Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 09-01-2006, 01:06 PM   #1
Automatic dialup after hibernation?
I bought the USB adapter for the Evdo card from mp3car and the Kyocera KPC650 from Verizon. The issue with that configuration is that verizon software wont recognize the card when used with the USB adapter , so I made a dial up connection for it and it works perfectly .
Is there any way to dial up automatically after the computer resumes from hibernation?
filatelico is offline   Reply With Quote
Old 09-01-2006, 01:13 PM   #2
MySQL Error
Sonicxtacy02's Avatar
if you have the dial-up connection setup thru windows you could create a batch file using rasdial.exe. The code in the batch file would be rasdial <CONNECTIONNAME> . This is assuming you have rasdial.exe in system32 folder of course.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 09-01-2006, 01:15 PM   #3
Raw Wave
Tidder's Avatar
And how do you trigger that to run after hibernation?
Tidder is offline   Reply With Quote
Old 09-01-2006, 01:18 PM   #4
MySQL Error
well that can be done thru the front end.... or thrut he program listed on this site that is made to run programs before and after hibernation. I cant remember the name of that program at this time.
03 Acura RSX Coupe
Old 09-01-2006, 08:01 PM   #5
MobiTekLink's Avatar
Try CiDial, I've been using it for about a year.
2004 GMC Yukon Denali
www.myspace.com/mobitekny
http://www.flickr.com/photos/bustadreamz
MobiTekLink is offline   Reply With Quote
Audigy 2 NX and hibernation backspace Car Audio 2 04-28-2006 01:56 PM
5 minutes to complete hibernation? WTF? DRWeside General Hardware Discussion 1 03-12-2006 10:36 PM
Windows XP hibernation problem: delete corrupt hibernation data? bosskong WinNT Based 4 10-10-2005 12:56 PM
I'v had a thought! - Make Hibernation Better? mick-uk WinNT Based 22 05-19-2005 08:39 AM
Odd Off Topic-ness on Hibernation Vchat20 General MP3Car Discussion 1 01-31-2005 05:41 PM
