Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 03-02-2006, 12:35 PM   #1
baudi's Avatar
Belkin CableFree USB Hub
This looks very interesting: a cable-less USB Hub from Belkin.
baudi is offline   Reply With Quote
Old 03-02-2006, 12:43 PM   #2
perfect for a carputer environment
skadoo323 is offline   Reply With Quote
Old 03-03-2006, 11:54 AM   #3
Drake69's Avatar
Yeah, but you gotta remember, cablefree or "cold" hubs don't always work with all USB connections. The problem with cold hubs is they rely on the same power outlet that your PC is using, which is perfect for directly connected devices, but there is a limit to how much you can connect up. Powered or "hot" hubs that plug into a separate power source are guaranteed to run all USB devices, no matter how many are connected up.
Think of it this way:
PC <--> USB device = 100% power to that port.
PC <--> USB cold hub = 100% power to that port.
cold hub <--> USB device = 25% (dividing power)
PC <--> USB hot hub = 100% power to that port (not needed).
hot hub <--> USB device = 100% (supplied directly)
A cold hub might work with two devices if they don't demand too much power from the hub, but three or more would be pushing it, causing problems with one or all the other devices already connected. Low-yield devices like memory cards or single mem-card readers would be okay, but USB Notebook harddrives would not work if at all.
The club I belong to: FM2CD 4X4 Club
My Personal Page: Links4Jeeps.com
Drake69 is offline   Reply With Quote
Old 03-03-2006, 12:13 PM   #4
baudi's Avatar
I think you misunderstand this product. It's not a cold hub. It's a wireless hub. It communicates wirelessly with the USB dongle, and provides 4 USB ports in a remote location. It is plugged in to its own power supply, so it should be able to provide full power to each port.
Old 03-04-2006, 01:42 AM   #5
NRGZ28's Avatar
Why poop on his party ? I'm sure to him it sounded like he knew what he was talking about!
"cablefree or "cold" hubs...."
Think about it.. a wireless hub would HAVE to be plugged in or be powered somehow. So, using some common logic, it would definetely be a "powered hub", which is the correct term to use!
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
NRGZ28 is offline   Reply With Quote
Old 03-04-2006, 02:03 AM   #6
what is a cold hub?
Honda Lagreat Carputer Project. Mobile Entertainment
http://www.mp3car.com/vbulletin/show-off-your-project/33936-honda-lagreat-carputer-project-lots-pics.html
Full Spec for mods check out:
http://www.hondashowoff.com/profile.php?id=3766
lookinco is offline   Reply With Quote
Old 03-04-2006, 10:05 AM   #7
buurin's Avatar
A battery attachment would be KEY!
And for the record.. I'm running Wifi, Touchscreen, GPS, 1GB USB Stick off a 'cold' hub.. well actually i suppose my hub is 'lukewarm' because it uses two usb ports.
Very cool device. I dont need/want one in my car but the mention of such a device for a media center pc is a good idea (putting it near the sofa for plugging in controllers, usb sticks, cams, etc...)
Whats the speed like? I have not heard of the specs on ultra wide band.
B Smoov
Project Status: 90% Complete
Next Step: TIVO for Radio
Ampie Case :: MII10000 Mobo :: M1-ATX PSU :: 512MB RAM :: 2.5" HD, 60GB, 5400rpm, 16MB Buffer :: DWW-700H :: Centrafuse
buurin is offline   Reply With Quote
Old 03-05-2006, 07:34 PM   #8
baudi's Avatar
UWB Speed
Ultra wide-band operates at different speeds depending on the application. 100 Mbps to 220 Mbps implentations are common, and 480 Mbps to 1 Gbps are possible. So it's fast -- similar to Ethernet speed.
Old 03-08-2006, 11:00 AM   #9
baudi's Avatar
Belkin Shows Wireless USB Hub with UWB at CES
http://www.wifinetnews.com/archives/006201.html
By Glenn Fleishman
Belkin didn’t have a working demo, but did have prototypes of its recently announced ultrawideband (UWB) based USB hub: The hub comes with a USB 2.0 dongle that plugs into any USB port and bridges to the USB hub within a few dozen feet. No special software or drivers is required to use either the dongle or the hub. A Belkin spokesperson at CES confirmed that these devices will run at 110 Mbps, with future models reaching the full 480 Mbps of both UWB and USB 2.0, and that they are sold only in matched pairs.
The matched pair issue is a small problem because it means that you cannot have multiple dongles associated with the same USB hub (which might confuse USB devices, but could work like a USB switcher, too), nor can you associated multiple hubs with a single dongle, nor mix and match hubs and dongles. This will change in future releases, I’m sure, as all of the UWB vendors interested in USB 2.0 replacement want to offer users as much flexibility as possible.
Old 05-20-2007, 07:50 PM   #10
I bought one of these the other day to give it a test. The advertised range is stated as up to 30 feet. I did not have much success with this range. However when connected the device worked great. 30 feet seems great if it would get there.. had more luck with the 15 to 20 foot range.
Anyone else tried it?
chewwtoy is offline   Reply With Quote
Old 05-21-2007, 08:50 AM   #11
baudi's Avatar
Not yet. It hasn't gotten very good reviews, mainly because of the throughput. What's your experience?
WTB: M2-atx, USB 2.0 hub, USB 2.0 pci card, etc CavityCr33p Classified Archive 1 01-30-2006 05:57 PM
USB Audigy 2 NX, D-Link USB Hub, and 15 W POL Caelric Power Supplies 4 01-17-2006 12:02 PM
Confirmation of USB Hub Power (have searched!!) rdiggidy Newbie 6 12-27-2005 01:41 AM
USB Hub not working after coming out of hibernation volum3rider Input Devices 25 09-11-2005 12:07 PM
USB HUB Powering Cheekz185 General Hardware Discussion 1 08-18-2005 07:25 PM
