Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 08-18-2005, 02:06 PM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Why would my lilliput IR mod interfere with my bluetooth dongle?
Here's something i truly dont understand. I was having a problem installing my bluetooth dongle in my car. It worked fine on work pc and home pc. This morning i unplugged all usb and serial plugs and installed it. Now it works fine. I've tracked the problem down to my lilliput IR mod thats plugged into the serial port on my epia 800. If that serial cable is plugged in the bluetooth makes the computer unresponsive or doesnt work at all. Why would that have an impact? As far as i know the serial connection of the IR mod is dedicated to com 1 and bluetooth connections have they're own com ports. Baud rate is different between the serial and bluetooth connection. My serial cable is unshielded but i dont think thats it cause sometimes my dongle wont even show up as a device half the time with they are both plugged in. Anyone shed any light on this ??? I'd hate to give up my lilli mod cause thats the only way i control my pc (touchscreenless at the moment).
Old 08-18-2005, 05:26 PM   #2
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Why don't you temporary "black tape" cover the Lilliput Ir "eye" to see if it is really cause by interference. I don't think so, but it worth a 10 second try.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Bluetooth Dongle Not Working correctly KingsDude Wireless Communications 6 05-17-2007 02:30 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Calling all Lilliput Experts! IR problem darkhalo LCD/Display 15 11-24-2004 04:09 PM
Lilliput drivers do not install with bluetooth ryguy LCD/Display 4 06-12-2004 11:52 AM
EPIA rebooting! morex 60W and MSI bluetooth dongle? masch General Hardware Discussion 4 03-11-2004 04:08 AM
