The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Thread Tools Display Modes
Old 07-28-2005, 01:54 PM   #1
Vehicle: 99 Ford Explorer
My Photos: (0)
self powered or bus powered for USB wifi adapter
I've searched, trust me, but haven't found an answer... if this is already posted, please point me towards it...
a self powered usb hub is always the way to go, if you can.. but I dont' want to rely on a 2nd dc ps. so it looks like the usb hub will have to remain bus powered. looking for comments on your experiences with self powered vs. bus powered usb hubs for use with a usb wifi adapter.
I like the new linksys portable WUSB54GP usb adapter (http://www.linksys.com/servlet/Satel...VisitorWrapper) because I can run the usb cable up the pillar and mount the wifi device near the roof and then pass a pigtail connector out the door to an external antenna on the roof. Minimize the pigtail length but still get the antenna on the roof.
Most posts indicate people are using the boxy linksys adapter not the portable adapter, any ideas why?
99 Explorer: Dell Axim X5, Garmin iQue 1620, Dell TrueMobile wifi
97 Venture: MII12k,512M,3.5" 80G,7" Xenarc,Holux GM-210, Keyhole Cam, Scanner + CB --> audio in
currently: installing (finally!)
jagsnag is offline   Reply With Quote
Sponsored Links
Old 07-28-2005, 06:49 PM   #2
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
I don't have a linksys, but I've found that it works best connected directly to the PC. Any other way causes problems.
XPort 1.24 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Solved: USB bus stays powered after shutdown S4Per Power Supplies 19 05-28-2007 09:09 PM
Looking for a creative solution: USB bus still powered after CPU is off S4Per Power Supplies 197 06-15-2006 08:47 PM
802.11G WiFi Adapter -- USB, Cardbus, CF, or RJ45 Ethernet? Bailey Wireless Communications 9 01-22-2005 11:33 AM
What USB BUS POWERED soundcard works with mediacar? jusatry MediaCar 3 06-01-2004 10:37 PM
Can the Opus be powered by an adapter? orangewhip Power Supplies 11 09-09-2003 01:52 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
