02-23-2006, 07:33 PM
#91
Vehicle: 1992 Eagle Talon TSI AWD
 as i pull over to post this, I wont use this so much so this is good for now. This does only use minuts right?
02-23-2006, 09:19 PM
#92
haha. I'm not sure what your setup uses. I remember threads going back a ways when EVDO first came out that stated you had to be on a grandgathered NAMOU plan to use minutes. Otherwise they were charging data rates. I went straight to VCAST, which is $15/mo unlimited, so I'm not sure what the results will be with your setup. Better keep the usage light this month just in case
02-24-2006, 06:04 PM
#93
Well I just did the file sharing hack ( change e2 to e3 on seam 2742) and it worked great however now my phone wont act as a modem anymore. Also I installed mpt on my carpc. Any ideas on what the problem with the dialup is?
02-24-2006, 06:27 PM
#94
Vehicle: 1993 Toyota 4Runner SR5
@selmerguy: seems like you use a motorola, try ##342587 (##DIALUP). The phone should say: "Dial up networking enabled".
EPIA Nehemiah M10k, M1-ATX, 20GB 4200 RPM 2.5", 256MB RAM, Win XP Home, Gyration RF Keyboard & Mouse, Zoltrix Nightingale Optical 4.1 PCI Sound Card, Lilliput 619GL-70NP, XM-PCR w/ optical upgrade, Garmin GPS-25LVS, Microsoft MN-710 USB Wireless NIC
02-24-2006, 06:30 PM
#95
I tried that allready. No go
02-24-2006, 06:36 PM
#96
If I remember correctly inetron.com has a list of flags you can enable/disable and dial up networking is one if them. Unfortunately, inetron's website is currently down. Perhaps you could check out that website later?
02-24-2006, 07:46 PM
#97
I got it to work again. I messed with the connection settings and it worked again. Man this phone hacking is tedious, thanks howard forums.
03-19-2006, 03:01 PM
#98
Hate to bring up an old post.. I see that this can be done on a E-815 phone. I was wondering if this still works? And is the ######## Ect. Info still what you need to get this thing going? Thanks
03-19-2006, 05:10 PM
#99
Mine still works, You dont need to hack your phone. Just enable dialup by dialing ##dialup on your phone. Then set it up through bluetooth or cdma.
03-19-2006, 05:33 PM
#100
Vehicle: 2000 Nissan Xterra
well, just to let everyone know, if it hasn't been mentioned yet
Verizon changed their plans recently, about a month ago, and unless you have the $60/month data plan, using your EVDO phone as a modem will either
a. give you "invalid username/password" error (i think thats the error) when you try dialing up
or, if that doesn't get you
b. you will be charged per kilobyte, which...adds up in a heartbeat.
so unless you have the $60/month plan, i wouldn't recommend using your phone as a modem anymore,
my e815 worked as a modem for the longest time, before i even had my carputer setup, and i didn't even need it, but now, it gives me the error when dialing in.
03-19-2006, 06:19 PM
#101
It just worked for me no questions asked! hooked right up! Now what about the data plan?
04-02-2006, 10:38 PM
#102
Razr EVDO Crippling
Hi guys, my question is this:
I'm thinking about upgrading from my 1XRTT capable vx6000 to a brand new EV-DO capable Razr from Verizon.
My only concern is that I don't want to get charged for EVDO service (unless I can get it with a $15 Vcast plan, which there's no definitive answer on) so I'd probably like to just continue using my 1XRTT plan that uses my minutes.
My question is: Can I disable EVDO on the Razr so I can continue using 1XRTT using my minutes as I do now? I don't want to get into an EVDO area and suddenly be forced to go broadband at like ridiculous rates. Thoughts?
Also, is it posible to keep my old phone active so I can use it as a modem? basically ties to my sme plan? just a thought cause then I could leave it in the car as a permanent modem, thanks guys
04-03-2006, 12:13 AM
#103
Update
Whew, ok.. I jut read about 1,000 pages of forums over at Howardforums and I think I found my answers. Yes, you can indeed disable evdo on the Razr.. as far as adding the second phone, not as much info, but I thin perhaps adding it as a second line for $10 a month would work? still looking
04-09-2006, 06:00 PM
#104
hey does anyone know if it works with the e815 through a motorola data cable and not futuredial cable? thanks
04-09-2006, 09:03 PM
#105
I used mine through the data cable once. I was faster then bluetooth. But not as cool.
| Thread Tools |
| Display Modes |
Linear Mode
