01-08-2005, 10:37 PM
#16
Quote: Originally Posted by nFiniteTuning
Ok, what would be the best Adaptor? I'm still not hired with this Wireless Internet company yet, but for now I'm using a Linksys Wireless-G USB Adaptor. from one end of my house to another, I'm only getting 1mbps.
You guys said the antena must be mounted outside, well ok....Which Adaptor, prefibly USB, can we use, and hook up an antena to it, so having the adaptor inside wont hurt the signal...
nFiniteTuning, I recommend you a book called Wi-Fi Toys (I own it) It explains the basics and it has different projects, even how to extend your coverage area.
http://www.amazon.com/exec/obidos/tg...31960?v=glance
http://wifi-toys.com/
Ford Expedition XLT 2003
My Work Log
Progress 40%
02-23-2005, 05:40 AM
#17
Hey i am little far off owning a car yet, but i thought i might as well learn now because i am into this stuff...
what would be the most popular wardriving card? and antenna?
thanks
02-27-2005, 08:17 PM
#18
_
also, since this doesn't seem to come up much, but I think many people would find it interesting:
how to set-up a connection so that you can controll your carPC with your PDA wirelessly....anyone?
05-09-2005, 02:02 PM
#19
Quote: Originally Posted by jrtf83
Seems we need a WiFi FAQ, I might not be the one to start this but here goes. Firstly:
What's the difference between the different protocalls a/b/g and such?
(From: http://www.webopedia.com/TERM/8/802_11.html)
Where can I mount my antenna?
You should really mount your antenna outside your car, metal will block the high frequency WiFi signal pretty easily. Glass will interfere some but not as much as metal.
Can I use my car's AM/FM antenna to recieve wireless?
No, as antennas must be tuned to the proper length depending on the frequency of the signal. Radio signals are a much lower frequency than WiFi and as such require a much longer antenna. Also, WiFi antennas send as well as recieve so they must be powered, powering an AM/FM antenna with your wireless card can fry things so be careful!
What else?
What's the best antenna?
What's the best wireless card?
WTF is a "protocall" ? And why should we listen to an analphabet like you ?
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
05-23-2005, 03:38 PM
#20
sjees ... give the man a break ... i think this thread is a good idea.
The only thing i miss is a bit on adapters
- which ones are good
- how to connect USB/PCI/PCMCIA ???
- how to connect an antenna to a USB dongle
anybody got some links ?
'02 Toyota Celica TS
Carputer progress : [####------]
Currently working on : finding spare time
Parts : pico-ITX, 160Gb SATA, 1.0Gb Ram
Parts needed: USB wifi dongle, USB BT dongle, external storage
06-03-2005, 08:16 AM
#21
What is your problem? Are you a  ? This is a fantastic thread. There aren't nearly enough sticky, good information threads on this site and you go and attack the guy that makes this one? You have no place here.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
07-06-2005, 01:48 PM
#22
I have been involved in several wifi start-up companies looking at providing "last mile" solutions via wifi, as well as the future of "mesh networking" via inexpensive boxes saturating an area with a wifi cloud (imagine a wireless AP at every intersection of a city, powered by fiber... Cary, NC is doing this).
From our research, Orinoco is above and beyond the best equipment for the cost, which over the past couple of years has become extremely cheap (as with all computer hardware I guess...).
Some other things:
- amazing things can be accomplished with proper antenna choice and installation. There have been people who have blasted a wifi signal over many many miles from an off-the-shelf linksys 802.11b router with special antennas (Which are also comparitively inexpensive [<$300]).
- Trees pretty much take a wifi signal and beat it like a red-headed step child. Very few things (barring you know, lead) obstruct wifi as much as trees. The leaves act like a sponge, soaking up the signal.
- Stock (and really many aftermarket) omni-directional/yagi wifi antennas send out a signal much like a donut. The very center has a hole, although small, where signal reception can cause problems. They also send signals out horizontally MUCH better than vertically. If you are looking for vertical propogation, turn the AP on it's side (or adjust the antennas to simulate the same effect)
- Sveasoft makes some awesome aftermarket firmware for most of the linksys routers. Check it out, it can be downloaded for free from many sites, although supposedly you have to pay for it, although it's under GPL, so there is a big fight over the paying issue (search slashdot)
More to come later if I think of more
07-06-2005, 09:51 PM
#23
What are the possibilities of using a fin like antenna similar to those seen on newer style BMWs, etc. as an omnidirectional antenna for WIFI? I do not know how those antennas work but would it be possible to make it work with WIFI or retrofit one of them with a WIFI antenna inside so that you can have the look of the fin antenna?
07-06-2005, 11:28 PM
#24
Admin. Don't bug or I'll byte.
Unlikely. The sharkfin antennas are usually a GPS receiver antenna. Different frequency from WiFi. Plus, it's a receiving antenna rather than a transmitter.
07-08-2005, 06:18 AM
#25
07-31-2005, 12:17 AM
#26
Dual Band Patch Antenna
I made 2 band and 3 band Patch Antenna few years ago for AO-40 Satellite. AMSATID members use 6 feet porabolic dish to operate at AO40 with this Patch Antenna as the radiator, installed at the focus of the dish.
The 2 band type maybe applicable for WiFi and GPS.
Its 1.2GHz + 2.4GHz Dual Band Patch Antenna.
See attached pictures.
08-02-2005, 05:04 PM
#27
Quote: Originally Posted by Skipjacks
this whole article can be summed up in one little exerpt - Police say Smith admitted using the Wi-Fi signal from the home of Richard Dinon. Why admit it? How would they prove it otherwise?
Please help.
08-02-2005, 05:29 PM
#28
Check the log of the router to see what has accessed it. You can identify the card used down to the make and batch number from this information.
Although people who don't know how to encrypt wifi are really unlikely to know how to check how many different cards are accessing it.
08-03-2005, 08:15 AM
#29
I don't wan't to hijack this thread, but Just because his card accessed it, doesn't mean he'd be found guilty of commiting a crime, you know what I mean?. He could give a whole host of excuses right down to "no idea how it happend". I've noticed they haven't seemed to have prosecuted anyone for song piracy yet that hasn't admitted doing the deed ...
Please help.
08-03-2005, 09:08 AM
#30
Firstly, you don't know that this guy was not some type of techie who a jury or judge could not easily believe when he said he didn't know it was happening.
Secondly, if I turned up at your house, seized your hard drive and discovered 20 gigs of music for which you could not produce CD's what would your excuse be ? Afterwhich you were offered an out of court or civil court fine for admitting it, or being potentially taken to trial and slapped in Jail for a criminal offence, which would you choose ?
| Thread Tools |
| Display Modes |
Linear Mode
