Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 05-04-2006, 01:30 PM   #1
Wi fi connectivity with no router?
I was showing off my CarPC to a friend of mine and he has a laptop with wi fi. I also have wi fi on my CarPC. Is there a way we can connect and share files? We tried a little bit but I didn’t know if it was even possible w/o a router and we didn’t get very far.
Is such a thing possible?
EricE is offline   Reply With Quote
Old 05-04-2006, 01:40 PM   #2
nkotch's Avatar
It's possible but it's a pain. Almost easier to just put a router in the car and have both connect to that.
With no router you need to setup what's called an AdHoc network. Basically, on one of the computers you setup a wireless adhoc network (using the wireless utility, it's a real pain with the windows builtin utility) and then you connect to this new wireless network from the other computer. Also, to make it easier you should assign manual IP addresses to each computer, like 192.168.10.100 to one of the computers and 192.168.10.200 to the other (doesn't matter the #).
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 05-04-2006, 02:04 PM   #3
Sounds doable. Thanks. Ill try that.
Old 05-04-2006, 04:03 PM   #4
Raw Wave
Tidder's Avatar
Pain in the ***. Good luck with that. And depending on the type of wifi card you have in your car, watch for your cpu usage to jump a bit. Remove the AdHoc setup when you're done. I've had a problem with a D-Link pci card that was I guess polling the wireless network looking for other AdHoc clients. If it found one, all was good. If it didn't, it'd keep searching and totally kill the cpu, making the computer one slow piece of ****. It was awesome.
Tidder is offline   Reply With Quote
Old 05-13-2006, 11:50 PM   #5
BarryWoods's Avatar
Mount a wrt54g in there somewhere. They will run off 12v.
BarryWoods is offline   Reply With Quote
Router in a Car with GPS Frogon GPS 15 01-18-2006 08:43 PM
USB devices that power off in Linux pkg Linux 6 07-11-2005 05:07 PM
FS: Craftsman Router, Router Table, Router Bits tbird2340 Classified Archive 32 10-19-2004 06:50 AM
Wireless router to wireless router wirelessly Jackso Wireless Communications 13 04-20-2004 11:14 PM
Anyone know of a wake on lan wi fi adapter or card? inniss777 General Hardware Discussion 0 12-05-2003 04:19 AM
