Go Back   MP3Car.com > Mp3Car Technical > Wireless Communications
Old 02-18-2007, 02:15 PM   #1
USB Adapter + External Antenna = $70 bucks worth of Wifi Improvement??
I'm planning on getting this USB adapter for around $60
(its a stand alone usb wifi receiver but has the option for antenna)
http://cgi.ebay.com/ws/eBayISAPI.dll...DME:B:AAQ:US:1
and adding this 9db external antenna that plugs into the adapter for $13
http://cgi.ebay.com/9db-WiFi-Wi-Fi-B...QQcmdZViewItem
Now....question...
Would this set up improve my wifi reception SIGNIFICANTLY??
or should I just get a regular wifi usb receiver and long usb cord for around $10.
pjloppez is offline   Reply With Quote
Old 02-18-2007, 07:32 PM   #2
jonessc's Avatar
Now....question...
depends on what benefit wifi is going to offer, assuming that aerial is going to be used outside of your car, that would make a difference to the signal you get from your sourse (ie router).
I have to be virtually parked at my front door to connect to my wireless router! im considering buying one as well
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 03-07-2007, 09:57 AM   #3
bump....any more opinions??
Old 03-07-2007, 12:55 PM   #4
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Now....question...
It is impossible to know what you mean by significantly, and since antenna performance is measured in Db, the improvement will be logarithmic.
Reception is based on MANY FACTORS, and not just antenna performance. There is just TOO much information to crunch.
That being said, and all else being exactly equal, you will have better reception. No way to know if it will be significant.
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 03-07-2007, 08:10 PM   #5
BarryWoods's Avatar
I used to have one of those radios. They're crap. That antenna isn't really designed to be used outside. If you use it that way be sure to use something like heat shrink on the joint and connector to keep out water.
Failure is not an option....
It's installed by default on every version of Windows.
BarryWoods is offline   Reply With Quote
Old 03-27-2007, 05:56 AM   #6
bes51659's Avatar
This is exactly what I've been looking for! A USB stick with connector for external antenna! (Not that specific antenna)
When the time comes there are a lot of antennas to choose from, and I will take one that fits into my charkfin. (See below)
But:
This you use that specific stick too, Barry? Any good?
Does it work well with WinXP and WZC in SP2?
bes51659 is offline   Reply With Quote
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Gps Module + External Antenna + Waas + Usb e_z_street GPS 3 10-06-2004 03:57 PM
Need help with External USB Laptop HD VWTronics General Hardware Discussion 1 05-26-2004 12:58 PM
What kind of USB Wifi adapter do you use? [H]Bugster General Hardware Discussion 68 01-23-2004 10:30 AM
USB 802.11b adapter with external antenna anyone? cyjad General Hardware Discussion 7 12-03-2003 09:07 AM
