Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 01-11-2009, 12:06 PM   #1
platinumsteel is an unknown quantity at this point
Need to figure out the correct adapters/connectors for these devices
Hi I am going to purchase these 3 devices as soon as I get confirmation on the correct connectors I need to get for them so I can order the length of cables I need from fab-corp.The first device I need to know what connectors it sports at the rear is the Linksys-Cisco WRT54GL Wireless-G Broadband Router can be found here
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
I would like to remove the external antenna it has and connect a short pigtail with correct Coax cable connectors/adapters from it into this device >>>>>Hawking HiGain Signal Booster version 2 - HSB2 which can be found here
http://www.amazon.com/Hawking-HiGain...1688355&sr=8-1
And at the other side of this hawkings device I would like to remove there little antenna and use a larger omni-directional antenna.The omni antenna I am planning to use is a 2.4 Ghz Omni-directional 15 dbi Antenna from wi-fi link which can be found here http://www.amazon.com/exec/obidos/tg...GVWN2&v=glance
I would like to connect these 3 devices to each other....So again all I need is to know is which adapters and connector types,please specify male and female that I would need to get to connect them successfully.....I would like it in the order starting with the linksys router all the way tru up to the Large Omni-Antenna which I think has a N female connector on it..if I am right....This information is critical to my first wireless network and would like it to be presented in the best simplest form...thank you.
platinumsteel is offline   Reply With Quote
Garmin Mobile PC - No On-ScreenKeyboard???? swwesq Garmin Mobile PC 62 11-19-2009 03:36 AM
