Hi All,
It seems that someone is always coming along, wanting to do something that's already been done.
That in mind, for those who want carpc high-speed wireless connectivity, along with regular bluetooth connectivity (thru cell ph), here's my stroy:
Check my specs for my carpc; I bought a Netgear PCI wireless adapter for (too much) about $70 at Best Buy. It installed flawlessly in my carpc, and I sit in my driveway or downtown philly -using high speed connection.
But, I have some connectivity problems that I attribute to low signal strength. My carpc is in my cargo cmpt of station wagon; you guys w/carpc in trunk really must have signal problems...
So, I want to unscrew antenna from PCI card and install antenna extender cable, in order to mount antenna by a window or maybe even make my own magnetic mount for roof. Seemed simple enuf. Let's get some range, here!
Netgear has cables; I ordered one. It arrived, but gender was wrong: their cable has fem connectors on both ends. One end connects just fine to male on PCI card, other end won't connect to antenna 'cause they're both fem. Netgear has the WORST customer supp't I have encountered - they had no idea how to simply supply me with double-male connector to fix problem. Goofballs extrordinaire....
Turns out I need a cable with one end SMA fem, the other end RP-SMA male (RP = reverse polarity, see Wikipedia for good article.._)
Found the cable I need on
http://boomj.com:
10-feet-RP-SMA-To-SMA-Wireless-Cable-RPSMA10MF STARTECH COMPUTER PRODUCTS 10 feet - RP-SMA To SMA - Wireless Cable - Antenna Adapter Cable (RPSMA10MF) $10.77
Now, I am wating for it to come in mail. I actually ordered 2 of them - to also extend my home wireless unit antenna to better elevation for broader broadcast/receive range.
If this works, it should greatly improve connectivity.
Sorry for the long post, but some other new guys like me may be struggling with similar issues...
Happy carpc'ing!
