Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 04-22-2004, 05:44 AM   #1
mbkowns's Avatar
mbkowns is on a distinguished road
Lightbulb USB 2.0 Linksys WUSB54G - Antenna Hack
I bought this a little while ago and I want to soldier a new antenna on to the device. I like this method because its better to extend the USB cable than to extend the pigtail in terms of network speed. Anyway I am looking to strip the tip off and install a new pigtail tip but i am wondering what a good place to pick some up would be and also what type of solder should i use?
The blue plastic(antenna if you want to call it that lol) has the rest of the wire
I want to make the pigtail connecter stick out like this one. The blue plastic above has a small hole (which i can make bigger if need be) so I can do something like below.
Since I included some pictures could someone please point me in the right direction.. thanks
2005 Ford Mustang GT <- - - UPDATED PICTURES
2003 KAWASAKI Z1000 - CUSTOM MODZ
MBK (AIM = IllMBKllI)
mbkowns is offline   Reply With Quote
Advertisement Sponsored links
Old 04-22-2004, 06:24 AM   #2
bone-saw is on a distinguished road
Hello,
this is what you need:
http://www.carnetix.com/WUSB11/WUSB11%20V2.8.html
Markus
bone-saw is offline   Reply With Quote
Old 04-22-2004, 06:43 AM   #3
mbkowns's Avatar
Thats great! where do i get that type of connector ?
Old 04-22-2004, 07:14 AM   #4
MikeH is on a distinguished road
Kyle,
I bought it from DigiKey. The part number is J603-ND and costs $5.53 each (DigiKey link here) )
I would caution you that the circuit traces are very small. You need good soldering skills and a very small sodering iron tip. I ended up dropping my board and breaking this connector off.
Someone suggested a better approach. Use the Orinoco USB client. It comes with this MMX connector already attached so that you can add an external antenna.
Good Luck
MikeH
MikeH is offline   Reply With Quote
Old 04-22-2004, 07:24 AM   #5
mbkowns's Avatar
Great My question is answered ! thanks I was hearing silver based solder was the best to use for wireless antennas do you agree or what do you think
also my soldering area is more in the middle of the board so it won't stick out which is good and bad.
1 good won't break off
2 bad have to take it apart to get to the adapter but i am using a pig tail to that so i will be good
Old 04-23-2004, 04:38 AM   #6
NovaKane is on a distinguished road
What is that tiny connector called? so i know what type of connection to look for when I buy the pigtail antenna. I took my lan card apart, and I could not figure out what that was, so i was just going to solder some coax to that connector. How good would that work?
NovaKane is offline   Reply With Quote
Old 04-23-2004, 05:53 AM   #7
gubon13's Avatar
gubon13 is on a distinguished road
i believe that he used an MMCX connector.
as for soldering in coax straight to the connector - it depends on the coax. you should use RG58 coax if you're gonna do that. definitely NOT RG59, and probably RG6 would also be a bad idea. as I understand it, they don't provide the correct shielding and impedence requirements. the signal wave wouldn't match up by the time it hit the antenna and your reception would be for $#!t...
"Is Wayne Brady gonna have to choke a b@$#*??!!"
gubon13 is offline   Reply With Quote
Old 04-24-2004, 12:17 AM   #8
oh, cool, thanks. I have been wondering about that for a while.
Old 04-25-2004, 04:18 PM   #9
Cryogen97 is on a distinguished road
I found this site a bit ago. you can order any kind of connector you want
http://www.fab-corp.com/index.htm
AutoPC: M10k, WinXP, gps, wifi, 80GB HD, dvd-RW. SB mp3+
MediaEngine front end, map monkey, netstumbler.
gps mouse is on the fritz.....stupid technology
Cryogen97 is offline   Reply With Quote
Old 04-25-2004, 04:31 PM   #10
mbkowns's Avatar
Quote: Originally Posted by MikeH
Kyle,
Good Luck
I bought one from them couple days ago it should be here anyday now
thanks
Old 04-29-2004, 06:43 AM   #11
mbkowns's Avatar
Is there a certain type of solder I should use still unanswered my part came today btw
Old 04-29-2004, 06:14 PM   #12
gubon13's Avatar
I try to stick to electronic silver solder. It makes clean connections and the conductivity is very high.
Old 05-05-2004, 02:11 AM   #13
john1701's Avatar
john1701 is on a distinguished road
another site for pieces and parts to check out.
www.hyperlinktech.com
This is where I got my pigtail and cables.
CAR:2001 Ford Crown Victoria
PC: Acer EEE 900HA with Vista with CF 2.0.
Memory:1G
Drives:160gig
WI-FI:Cingular
GPS:Garmin
Screen:Xenarc 700TSV
The Florida Meets Thread
john1701 is offline   Reply With Quote
Old 06-03-2004, 06:15 PM   #14
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
Quote:
Hello,
Markus
linky no worky
antimatter is offline   Reply With Quote
Old 06-03-2004, 08:52 PM   #15
Kermee is on a distinguished road
Quote: Originally Posted by antimatter
linky no worky
Looks like between 04/22/04 and today, CarNetix updated their website.
Kermee is offline   Reply With Quote
Wireless and USB 2.0 cards Defiler Classified Archive 0 04-07-2004 09:59 AM
USB 2.0 vs. Firewire... keeping a low profile gregulator General Hardware Discussion 9 12-11-2003 08:08 AM
USB 2.0 drivers without SP1 WINXP videodok Software & Software Development 11 12-11-2003 08:04 AM
Storix External USB 2.0 DVD Review VWTronics Input Devices 8 09-27-2003 07:20 PM
Can I use a USB 2.0 harddrive enclosure with a USB 1.1 compliant motherboard? nxt125 General Hardware Discussion 7 09-01-2002 10:25 AM
