04-22-2008, 03:54 AM
#451
Hi, I tried the datebook restart mologogo trick. However, during the times that I set mologogo to start, it will ask for confirmation "YES/NO". I have to press a button before it continues. How do you get yours to work? My phone is a i425.
05-09-2008, 02:28 AM
#452
Vehicle: 1969 Chevelle Malibu
Awesome thread...Subscribed
05-09-2008, 03:35 AM
#453
Also I havent really seen alot of people using the i425...Is it a good phone to use?
05-09-2008, 08:14 AM
#454
Admin. Don't bug or I'll byte.
Vehicle: 2001 VW Beetle
I haven't heard of any problems with it.
05-10-2008, 12:29 AM
#455
I just bought the i425...will be setting it all up shortly to take it on a test run
05-18-2008, 02:07 PM
#456
Solving problem of i415 hanging on calls/messages
Hi all,
For i425 users, are you guys experiencing the problem with the java apps (mologogo, etc) stalling out when the phone receives a call, text mesage, etc??
I'm experiencing the problem on the i415 and want to find a way around it. In my situation the i415 will be hard-wired to my car, so there won't be any battery issues. I'm thinking that either recycling power (off then on) periodically or by using an 2-axis accelerometer to recycle power when the vehicle hasn't moved for a certain period of time.
I'd love to hear if someone has solved this problem already...
Thanks,
Escapee
06-23-2008, 09:31 AM
#457
newbie question on Boost Mobile
I considering Boost Mobile for a network connectivity option for my CarPC. I understand that the speeds are slow like dialup but I'm really ready to commit to a contract since I barely use my cell for phone use. My question is will the Motorola i335 with a USB cable work as a Tethering modem. Any help would be greatly appreciated. Thanks
07-13-2008, 01:27 PM
#458
Got my i425 set up today. Works, but painfully slow as indicated. One of the earlier posts indicated that it was sufficient for 48k shoutcast radio. That got my hopes up for some streaming comedy channels, but in my experience It's not really fast enough for even 28k streaming radio unless you want to continuously rebuffer.
07-13-2008, 09:34 PM
#459
Are you in an iDEN area? If so, did you activate iDEN?
07-13-2008, 10:16 PM
#460
My understanding is limited, but I am paying the .35 cents a day for the unlimited data, if that's what you mean. And I thought iden was the standard method the i425 uses for data anyway. Was I suppose to do something else?
07-13-2008, 10:44 PM
#461
Go here to find out how to check for iDEN enabled.
You don't have to pay the .35 a day, by the way. That's only for web browsing.
07-13-2008, 11:43 PM
#462
That posts refers to WIDEN enabled, not iden. Since WIDEN was shut off, I didn't think it was relevant. I'll check it out though.
07-14-2008, 08:07 AM
#463
Oops - looks like you're right about that one! It may still be worth checking out since WIDEN is a variation of iDEN. The same activation may be required. Not sure.
07-16-2008, 08:19 PM
#464
Ending up going with the AT&T MediaNet prepaid method for $19.99. Fast enough for web-browsing with images and streaming audio, it's not terribly expensive and still no contract.
| Thread Tools |
| Display Modes |
Linear Mode
