Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 07-24-2006, 12:17 PM   #151
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
lol we'll i'll be damned higher connection speeds! thanks I got 6.2kb on the dslreports test
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-24-2006, 01:00 PM   #152
mccdeuce's Avatar
mccdeuce is on a distinguished road
boost data speeds are slow - but i have been able to get internet without being charged at all. But it doesnt really matter as your money expires after 3 months anyway. so it gets used either way
mccdeuce is offline   Reply With Quote
Old 07-24-2006, 03:17 PM   #153
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Ok question for you guys that use RR, how much it takes to load the weather screen? cus I run a lot of "INETGET" scripts and this are taking for ever to update (the screen some times freeze loading this)
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 07-24-2006, 04:15 PM   #154
PURDooM's Avatar
PURDooM is on a distinguished road
Thanatos.
it takes me about 2 seconds... not sure about bandwidth
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 07-24-2006, 04:28 PM   #155
Para Laura
mine take a while!
can you please tell me exactly your settings in the dialup connection? (like in every single tab)
Thanatos.
Nissan Aux-in MOD
Old 07-25-2006, 04:18 PM   #156
Pseudo Nim's Avatar
Pseudo Nim is on a distinguished road
This doesn't work in Canada, does it
edit: doh, considering we don't even have that provider in Canada, I imagine not.... damn.
Doko ni datte, hito wa tsunagatte iru...
My Subaru Impreza install (now retired...)
Realtime audio freestyle hiphop battles online - www.letsbeef.com!
Pseudo Nim is offline   Reply With Quote
Old 08-01-2006, 12:10 AM   #157
Raw Wave
wizardPC's Avatar
wizardPC will become famous soon enough
Quote: Originally Posted by pRoFiT
I didn't read the last page or so, but i didn't see it before when reading this thread. For a little extra cash you can use accutracking http://support.accutracking.com/docs/boostsetup.html To track your phones location. Works with boost i450 phone. It is like $8 a month on top of the $6 you pay for boost. But you get online tracking of your phone in real time .
www.mologogo.com is the same, but FREE.
So what im also saying on the side is that if they have software that uses GPS and Internet Then there must be a way for us to do the same thing.
That way we would only need the phone for internet and GPS! I've never done any programming for phones so im not sure how easy it would be to create an app that would allow us to use both at the same time. Since the phone probably only has one serial line on it. you would only be able to use one option at a time. If only it also had bluetooth enabled
Oh well just a thought.
The Accutracking software only runs on the phone. It can use the internet and GPS at the same time because it has access to both the cellphone part and the GPS part. The cables only allow one or the other.
Debt as of 1/1/05: $34,354.48
Debt as of July 4, 2007: $0.00 explanation
Total spent on wedding so far: $3885.79
Thanks to everyone for your support.
I'M DEBT FREE!!
wizardPC is offline   Reply With Quote
Old 08-01-2006, 02:59 AM   #158
Banned
RPM_VR4's Avatar
RPM_VR4 is on a distinguished road
You could always get a GPS cable and a modem cable, open them up, and figure out the pin-out of connector so you could make your own. I added "charge from usb" to my phones USB cable just by shorting one pin to USB power. Now it charges perfectly while I use it in the car
RPM_VR4 is offline   Reply With Quote
Old 08-02-2006, 10:52 PM   #159
darkpaw is an unknown quantity at this point
Ok I've got the 450 and did the test listed above to determine if phone was running in widen. Its showing PCH on the debug screen, but it does seem to be getting ok speeds.
Mobile test on dslreports showed a 24kbps connection, so am I getting iden or widen with that?
darkpaw is offline   Reply With Quote
Old 08-03-2006, 08:50 AM   #160
Terminal flasher
what is ur baud rate set at? that might be why you could only get 24kbs.
03 Acura RSX Coupe
Old 08-03-2006, 04:10 PM   #161
I have the baud rate set to 900k which is max. Will play around with it a bit more. Sounds like I need to get a cp done though, damn was hoping to get by without having to find the software.
Old 08-03-2006, 06:00 PM   #162
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Rafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to all
Make sure you set the windows baud rate higher too...
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 08-06-2006, 12:01 AM   #163
kd4nfs is an unknown quantity at this point
packet dial up string
whats the difference between
s=2,
and
s=2#777?
kd4nfs is offline   Reply With Quote
Old 08-06-2006, 08:49 AM   #164
Terminal flasher
there is no difference.
03 Acura RSX Coupe
Old 08-07-2006, 11:56 PM   #165
necrolyte's Avatar
necrolyte is on a distinguished road
Okay guys, I just picked up an i450 off ebay for $12.50, and a Sim card with $10 card starter package for $13 off Ebay. So far, $25.50 with a free $10 in return.
Gotta grab a datacable and charger and I'm go for this in my area. I'll let you guys know results when I get hooked up.
necrolyte is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
