Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 06-19-2008, 01:31 AM   #1
Connect my WIImote to pc - PROBLEM!
Hello, Last night I'v spend al the night on trying to connect my wiimote to the pc. I bought a normal bluetooth stick (12 euro's). I installed the drivers (widcom) and inserted the bluetooth stick. I'v read that you should skip pairing etc, so id did. After doing everyting by this tuturial : http://wiibrew.org/w/index.php?title=Wiimote_Tutorial
After that, the wiimote was flashing non stop. (So it should be connected, paired) Then i started GlovePIE, and ran the testwiimotescript, (wiimote still flashing) Tuturials say that the "debug" thing, should change in numbers as you wave your wiimote. Well, i can swing my wiimote as hard as i can, but the debug numbers don't change.
Also the mouse script doesnt work, only my cursor goes slowly to the corner of the screen.
I'v also tried Bluesoleil.. But it doesnt recocnise my bluetooth adapter, it just says: Place a bluetooth device.
I have no more ideas.. So if someone could help me???
Thank yOu!!
TwiisT is offline   Reply With Quote
Old 06-20-2008, 11:44 AM   #2
I tried connecting my Wiimote to my pc through bt once. I used a belkin dongle though. Didn't have any problems. I slightly remember reading once, though, that only some dongles seem to work with the Wiimotes. If you have access to a different one, it might be worth a try.
kibble is offline   Reply With Quote
Advice Please - PC Design Problem pete_dj General Hardware Discussion 6 03-14-2008 02:47 PM
Car PC EZ 2.4 SDC/Inverter Controller - NOW Avail! hd54321 Power Supplies 1 02-24-2005 12:42 PM
