Quote: Originally Posted by
Rick99TAWS6
I'm not sure on the availability of hardware/software for the Nissan, but I have HPTuners installed on my CarPC and am able to log/tune the EMS(ECU) for a number of GM and Ford cars. Can do real time tuning to a number of the tables with a custom OS on the cars EMS(ECU)
Might look around some of the Nissan forums to see if there is something similar available for them
Good luck
Already have the software. The car is running an aftermarket stand alone EMS (Autronic SM-4). We have all the tuning software and it's on the PC. Just trying to see if you can remotely access and tune from abroad if necessary? I will be on the Bonneville Salt Flats...my tuner will be in VA.
I know it's been done at racetracks on Formula cars but they need an exteremly fast response so they have private connections through a different type of network (don't know what it's called)
To be honest I don't need that... a delay will be fine as long as it's not too much. The overall tune is done...the minor tweaking from logging and viewing doesn't necessitate instant responses to EMS parameters.
Just trying to get it set-up.
