The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Thread Tools Display Modes
Old 03-14-2008, 10:20 PM   #16
stonestatue's Avatar
Vehicle: 93/Chevy/G20
My Photos: (0)
Quote: Originally Posted by Werewolfx View Post
Nice looking van, I'd go with a mirror mount bracket on the drivers side right behind the drivers door, as high up as you can get it on the metal. Go with a wilson 5000 trucker, use a long enough shaft to get the whole coil above the roofline, and drill a hole to bring your coax in through. Use RG8x. Second choice would be a hood/fender lip mount on the drivers side..either with an angle cut to keep it perfectly vertical, or use a flat mount infront of the hood screwed to the top of the core support. Bring the coax in through the firewall/doghouse. You could mount on the passenger side behind the rear side door, but thats not an optimal location for use on the highway..Whatever you do, ground all your doors to the body, and your "hood" to the body..the braid from some old coax works great..Also, ground the exhaust to the unibody with some braid strap at each end of the vehicle. Subtle mods like these can help make up a LITTLE bit of the performance loss for going with a form over function antenna system..I'm going to attempt to attatch a couple of the pics I tagged with potential mounting locations. The yellow circles mark potential mounting locations.
Is that just for the CB antenna, or the scanner and ham antennas as well? I already considered mounting an antenna opposite the radio, or maybe even next to it.
Self proclaimed environmentalist.
stonestatue is offline   Reply With Quote
Sponsored Links
Old 03-14-2008, 10:27 PM   #17
My Photos: (0)
A good place to look at some mounts is http://www.premiere-electronics.net/
There are several that would work well on your van..Stainless is best, aluminum works pretty well too though..Firestik SS-204A or Firestik SS-274a mounts from that website might be good choices..Firestik SS-64AGM GM Sport Mirror Bracket MIGHT be a good choice too, but pay attention to what size antenna you put on it.. Try to spring for the "monster stud"..thats a good strong stud for mounting vertually any antenna you want.
Stay away from the fiberglass antennas ESPECIALLY the ones under 4 ft long, anything under that is going to be a very poor performer. If you REALLY want to use a fiberglass antenna, get a francis..they're the best of the fiberglass antennas..you'll need an external SWR meter to tune your setup no matter what you get. The wilson 2000 trucker is also a good choice for an antenna for 10/11 meter use..
Hope all that makes enough sense to be of some help.
Werewolfx is offline   Reply With Quote
Old 03-14-2008, 10:29 PM   #18
My Photos: (0)
The ham depends on what band you're gonna be operating on..Those mounts are mainly for the CB(11 meter) and 10 meter ham antenna choices..Premiere has a couple of mobile scanner antennas that are roof mounted, they should work on a fiberglass roof and are fairly inconspicuous..
Old 03-14-2008, 10:32 PM   #19
My Photos: (0)
A good place for LOADS of information regarding CB and ham radios, antennas, amps, etc is www.cbradioforum.com if anyone is interested in learning more..
Old 03-19-2008, 01:00 AM   #20
My Photos: (0)
Where would you recommend I put the scanner antenna?
Sponsored Links
Old 03-19-2008, 01:10 AM   #21
My Photos: (0)
Also, I was looking into this:
http://cgi.ebay.com/NEW-MOBILE-SCANN...QQcmdZViewItem
It "adapts" the FM antenna already on most cars and allows it to be used with a scanner as well as the FM radio.
Old 03-19-2008, 03:07 PM   #22
My Photos: (0)
Nevermind the evaluation of the FM radio splicer. I checked out some reviews of it in an antenna forum, and they weren't favorable. I did find this link on the same forum though:
http://www.sti-co.com/antenna-produc...band-antennas/
This is a covert antenna designed to be used with police radios and FM radios.
http://www.sti-co.com/antenna-produc...ntenna-system/
This one is an antenna inside PVC pipe designed to be used as a luggage rack bar. Since I have a van, this would blend in perfectly.
Old 03-23-2008, 01:15 PM   #23
My Photos: (0)
Be careful about putting multiple antennas that close (ie inside that pvc tube). For one, horizontal polarization for most transmitter omnidirectional antennas is BAD. Two, you put two antennas that close together, and you can have disasterous results for both radios. It would be alright for the scanner alone, but why bother? A big white (or you could paint it i suppose) pvc pipe mounted on the roof of your van is going to be just as conspicuous as a 15" tall scanner antenna, and you still need the other mounts for your CB and ham radios. I'd just use a cheapo rubber FM antenna from an auto parts store for your FM radio. They mount on your front fender and work pretty well. You would need to drill a 1/2"-7/8" hole depending on the antenna.
Old 03-23-2008, 01:34 PM   #24
My Photos: (0)
Mount this antenna http://www.www.premiere-electronics.net/store/mor.html on the fiberglass roof for the scanner, and route the coax however you need (it only includes 12 feet, so keep that in mind). Scanners dont need a ground plane.
Old 03-23-2008, 01:40 PM   #25
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
Why not mount a metal plate (very thin) of 1 by 1 meter (or bigger) underneath the fiberglass roof and ground it to the body? Then mount your antennas on the roof (through the metal plate).
That will give the best performance and will look best...
Just an idea...
Good luck,
Joachim
JC-S60 is offline   Reply With Quote
Old 03-23-2008, 07:56 PM   #26
Mac Car Moderator
kandyman676's Avatar
Vehicle: 2008 Nissan Altima Sedan 3.5 SL
My Photos: (1)
Quote: Originally Posted by stonestatue View Post
Is that a good thing or a bad thing? Either way... I don't guess I mind the ability to scare people...
Nah, he would need to black out the windows, paint it white, and mark on some really fake company name. THEN be scared :-)
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
kandyman676 is offline   Reply With Quote
Old 03-24-2008, 07:17 PM   #27
My Photos: (10)
a good ham radio (10 meter) that can be converter to cb as well is an RCI 2970 or similar. The new cool thing is the UHF ham band. small antenna and lots of fm channels.
pir8radio is offline   Reply With Quote
Old 03-26-2008, 01:55 AM   #28
My Photos: (0)
The said metal plate will NOT be a good RF ground. It would perform similar to slapping a mag mount on a cookie sheet. Ideally, your vehicle would be one continuous piece of metal, no hinges or gaps or un-welded joints. Electrical ground and RF ground are not the same, thats why you need to ground your doors and hood to the body using ground straps, either pre-made or make your own from old RG-8 shield braid, not ordinary wire. You want to ground the exhaust at both ends to the vehicle chassis. Extra battery to body grounds are good for reducing alternator whine..Run the power and ground leads for your radio(s) straight to the battery, dont ground it to the body, and DEFINITELY don't use the lighter plug. Thats asking for interference, both rfi and tvi.
Sponsored Links
vB code is On
Trackbacks are Off
Antenna Mounting? BAC5point2 GPS 4 03-10-2008 01:18 PM
Radioshark to Car Antenna theminor Car Audio 50 10-04-2007 05:15 AM
Calling all XM experts... 2 antenna wires vs. 1 Nola111 Car Audio 8 02-17-2007 08:02 PM
Accommodating my GPS and WiFi antenna portabuddy Fabrication 7 11-26-2006 02:25 PM
Hacking a Holux GM-210 for external antenna (doesn't work) mpquattro GPS 9 04-22-2006 08:22 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
