-2007, 12:10 PM   #19
scaff's Avatar
Bugger, thanks.
Any suggestions on a usb adapter ?
Old 04-18-2007, 09:26 PM   #20
BarryWoods's Avatar
Bugger, thanks.
Not one that has both an internal and external antenna.
Old 04-19-2007, 04:06 PM   #21
scaff's Avatar
Ok, forget the disconecting part....lol.....can I connect a mast to this usb dongle ?
Old 04-19-2007, 09:24 PM   #22
BarryWoods's Avatar
Probably not without breaking it, but you can attach the dongle to the mast.
Old 04-20-2007, 01:15 PM   #23
scaff's Avatar
So now I got some gaffer tape & sticky back plastic how do I conquer the planet ?
Old 04-21-2007, 04:39 AM   #24
scaff's Avatar
My mast arrived this morning damn looks a little different to the picture, but anyways its a lo smaller than expected so disconecting it will no longer be an issue, just need to know where to solder to and wire type when you have 5 mins to spare Barry.
P.s. Thanks for your input so far !!
Old 01-23-2008, 10:22 AM   #25
I made my mast from scratch. Did you get anywhere with this? What I ended up doing at the end was using a really thin coax cable (like ear phone cable) to connect the dongle to the bottom of the mast below the decoupler. I used about 3 inches of a thin cable and it works really well. It's still working and I'm using it in the house currently. I got tired of my mirror bouncing around on the highway after about 6 months of having it mounted. If anyone ever tried to make one, find something thinner and lighter than 3/4" pvc to put your antenna inside of. I need to find some half inch fiberglass still.
nicksmurf111 is offline   Reply With Quote
USB Adapter + External Antenna = $70 bucks worth of Wifi Improvement?? pjloppez Wireless Communications 5 03-27-2007 05:56 AM
Accommodating my GPS and WiFi antenna portabuddy Fabrication 7 11-26-2006 02:25 PM
Cellular WIFI Antenna? scott011422 General Hardware Discussion 6 11-08-2006 03:55 PM
Recommend WiFi card and Antenna? DaveB Wireless Communications 8 01-24-2006 11:04 PM
Tall Wifi Antenna EBFoxbat Wireless Communications 18 11-22-2005 06:43 PM
