Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 05-28-2008, 11:18 PM   #31
Sorry for spamming this thread. But I have one more little teething problem.
When my CarLaptop now tries to standby, the Widcomm software is bringing up a message saying Bluetooth Headset is connected, click OK to disconnect? Is there a way to suppress this message and just standby automatically? If I hit OK, then it disconnects the audio gateway and on resume from suspend it does no connect automatically.
Hazza is offline   Reply With Quote
Old 05-29-2008, 06:14 PM   #32
i had that same problem, the only solution i found around it was to buy a targus bluetooth adapter
Scion CarPC
Injector is offline   Reply With Quote
Old 05-29-2008, 09:00 PM   #33
Thanks Injector. How does a targus adapter manage to get around that problem?
PS - I was having a play with the Laptop back in my car and it seems to stop the gateway connection and standby automatically (probably when I get out of the car and the phone goes out of range). So now I just need something to reconnect the gateway service when the phone comes back in range. I think there was a utility floating around for that so I will try that.
Old 05-29-2008, 09:21 PM   #34
i don't know how it does it, i initially bought it because my old unit had the crappiest signal ever.
Scion CarPC
Old 06-08-2008, 11:47 PM   #35
i would say because it's usb that windows suspends it during standby which is why it doesnt give the error
tony
tracker64 is offline   Reply With Quote
Old 06-18-2008, 05:26 AM   #36
Interesting you say that tracker64, but that is not the reason it works. It seems if standy in initiated by the lid switch it ignores the message box, if its via the power button or the suspend command in windows it wont budge until message box is clicked.
But anyway since I have moved to the widcomm stack I now have another problem. So during suspend/hibernate the USB ports (and hence the bluetooth dongle) are suspended/closed and it seems Widcomm does not reinitialise the dongle fast enough before Centrafuse starts, so Centrafuse errors and exists almost everytime I resume. This didn't happen with the Blue Soliel stack so it must be the extra time Widcomm needs to enable the bluetooth stick that is causing the problem. Any ideas as to how to fix this?
Old 07-29-2008, 03:05 PM   #37
I've been using the Widcomm stack with a trendnet USB dongle, so I've been using the headset/hands-free profile for a while
My problem is that the audio is too low. My amp gain is maxed, the volume controls are maxed on the PC and the phone, but its still pretty quiet. OK if I'm stationary, but barely audible over normal engine whine. Anyone have a solution to this? Would a new bluetooth dongle even fix this?
qbunnie is offline   Reply With Quote
Old 08-05-2008, 08:19 AM   #38
i have a new problem. i tested my bluetooth connection with my home pc and it worked. now i installed everything on my carpc and i tried to connect my phone to the carpc. everything went fine, until i made a call. after i dialed the car pc sends a message on te tft, "bluetooth connection failed" and my nokia phone switches to phone mode. any ideas?
i'm using the widcom software 4.1.....
Jayorich is offline   Reply With Quote
Old 08-07-2008, 10:47 AM   #39
i bought a belkin bluetooth stick and tried the widcom driver 4.1. but the belkin stick doesn't work on the 4.1 driver. hardware manager says: no driver found!!
only works with the 5.1 driver which was included. but the 5.1 driver disconnects my phone making a call. any ideas?
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 93 08-11-2008 09:40 PM
Wow, that's fast! tom2112 GPS 56 01-02-2007 12:28 AM
