11-22-2006, 03:21 PM
#1
dial up thu cell phone very slow speed
so I am using my Samsung d900 as a modem (thru USB)
Trying to use dial up (ATT)
Found few local numbers and can connect.
Problem is I am connecting at 9.6Kbps and it takes 5 mins to load google.com
ANY ideas? Can I bump it up to 56K?
Greg
11-22-2006, 03:35 PM
#2
Calm Down Or Get A 2 Week Vacation -Love The Forum Policeman
Greg
You need to find a faster way to connect. Dial Up through cell phones are severely limited. 9600 is the best you will get.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
11-22-2006, 03:38 PM
#3
PS. I get same speed thru bluetooth
11-22-2006, 03:57 PM
#4
I thought I can hit 56K speeds
11-22-2006, 05:24 PM
#5
I don't believe you can hit 56 with a cell phone, NOT WITH DIAL UP.
If you use a GPRS connection (I think that MIGHT give you 56 K, but it might be less), or EDGE or EVDO, you can get higher.
Michael
Some links http://www.gsmworld.com/technology/gprs/index.shtml
and this one. http://navasgrp.home.att.net/tech/cingular/gsm_data.htm
Notice the limitation for CSD, what you are using.
11-23-2006, 02:28 AM
#6
The Lavender Tie Just Made It Obvious
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
Vehicle: POS 1993 Mercury Sable (Fixed :( )
Yeah, the D900 is an Edge phone... You should be able to get at least 100K from it... if you configure it correctly....
http://www.phonescoop.com/phones/phone.php?p=993
I would suggest you go to www.howardforums.com... they have a lot of information on there regarding GPRS/Edge setup..
G'luck,
Rafster
11-23-2006, 04:28 AM
#7
Unregistered User
Vehicle: 99 Pontiac Sunfire Status: My EX is a PSYCHO ·`¯`·©2008 ODYSSEY·`¯`· ««I'M THE REAL ODYSSEY»»
If you plan on using your cell phone as a modem do not expect anything faster than 14.4K.
Now if you take advantage of your wireless provider's web, then depending on what technology they are using, you will see faster speeds.
ODYSSEY
Quote: Originally Posted by Tidder
All information expressed in this post is my opinion, and should not be regarded as a statement of fact. Digital-Car UK|
(\__/)
(")_(")
11-23-2006, 10:40 AM
#8
GPRS only works on the phone. i have no clue how to pass the connection to PC
Greg
11-23-2006, 10:47 AM
#9
These are instructions for T-mobile Internet and they dont work with T-zones internet which I have in my plan.
Setting up the modem
1. On the PC, connect the serial cable from the serial port to the handset. Ensure the handset is powered on.
2. Click on Start, Control Panel, and double click on Phone and Modem Options.
3. Click on the Modems tab.
4. Click on Add…
5. Tick Don’t detect my modem; I will select it from a list.
6. Click on Next.
7. From the Manufacturer list click to select Samsung.
8. From the Models list, click to select Samsung GPRS MODEM.
9. Click on Next.
10. Tick Selected ports.
11. Click to select COM1 from the list.
12. Click on Next.
13. If a Windows Logo testing window appears, click on Continue Anyway.
14. Click on Finish. This will return you to the Modems tab.
15. Click once on Samsung GPRS MODEM and click on Properties.
16. Click on the Advanced tab.
17. Type at+cgdcont=1,”IP”,”internet2.voicestream.com” in the Extra initialization commands field.
*** Note –If the account is provisioned for T-Mobile VPN service, then type at+cgdcont=1,”IP”,”internet3.voicestream.com” instead.
18. Click on OK to complete the setup.
Setting up the connection
1. On the PC, return to the Control Panel and double click on Network Connections.
2. Click on the link to Create a new connection .
3. This will open the New Connection Wizard , click on Next to begin.
4. Tick Connect to the Internet.
5. Click on Next.
6. Tick Set up my connection manually.
7. Click on Next.
8. Tick Connect using a dial-up modem.
9. Click on Next.
10. Tick the box to select the Samsung GPRS MODEM.
11. Ensure it is the only modem ticked and then click on Next.
12. Type the name T-Mobile GPRS for the ISP Name .
13. Click on Next.
14. Type *99***1# for the Phone number.
15. Click on Next.
16. Tick whether you would like to make this connection available for Anyone’s use or My use only, and then click Next.
17. Ensure the User name, Password, and Confirm password fields are blank.
18. Tick to select from the available options below, and then click on Next.
19. Click on Finish to complete the setup.
Making the connection
1. On the PC, return to the Network Connections folder and double click on the T-Mobile GPRS icon.
2. Verify that the User name and Password fields are blank and the number to Dial is *99***1#
3. Click on Dial.
You will now be connected to the T-Mobile GPRS service.
12-15-2006, 01:13 PM
#10
hello, i am from the uk, i want to use my D900 as a modem to connect my laptop to the internet when away for msn now and again. i am on o2(but if you can tell me for orange aswell if possible as i may be changing soon)i have a usb datacable. and i have the samsung pc studio 3 on my laptop, there is an option to use internet on that but it can never connect when it auto puts in the settings.
can you help me. thankyou very much
adam
12-15-2006, 02:05 PM
#11
adam
Head over to www.howardforums.com, and check out there Orange and thier O2 forums. Search search search that forum before you post a question, they will EAT YOU ALIVE THERE if the answer is already there, and it probably is.
Michael
| Thread Tools |
| Display Modes |
Linear Mode
