The MP3car.com Store
Go Back   MP3Car.com > General > Show off your project
Thread Tools Display Modes
Old 10-02-2007, 09:47 AM   #1
tbird2340's CarPC Specs
tbird2340's Avatar
Vehicle: 2005 Dodge Ram Quad Cab
My Photos: (0)
2005 Dodge Ram Quad Cab - Carputer #2
Well I sold (well it's for sale) my 2003 Ranger and got me a big rig.. I have been struggling for about 4-5 months without a carputer as I didn't have time (or really the skills) to mold an LCD into my dash..
Well I scored yesterday on eBay. I decided to search for a "RAM Bezel" hoping to find a cheap one I can fiddle around with when I found this..
Now that the hardest part is done for me I need to plan out everything else.. I'm pretty sure I'm going to be putting the PC in the lower storage area (middle seat). I seen a few Ram projects that did this and it appears to be the way to go..
Few questions I have at this point are how to get the abundance of wires to this location neatly. In my Ranger I installed a full length center console that I was able to run all my wires in, this don't have that..
What is a MAJOR bummer to me is that I will no longer have a head unit. Hopefully someone can give me an idea of how to keep it / where to put it. I don't want to remove the faceplate and put it in the sunvisor so any other ideas would be great.
Good to be back!! Well.. Almost back..
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Sponsored Links
Old 10-09-2007, 12:57 PM   #2
tbird2340's Avatar
My Photos: (0)
Exterior pictures of my truck:
Old 10-31-2007, 06:45 AM   #3
tbird2340's Avatar
My Photos: (0)
The storage compartment under the middle seat is the PERFECT location for the guts..
Here are the major components.. Motherboard (Biostar Geforce 6100-M7) with a Sempron 64 2600+ CPU, 80 gb HDD (Seagate Barracuda 80GB SATA150), and DC/DC PSU (M2-ATX). (USB GPS, USB Wifi, USB Soundcard, and USB Bluetooth not shown).
Test fitting where the motherboard will go:
Test layout of the bottom:
Old 10-31-2007, 06:50 AM   #4
tbird2340's Avatar
My Photos: (0)
Holes cut out for fans and cable routing:
Two 80MM Fans installed. One on the left blowing in and to the right, one on the right blowing out and to the left.
Two USB ports mounted for a total of 6 USB ports (4 on rear):
Old 10-31-2007, 06:51 AM   #5
tbird2340's Avatar
My Photos: (0)
Carputer mounted in plexi case:
Case made out of 1/4" Plexi glass. Four 6" Bolts separate top and bottom. Three LED's on front of case (Carputer power, PSU power, HDD activity). Toggle switch gives me the option of keeping the carputer from powering on (short trips or moving the truck), reset button.
Old 10-31-2007, 06:56 AM   #6
tbird2340's Avatar
My Photos: (0)
Wires ran..
These next two may be kinda hard to understand.. It is the board of a mouse.. Using a program called "VolMouse" that enabled you to control the volume of your PC with the scroll wheel of your mouse. I glued the board behind the lighter and rigged up a shaft (the hollow plastic tube of a pen) that attaches to the gear of the mouse and the other end is attached to my lighter. Now, I can turn my lighter and control the volume.
8" Touchscreen
Wifi Adapter
GPS
PC Installed
Startup Screen (Replaced Windows Logo)
Old 10-31-2007, 01:59 PM   #7
MaiCody's CarPC Specs
Vehicle: 2000/Dodge/Durango
My Photos: (0)
very clean install!!!
One question, any heat issues with mounting the motherboard upsidedown?
MaiCody is offline   Reply With Quote
Old 10-31-2007, 02:05 PM   #8
tbird2340's Avatar
My Photos: (0)
Thank you.. It's only been in for about a week so far and we are in the Fall season (live in Ohio)... So far zero heat issues but we'll see when Spring / Summer comes along.
Old 10-31-2007, 02:20 PM   #9
venealis's Avatar
Vehicle: 2005 Dodge Ram "Yep it Does"
My Photos: (0)
Nice look, nice neet install job well done. Not sure if you are interested or not but i was able to mount my GPS in the dash in the area where there would be a tweeter and works great. Just a suggestion.
venealis is offline   Reply With Quote
Old 10-31-2007, 02:21 PM   #10
venealis's Avatar
My Photos: (0)
where did you put your head unit or are you going the route of amplifiers?
Sponsored Links
Old 10-31-2007, 02:32 PM   #11
tbird2340's Avatar
My Photos: (0)
Thanks for the suggestion! Someone on another board said the same thing and I will definitely try that out. Is it easy to get that piece off?
Old 10-31-2007, 02:33 PM   #12
tbird2340's Avatar
My Photos: (0)
I am headunit-less.
Run an amp for my sub and another amp for my door speakers. The only thing I'll miss is on the rare occasion I need to tune into the Steelers when I can't catch the game at home..
Anyone recommend a USB radio device?
Old 11-03-2007, 03:59 PM   #13
My Photos: (0)
Get Sirius! You get all NFL games!
liftn is offline   Reply With Quote
Old 11-03-2007, 06:09 PM   #14
tbird2340's Avatar
My Photos: (0)
You also get a monthly charge!
Old 11-06-2007, 01:36 AM   #15
JpLelko's CarPC Specs
JpLelko's Avatar
Vehicle: 2006/Dodge/Ram
My Photos: (0)
very nice install. i have a 06 ram qc. i hope to do a similar install. i also plan on placing the pc under the middle seat. its great place. i am planning on doing a 7" widescreen in mine. i think it will just fit. dodge changed around the bezel that year so its a little different, but i think its doable. did you do any audio upgrades (speakers, amps)? keep up the great work.
Progress:
Planning [XXXXXXXXX-] - 90%
Building [XX--------] - 20%
JpLelko is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
2003 Dodge Ram 4x4 Laramie GinoRP Show off your project 19 05-21-2008 12:10 AM
Dodge Neon Carputer /7" Touchscreen CDesigns Show off your project 14 01-01-2008 04:34 PM
1998 Dodge Neon R/T - Carputer Version 3 AJ Quick Show off your project 9 07-12-2006 06:04 PM
FS: parts of a carputer setup (m9000, arise DC DC PSU, laptop HDD, low pro RAM etc) jusatry Classified Archive 13 05-27-2004 01:17 AM
FS Carputer EPIA-M 1ghz, 256 ddr ram, 120 gig HD xtentialyst Classified Archive 2 05-12-2004 01:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
