Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 12-01-2006, 08:45 AM   #31
Quote: Originally Posted by nemo1 View Post
Engenius can survive hibernation no problem?
Nope. I had problems with the its drivers stopping Road Runner from going into hibernation so with the help of Devcon and AutoIt, i just disable the card before going into hibernation and then reenable it on resume....and everything works flawlessly
04 Accord Coupe Carputer
ajamils is offline   Reply With Quote
Old 12-10-2006, 04:28 PM   #32
I have the same problem and it is sooo annoying... Can you elaborate? Or does anybody have a fix for this?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 12-10-2006, 04:55 PM   #33
Neither darque nor pervert
DarquePervert's Avatar
Using Windows to manage your wireless conenction helps. Their client utility is crap anyway.
I was all prepared to use autoit and devcon to pull this off, but now I don't think I need to!
SEARCH: It's how information gets found!
How To Ask Questions The Smart Way
My Worklog
Old 12-10-2006, 05:31 PM   #34
U have the Engenius device? So i will delete their app and see what happens!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-23-2007, 06:33 AM   #35
I am continuing to have problems with this unit and hibernation. I have set up Devcon/Autoit and have made sure that it's properly shutting down and restarting the device, but still no joy. After resuming from hibernation device manager shows the device with a yellow exclamation point next to it and a note that it could not be restarted. I must then either reboot the machine or reinsert the USB cable to get the computer to recognize the device.
The device is plugged directly into the USB port on the computer, not a hub. I've got all kinds of other USB devices going and none of them has any hibernation problems.
Is anybody else continuing to have problems with this device and hibernation? Does anybody have any advice about how to fix it?
kbreeden is offline   Reply With Quote
Old 03-23-2007, 07:58 AM   #36
I uninstalled the client utility per the earlier post and everything seems to be working now even without the Devcon/Autoit procedure in place. Hopefully, that will continue.
For anyone doing this, during uninstall a window comes up asking if you really want to uninstall the drivers. Click "no" and the client utility will be uninstalled but the drivers will not.
Quote: Originally Posted by keenanj View Post
Also This 7dBi antenna fits the connector and just about doubles the range
The website says you are out of stock of the antenna. Will you be getting more?
Also, I'm trying to keep my system totally stealth. I have the receiver under the rear deck so it's invisible. The reception is great as is, but it could always be better. Do you think there will be a significant improvement in reception with this antenna even if I put it under the deck? I'm not really concerned about the $15 for the antenna, but I have to remove my rear seat to put anything under the deck and that's a huge pain.
Thanks in advance.
Old 03-23-2007, 10:19 PM   #37
nemo1's Avatar
Keenan Systems is the authorized master reseller for EnGenius so you are getting the real products at the best price.
Are you saying there are fake ones out there? If yes then how can we identify the fake ones?
nemo1 is offline   Reply With Quote
Old 03-29-2007, 01:29 AM   #38
nemo1's Avatar
I have tried using windows to manage the wireless connections. When it goes to hibernate it will stop the wireless connection and when windows resume from hibernate, the wireless connection will be automatically connected back. Is that what you are getting?
Old 03-29-2007, 09:12 AM   #39
I removed their client application and I am just using windows! But i am still getting the same problem but not as much. Maybe the carPC will not hibernated like ever 10-15 times the car turns off. Also i tried the Devcon auto it and it didnt help so much.
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 03-29-2007, 09:38 AM   #40
Thanks for letting me know. My situation is exactly the same.
Old 03-30-2007, 09:57 AM   #41
J187's Avatar
This is weird, I used RR and never had Hibernation problems, although I didn't use hibernation a lot.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings View Post
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
J187 is offline   Reply With Quote
Old 03-30-2007, 10:06 AM   #42
I'm not having problems with hibernation/resume other than the fact that often when it comes back the wifi receiver is nowhere to be found. Sometimes even rebooting won't then get it back; I have to physically remove and reinstall the USB cable.
Old 03-30-2007, 02:31 PM   #43
I had issues with both netstumbler and wifi hopper that caused this problem. Are you running either of those?
EricE is offline   Reply With Quote
Old 03-30-2007, 09:44 PM   #44
Yes, I'm using Wifi Hopper. Were you able to find a fix?
Old 04-08-2007, 08:34 PM   #45
nemo1's Avatar
I had purchase this wireless adapter. I installed the driver and use windows to manage the wireless. The range I am getting is normal. Is there some settings that I missed out? or the item is faulty because the signal strength I am getting seams like a normal USB adapter.
driver issues with usb to ide adapter jermkesler General Hardware Discussion 22 08-31-2006 09:09 PM
Best USB Wireless Adapter? James141 Wireless Communications 36 06-25-2006 01:48 AM
Head Unit USB Adapter unr3al General Hardware Discussion 6 09-21-2005 11:02 PM
need power supply info for buslink pcmcia usb 2.0 adapter minghi General Hardware Discussion 1 04-12-2005 08:54 AM
Wireless Game Adapter cruiser01 Wireless Communications 5 02-15-2005 06:53 PM
