Sorry for the delay in pics.... our digi cam died. Here is one I took with a crappy camera..
Unfortunatly, my Ground wire was too short, so it isnt in the conduit yet. Also, I have a 'noise' problem with my 12v power supply, so its not in use right now, and I am using an inverter. Otherwise it would look even cleaner yet. You can see next to the amp on the right, the relay that provides switched power to the laptop. This is allowing me to supply the laptop with power from the same source as the amp, in hopes to prevent any 'ground loop' problems. Also, coming off the relay to the right, you can just see a red wire. That is the power for the cooling fan. It goes through a hole in the lid of the case. The way this is set up, I can slide the case lid off, and swing it out of the way, without disconnecting any wires. I have yet to bolt any of the case down either.
Tossed in my little rats nest right now too, is the power on module made by w3bma5t3r... THANKS! Now if only my BT would stop haunting my standby... and my 12v cord worked. I am real close to adding a switched lighter plug for my inverter, and going that route for now.....
Also... I have since added a Holux GPSlim 236 to the aresenal. I also have a DWL-650 wifi card hacked and ready for an external antenna...
Its coming together... Slowly!
