Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 07-08-2006, 06:42 PM   #121
Simy's Avatar
Simy is on a distinguished road
Possible Linux - Iden Solution? Question.
I've been googling my ***** off trying to find a linux - iden solution, I think ive found it. However I dont have the phone yet so, Could sombody who has linux please tell me if this works? There was a brief mention of this before, but nobody posted the end result. I'm hesitant to get a phone for an operating system that im not likley to use!
Heres the link: Click Me!
Quote:
Motorola iDEN / Nextel data service
Unfortunately, CDPD service sucks around where I live, so it has been necessary to set up an alternative. I have a Nextel phone, and for an extra $10/mo and the price of a serial cable, I can make data calls. Unfortunately, Nextel isn't an ISP, so you need to either set up a modem to dial into or have a dialup ISP account. Also, the calls are at 9600 bps, which is actually less bandwidth than CDPD. My experience, however, has been that the reliability has been higher and the latency is actually much lower. Lastly, and most significantly, the calls are billed exactly like voice calls -- by the minute (fortunately, my plan has a lot of minutes).
There are a couple of tricks to setting this up.
1. Rather than counting on autobauding, you should set your phone to expect a particular speed. I use 57600, which is the top speed a Palm can do.
2. The dial string should be set like this:
set dial "ABORT BUSY ABORT NO\\sCARRIER ABORT NO\\sDIALTONE TIMEOUT 5 \
\"\" ATZ OK-ATZ-OK ATE1Q0 OK \\dATDT\\T TIMEOUT 60 CONNECT"
3. Specify the phone number as the area code and phone number (no 1 in front)
That's about it. I used to use ucom and uvscom to talk to an IOGear UG-232A serial port connected to the phone's serial cable, but recently I upgraded to the USB cable made for the phone, which works perfectly with the umodem driver.
Update! There's a new service offered by Nextel called PacketStream. It is a direct Internet connection (though their unmeasured service goes through a NAT gateway), so no ISP is required, and it is either unmeasured or (depending on the plan you pick) measured by the kilobyte, not the minute. I've been getting something like 20 kbps over it, so it's sort of like 1st generation Ricochet. You can also receive phone calls while using it (though it does stop data I/O). You simply dial the phone number "S=2" and you're connected.
Thank you in advance!
-Simy
Carputer Status: 10%
Have: Dell L400 (700Mhz 32?RAM, 20Gig HD), 7" Newvision, Pioneer DVDRW/CDRW via USB
Need: Amp.
Simy is offline   Reply With Quote
Old 07-09-2006, 12:19 AM   #122
Cheekz185 will become famous soon enough
I dont know if it just my phone or what but i just picked up my boost i450 and the GPS is HORRIBLE, i barely get any signal on the phone, and when i do, it isnt giving me the right location of where i am!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 07-09-2006, 12:37 AM   #123
PURDooM's Avatar
PURDooM is on a distinguished road
You probably have assisted gps turned on. Turn that off.
Current projects: iGmod reloaded (Latest release) (put on hiatus indefinatly)
Unlimited Internet and gps tracking for $6 a month with boost mobile!
Carputer 2: www.lmaocar.com
PURDooM is offline   Reply With Quote
Old 07-09-2006, 12:59 AM   #124
How?
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Old 07-09-2006, 01:08 AM   #125
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
I got mine yesterday and i haven't been able to connect to the net (no cable yet so i'm trying from the phone itself)
Every time I try to access a site it give me "error 500 call you service provider" and in details it say "1019 compile error" So i call CS and they told me that is something going on with the new activations and the web bla bla bla ... so I'm going to give this POS a try tomorrow and if it does work i go to the Fricking store and buy a PCMCIA card for Verizon or Sprint and i get done with this (i have a MII so it will be perfect) the only thing is that i did want to try surfing the net with some thing cheap like this but if is no other way SO BE IT!!!!!!!!!
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 07-09-2006, 01:42 AM   #126
pRoFiT's Avatar
pRoFiT will become famous soon enough
Thanatos, the coverage for florida is pretty good with boost. I went to Target today and picked up a boost pamphlet (is that spelt right?) And everything checks out. Looks like 20 cents a day for unlimited internet. Thanatos, let me know if you get yours working and i may buy one too.
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 07-09-2006, 01:44 AM   #127
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Rafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to allRafster is a name known to all
Thanatos.
Go to a Nextel/Sprint store, and have their CS look at it..
Mine worked tight out of the box, not WiDen, but the internet did...
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 07-09-2006, 01:05 PM   #128
PURDooM's Avatar
Thanatos.
Well, you could go to sprint if you wanted to spend an extra $40 a month...
Your situation sounds unique, perhaps the firmware in your phone is messed up. I would get it exchanged and keep the sim card if I was you.
If you can access the AIM service, everything should work from there.
Old 07-09-2006, 05:14 PM   #129
Para Laura
Ok so finally I got this thing working (half way):
If I go to "4.enter site" I can enter almost any site (at least the ones that are support it with a cell)
Also I can login Msn messenger without problems.
But if I click "google serch" I still having the same error, So querstions:
Do you guys can search the net if you click "google search"?
PS:the custummer service gave me some steps when trying to fix the prob and one of them is WIDEN so that this means in widen anable (no one have answer the question of how finding out if phone is widen or not)
Thanatos.
Nissan Aux-in MOD
Old 07-16-2006, 09:35 PM   #130
PURDooM's Avatar
Does anyone know any touchscreen friendly DUN software? Or some API calls for DUN in windows? I usually am switching between evdo, boost, and wifi and its a PITA to do that all via connection manager.
Old 07-18-2006, 09:36 AM   #131
mark2727 is on a distinguished road
Quote: Originally Posted by Rafster
Th i450 is $80.
P.S. I finally found a site with the Codeplug software! http://www.wog.com
Unfortunately, that site is down (or something). Is there any way we can get that codeplug software linked to in this thread or somewhere?
Thanks,
-mark
mark2727 is offline   Reply With Quote
Old 07-18-2006, 09:40 AM   #132
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
do you switch by priority (which connection is faster)? If so i think i could make a manager program that would automatically connect to the best available service. It would probably help me too. I'm getting my boost phone today and will need something to manage that, my verizon phone, and my wifi.
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 07-18-2006, 10:00 AM   #133
PURDooM's Avatar
Well, a little of each? Idealy it would keep them all connected, but sometimes I don't have DUN comming off of my sprint phone, sometimes I am not parked at home. So assuming that I have a EVDO connection, said software should release tcp/ip from boost mobile, for example.
I would also need to have a button to say "connect to whatever", but I suppose that is easy because you can make shortcuts to a connection in windows. Now that I mention it, I bet you could give the shortcut the disconnect command via some windows shell run program api.
Can you release/renew your ip from a dial up connection?
Old 07-18-2006, 10:03 AM   #134
Terminal flasher
i just tried it and yes you can. what you need might be a lil more complicated than i can whip up but hey i'll give it a go
03 Acura RSX Coupe
Old 07-18-2006, 04:56 PM   #135
Made It Obvious
Rafster's Avatar
Thanks,
-mark
Works for me....
What you want is to google "Carrier R01.16.19" see if you can find another copy.
I just got that copy from a friend..
Peace,
Rafster
Post # 3000
Items for Sale
