The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Thread Tools Search this Thread Display Modes
Old 04-01-2008, 09:25 PM   #1
jbradshw's CarPC Specs
Vehicle: 1999-5 Nissan Pathfinder XE
My Photos: (0)
Mini PCI-e wireless card w/ external antenna support
My motherboard has a mini PCI-e slot and I figured why not use it for a wireless card. However, it also needs to support an external antenna.
Does one exist???
I've searched the net and forums for a couple of days and haven't found one - or at least one that actually says it supports one. I've tried looking at a few pics but I can't make out if any of them have a connector for it.
jbradshw is offline   Reply With Quote
Sponsored Links
Old 04-01-2008, 09:54 PM   #2
NotYou's CarPC Specs
Vehicle: 99 Jeep Wrangler / 07 Grand Cherokee
My Photos: (10)
All mini-pci wireless cards will have one (or two) connectors for an external antenna. They are really, really tiny connectors that are circular with a dot (wire) in the middle.
The connector type on the card will be a U.FL connector, also [less commonly] known as I-PEX. Most wifi antenna's will have a RP-SMA or TNC connector. Therefor, you will need three things:
- Mini-pci wireless card
- u.fl to RP-SMA adapter pigtail (or u.fl to TNC adapter pigtail)
- Wifi Antenna with either RP-SMA or TNC connector
Unfortunatly, the adapter pigtails are more then what you would expect to pay for them. They run about $10-13, plus shipping. There's lots of places online to find them, just search for "u.fl pigtail adapter"
There are lots of mini-pci wireless cards, so shop around to find one with the networking type (a, b, n, or combo of these) and output transmit/receiver power that you want. Higher output power means you'll have a better chance of a stable connector over a farther distance.
If you really need some examples, let me know.. but there's are LOTS out there -- especially if you look around at laptop supply places.
NotYou is offline   Reply With Quote
Old 04-02-2008, 12:22 AM   #3
My Photos: (0)
Not to split hairs and I'm assuming the answer is yes, but does this also apply to mini PCI-e wireless cards?
Also I would be using this with the combo GPS/Wifi antenna sold in the mp3store that has the FME connector so I would definitely need at least 1 adapter for it.
Old 04-02-2008, 01:32 AM   #4
Area3's Avatar
Vehicle: 2005 Pontiac Grand Am
My Photos: (0)
Don't know if this is what You are wanting But This Card is a good one...
http://store1.sonnettech.com/product...roducts_id=222
Microsoft Is a Evil Empire that has corrupted a generation!
Thanks - Eric Scott
Area 3 Productions
www.myspace.com/area3
Area3 is offline   Reply With Quote
Old 04-02-2008, 09:59 AM   #5
My Photos: (0)
Yeah that's a great example of one - I can see the external antenna connectors on it. Thanks! However that roof antenna only has 1 connector so getting an n-card won't work too well as I don't plan on running more antennas for the other connectors heh. I just need to find a good b/g one.
But yeah I can clearly see those connectors now so as long as the picture is clear enough that shows that, I should be able to pick one out now. That's sorta been the issue as well, some of the products I've seen out there, the closeup pic is fuzzy so you can't tell if it supports external antennas.
Old 04-02-2008, 12:13 PM   #6
Area3's Avatar
My Photos: (0)
Just Read a Little and You might Find Your Answer
Quote:
Backward compatible with 802.11a, 802.11b, and 802.11g devices
Thanks - Eric Scott
Area 3 Productions
Old 04-02-2008, 12:52 PM   #7
My Photos: (0)
Yeah I know that, but its a bit pricey for what I need - I would rather just save money and buy a g card.
Old 04-02-2008, 01:19 PM   #8
My Photos: (10)
Yes, the same would apply for mini PCIe wireless cards.. Make sure you get the right one, though, as I've seen very very few mini PCIe slots except for custom solutions.
If you use the mp3car store antenna, you'll not only need an adapter pigtail, but an extension cable as well. Generally, pigtails are only about 6 to 12 inches. And with the u.fl connections especially, you will want a short pigtail with its opposite end firmly mounted. The u.fl connectors have a strong hold, but to much tension/stress and the pigrail will rip right off. Just something to keep in mind =)
Old 04-02-2008, 01:40 PM   #9
My Photos: (0)
Yeah I'm using the MSI Fuzzy RS690T motherboard which has one - this is my main reason for the original post. The connector is so tiny I didn't even really notice it at first!
Old 04-04-2008, 01:16 PM   #10
BarryWoods's Avatar
Vehicle: 2005 Honda Element
My Photos: (2)
I have four of these in a computer I built, http://www.netgate.com/product_info....roducts_id=348
They work pretty good, with both windows and linux support. Fairly inexpensive tool
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Sponsored Links
Old 04-04-2008, 03:19 PM   #11
My Photos: (10)
While a good recommendation, the OP was looking for a mini pci express card. =)
Just clarifying for anyone using this topic for reference
Old 04-05-2008, 09:23 AM   #12
BarryWoods's Avatar
My Photos: (2)
Whoops!! Missed the -e.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
How to extend antenna from your wifi PCI card? Tred Wireless Communications 12 06-24-2005 01:38 AM
FS:BB160 Wireless PC Card $5 each kderedwolf Classified Archive 10 05-03-2005 03:38 AM
I have an Epia800 with room for one PCI card, what should i get? Dominik General Hardware Discussion 12 10-11-2004 11:13 PM
need PCI nvidia video card with Conexant TV chip Onyx General Hardware Discussion 2 11-12-2003 03:14 PM
Looking for a 802.11b PCI card with external Antenna port e_fractal Input Devices 15 08-11-2003 12:41 PM
Sponsored Links
Ad Management by RedTyger
