The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Thread Tools Display Modes
Old 01-26-2005, 08:54 AM   #1
My Photos: (0)
Two sector antennas on the sides of my truck?
Ok, now that I have the 1 watt amp, and it's impressive, I really want to figure out the antenna array for my truck.
I was gonna run an OMNI, but I can't get anything better than a 7 dB omni, without going to a big 16" fiberglass rod. And I don't think I want that on the roof of my lifted suburban, a little too obvious.
So what I want to do is mount 2 sector antennas into the rear corners, Build some fiberglass panels to hide them, I'm pretty sure I can make it relatively decent looking, and nobody will know what they are. This way, I could use two 20 dB antennas that have 180 degree patterns, one on each side.
I'll use a signal combiner from hyperlink, says its only got a .4 dB loss.
Problem is, I can't find sector antennas for less than $180-300$ each. And I don't know why! Anyone know of a better idea or source? ( hyperlink and fab-corp are both expensive) I could run the flat patch antennas, but they seem to have very narrow beam patterns and that would hurt the purpose of the rig.
OR
Does anyone know how well a pair of omni antennas would work? Would the signals interfere? Do they have to be perfectly vertical to work good?
I want a solution that I can hide. If it comes down to a 40" whip antenna on each side of my truck, so be it. But I'd like to bury the antennas into a panel of some kind.
Basically, if anyone has any ideas, please post them here.
Thanks!
Dave
big_cali_dave is offline   Reply With Quote
Sponsored Links
Old 02-23-2005, 11:27 AM   #2
tom2112's Avatar
Vehicle: 2003 Mitsubishi Eclipse GT, 5spd
My Photos: (0)
Dave,
I don't know if the application is similar enough, but I know that the VHF antennas I used in the army (several foot long fiberglass poles) worked the same laying down as standing up. We used to bend them over the top of the vehicle so we didn't snag tree limbs and low wires and such.
So just use the 16" fiber pole you mentioned and lay it down. It should be real easy to hide laying down.
Later,
Tom
So far:
M10000 Nehemiah, 1Gb RAM, Opus 90w PS, Buffalo Tech WLI2-USB2-G54, 160 Gb HDD, GlobalSat BU-353 GPS, iGuidance, Zippy EL-610, Panasonic CW8123B Slim Slot CDRW/DVD, 10" Lilliput, Sony XA-300, Sony CDX-MP30 Head, OBD-II
tom2112 is offline   Reply With Quote
Old 02-26-2005, 05:52 AM   #3
My Photos: (0)
VHF. 30 mhz to 300 mhz has a HUGE wavelength. The antenna radiation patterns for those signals tend to be big spheres from the antenna. The radiation from a 2.4 ghz antenna is usually very flat, with the signal being say, 12 dB horizontal 360 degrees and 12 dB vertical at like, 15 degrees. If I lay a whip antenna on its side, I will end up with a very strong signal that only radiates directly out the sides of the truck. I figure I will need at least 90 degrees of coverage on the sides, and the full 180 would be preferred. From what I've seen, the sector antennas with big coverage ( >90 ) are very expensive and big...
Thanks for the bump though, I still need ideas for this.
Old 07-17-2005, 10:28 AM   #4
BADDERICK's Avatar
Vehicle: 2003 supercharged harley f-150 supercrew
My Photos: (0)
I love ebay :d
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=61816&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=44996&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...gory=3704&rd=1
http://cgi.ebay.com/ws/eBayISAPI.dll...ory=86720&rd=1
I don't know if these are going to help you, but I've been trying to figure out what I am going to use also.
Ebay has tons of wifi antennas fairly cheap
2003 100th harley F-150
PCChips C3 VIA/eden, M1 ATX smart car.
Here is my project so far: My 100TH Harley-Puter
Ride safe
Buy my stuff: Stuff
BADDERICK is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
I got a new truck, well, used truck. lstrunk Off Topic 12 08-09-2005 09:44 PM
Carputer acts weird when I remote start my truck. tbird2340 General Hardware Discussion 18 10-17-2004 03:03 PM
FS: The COOLEST truck in MS wizardPC Classified Archive 13 12-12-2003 01:19 PM
Carputer Question ? Shuts down when starting my truck. topache LCD/Display 3 11-03-2003 10:41 PM
I'm painting my truck a perty color lstrunk Off Topic 12 03-31-2002 09:39 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
