The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Thread Tools Display Modes
Old 06-29-2004, 01:17 PM   #1
Vehicle: 1995 Audi 90
My Photos: (0)
Any way to use your car's antenna as a WiFi antenna?
I think it would be a nice integration since those of us who ditched the headunits have a useless antenna. I want to put it to use!
NoNonsense is offline   Reply With Quote
Sponsored Links
Old 06-29-2004, 01:32 PM   #2
Vehicle: 2002/Chevy/Camaro
My Photos: (0)
You read my mind
Hexerei is offline   Reply With Quote
Old 06-29-2004, 11:02 PM   #3
The Grinch's Avatar
Vehicle: 98 Grand Prix GTP
My Photos: (0)
Antenna's are made to specific lengths to match the radio frequencies that you are trying to receive or transmit on. FM radio is in the lower half of the MHz band, while WiFi is well into the GHz band. Then there's other stuff to consider like antenna resistance and impedance. If you tried to simply rig up a WiFi device to your car antenna, you would risk toasting it's transmitter. Even if you figured out how to safely hook it up, the antenna would give you very poor reception for the application.
The only alternative you have is to replace your car antenna with one that is made for WiFi. You can buy them (they are quite short by the way), and you would have to fabricate a way of mounting it as the connectors are totally different.
The Grinch is offline   Reply With Quote
Old 06-29-2004, 11:05 PM   #4
Sway's Avatar
My Photos: (0)
Thumbs up
even if it does not work it was a great idea, because i never use the radio.
Sway is offline   Reply With Quote
Old 06-30-2004, 02:39 AM   #5
cheerio's Avatar
Vehicle: 1998/Saturn/SL1
My Photos: (0)
you could always drill a hole and look like a police car ;x
cheerio is offline   Reply With Quote
Old 06-30-2004, 10:24 AM   #6
My Photos: (0)
That's a negative, Sir! hehe
I just thought that attaching the WiFi antenna to any other long piece of metal (even a metal hanger) would increase the reception, so why not attach it to the car's antenna....it doesn't need to be amplified, so how would it toast the transmitter?
Sorry, i don't understand all this WiFi stuff yet...
Old 06-30-2004, 10:25 AM   #7
My Photos: (0)
It's all about the adapters!
Old 06-30-2004, 10:37 AM   #8
MikeH's Avatar
Vehicle: 2007 Acura RDX
My Photos: (0)
The output transmitter section of a WiFi client is "tuned" to match a certain impedence (like a frequency-dependent resistor). It looks like a perfect "match" (ie a 50ohm resistor) only at the proper frequency (around 2GHz). Your car antenna is "matched" (looks like 300 omhs) at 88-108MHz and can't really be tuned to look like 50ohms at 2GHz for your WiFi transmitter. Some WiFi transmitters (output power amplifiers) will fry themselves if they try to power an antenna that's not well "matched". Your car antenna COULD look like zero ohms at 2Ghz....That would toast you WiFi PA....
MikeH
CarNetix
Helpful info at http://www.carnetix.com
C134, M10000, 40GHDD, XM-PCR, CarNetix P2140, FP
MikeH is offline   Reply With Quote
Old 06-30-2004, 11:47 AM   #9
The Grinch's Avatar
My Photos: (0)
The ol' coat hanger antenna scenario works (sort of) because a car stereo only receives radio waves. But if use it for transmitting/broadcasting, it's a whole new ball of wax. WiFi fits right into that catagory (send/receives). When you transmit, you are actually sending power to the antenna. If the antenna is not properly matched to the transmitter, it will cook itself.
Old 07-01-2004, 07:03 AM   #10
My Photos: (0)
I understand now....
so, had anyone developed a WiFi antenna that can be lowered and raised with a button? I'd like to try to utilize that antenna of mine or replace it with something else that would work.
Sponsored Links
Old 07-01-2004, 08:59 AM   #11
My Photos: (0)
heres my idea.
what about using my cordless phone's antenna? it's longer than the one on my wifi card and same frequency 2.4ghz.
xtra is offline   Reply With Quote
Old 07-01-2004, 09:34 AM   #12
NorthGaVigor's Avatar
Vehicle: 1997 Jeep TJ
My Photos: (0)
Used a pringles can as an external antenna on my dlink in my laptop and used a coffee can @ my friends house and was able to get a link from his router.
1 mile away! I have the directions if anyones wants them!
www.natchezss.com
God Bless America and Our President!
NorthGaVigor is offline   Reply With Quote
Old 07-01-2004, 01:18 PM   #13
My Photos: (0)
1 mile away!
That's freakin' amazing...here in NYC, that would essentially ensure a constant signal using netstumbler! however, there is no way in hell that i am going to mount a coffee can to my roof or trunk!! hahaha
Old 07-01-2004, 01:25 PM   #14
I see dead kittens
Quattro's Avatar
Vehicle: 1998 Audi A4
My Photos: (0)
I've seen that done before on the show the screen savers. They used a coffee can to increase thier wifi signal, it worked really good.
The cordless phone antenna would be much better looking in a car, if it works.
Installed
Asus A7N8X-VM - AMD Mobile Athlon 2400
512 Ram - 60GB HD - Opus 150w
Lilliput 7" - Rikaline 6010
[00000000000001100010-] 98% Completed
Check Out My Install!!!
Quattro is offline   Reply With Quote
Old 07-01-2004, 01:30 PM   #15
MikeH's Avatar
My Photos: (0)
Actually, some of the multi-band cellphone antennas have a ~2Ghz band. they also come in car-mountable versions. This might make a much better looking design.
MikeH
CarNetix
Sponsored Links
vB code is On
Trackbacks are Off
Will this wifi card work with antenna? AutoInnovations General MP3Car Discussion 8 02-12-2004 06:49 PM
Help finding a 54g PCI wifi card for Procase'd carputer NJay General Hardware Discussion 19 01-21-2004 03:04 AM
Anyway to calculate wifi antenna range? bizahh General Hardware Discussion 9 01-01-2004 02:59 PM
WiFi - antenna conector question Rudical Input Devices 2 10-22-2003 06:05 PM
Very Small 4 dB WIFI car mount antenna...will it work? AcuraTLFan General Hardware Discussion 0 02-06-2003 11:49 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
