Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 08-10-2008, 03:43 PM   #16
hartigan is on a distinguished road
I know I'm reviving an old thread but, I'm very curious as to how this project turned out. Were you able to complete it?
hartigan is offline   Reply With Quote
Old 08-10-2008, 06:45 PM   #17
mrob is an unknown quantity at this point
No, I haven't completed it. I had to put it off for several months due to work and family commitments. My plan was to pick it up in August, which I have.
Recently I've soldered all of the hookup wire to the amp. I've also drilled and filed the openings on the amp case. Today I blew away LinuxICE and replaced it with Ubuntu 8.04. Right now I'm toying with Via's beta Unichrome driver for the CN700 on Ubuntu 8.04 and getting the touchscreen going.
I'm also playing around with Elisa as a front end.
mrob is offline   Reply With Quote
Old 09-01-2008, 01:01 PM   #18
Before I moved all of the PC components to the case, I wanted to make sure the case can actually fit in the dash:
Like a glove.
I'm going to mount the touchscreen to the case, but for this dry run I'm simply placing it in front of the case and allowing the dash kit hold it in place:
I'm not altering the touchscreen bezel for now, I'm just fitting it in as-is. I don't want to commit to the EBY701 just yet; I may upgrade to a daylight readable screen.
Old 09-01-2008, 02:30 PM   #19
Here are some of the tweaks to Ubuntu 8.04 I needed to make in order to support some of my hardware.
For the touchscreen interface I created a udev rule to create a consistent symbolic link to the associated USB event. To do this I created a file named "69-touchscreen.rules" and placed it in /etc/udev/rules.d:
Code:
# Evtouch udev.rules # # Because Evtouch can't autoprobe devices we assume that we only # Have one device so we can make it like this :) # # List here your touchscreen, check if it works and send it to lifebook_AT_conan_DOT_de # Name can be found in /proc/bus/input/devices ('cat /proc/bus/input/devices') # # These are the touchscreens supported by kernel's "usbtouchscreen" module # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="3823", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="3823", ATTRS{idProduct}=="0002", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0123", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0123", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0eef", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0eef", ATTRS{idProduct}=="0002", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="1234", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # eGalax Inc. USB TouchController) KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="1234", ATTRS{idProduct}=="0002", SYMLINK+="input/evtouch_event" # eTurboTouch KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="1234", ATTRS{idProduct}=="5678", SYMLINK+="input/evtouch_event" # PanJit Touchset KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="134C", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # PanJit Touchset KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="134C", ATTRS{idProduct}=="0002", SYMLINK+="input/evtouch_event" # PanJit Touchset KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="134C", ATTRS{idProduct}=="0003", SYMLINK+="input/evtouch_event" # PanJit Touchset KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="134C", ATTRS{idProduct}=="0004", SYMLINK+="input/evtouch_event" # 3M Microtouch EX II KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0596", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # ITM Touchscreens KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0403", ATTRS{idProduct}=="F9E9", SYMLINK+="input/evtouch_event" # Gunze AHL61 KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0637", ATTRS{idProduct}=="0001", SYMLINK+="input/evtouch_event" # DMC TSC-10/25 KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="0AFA", ATTRS{idProduct}=="03E8", SYMLINK+="input/evtouch_event" # Lifebook B-Series KERNEL=="event*", SUBSYSTEM=="input", ATTRS{name}=="LBPS/2 Fujitsu Lifebook TouchScreen", SYMLINK+="input/evtouch_event" # Elo Touchscreen KERNEL=="event*", SUBSYSTEM=="input", ATTRS{idVendor}=="04e7", ATTRS{idProduct}=="0020", SYMLINK+="input/evtouch_event"
Next, I installed the evtouch driver for the xserver:
Code:
$ sudo apt-get install xserver-xorg-input-evtouch
Lastly, I calibrated the touchscreen. None of the calibration utilities worked well for me, so I simply captured the raw output while I swiped my finger in each direction. Looking at the capture, I could see the coordinates for the edges of the screen. Here's my complete xorg.conf:
Code:
# xorg.conf (X.Org X Window System server configuration file) # # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the xorg.conf manual page. # (Type "man xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "us" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" EndSection Section "InputDevice" Identifier "touchscreen" Driver "evtouch" Option "Device" "/dev/input/evtouch_event" Option "DeviceName" "touchscreen" Option "ReportingMode" "Raw" Option "MinX" "101" Option "MinY" "139" Option "MaxX" "1953" Option "MaxY" "1872" Option "SwapX" "True" Option "Emulate3Buttons" Option "Emulate3Timeout" "50" Option "SendCoreEvents" "True" # Behaviour Option "longtouched_action" "down" Option "longtouched_button" "3" Option "maybetapped_action" "click" Option "maybetapped_button" "1" Option "touched_drag" "1" Option "oneandahalftap_button" "0" Option "TapTimer" "30" Option "LongtouchTimer" "500" Option "MoveLimit" "10" EndSection Section "Device" Identifier "Configured Video Device" EndSection Section "Monitor" Identifier "Configured Monitor" EndSection Section "Screen" Identifier "Default Screen" Monitor "Configured Monitor" Device "Configured Video Device" EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Configured Mouse" InputDevice "touchscreen" EndSection #Section "Module" # Load "glx" # Load "dri" # Load "extmod" #EndSection # #Section "DRI" # Group 0 # Mode 0666 #EndSection
The WiFi card was easy. Here's my /etc/network/interfaces (with the encryption key and SSID replaced with x's):
Code:
auto lo iface lo inet loopback auto ath0 iface ath0 inet dhcp wireless-essid xxxxxxxx wireless-key xxxxxxxxxx iface eth0 inet dhcp
For GPS support I installed gpsd:
Code:
$ sudo apt-get install gpsd gpsd-clients
To configure gpsd, I determined its device path by looking in the dmesg output for the Prolific USB serial driver assignment. In my case it was ttyUSB0. To pass this info to the gpsd daemon, I edited /etc/defaults/gpsd:
Code:
# Default settings for gpsd. This file is sourced from # /etc/init.d/gpsd. START_DAEMON="true" DAEMON_OPTS="" DEVICES="/dev/ttyUSB0"
Until I find/make a frontend that's ready for real use, I'm going to use the GNOME desktop with a very simple layout. Here's how I have it set up:
For now, I'm going to use Rhythmbox for music and podcasts. It's not too touchscreen friendly, but it'll work for now. I'd like to use Elisa, but I'm running into
this issue. Instead of spending time working with the VIA graphics drivers, I decided to wait it out. I saw some good news on this subject on Slashdot this morning.
Old 09-02-2008, 08:39 PM   #20
I forgot to mention two utilities I installed to make the interface a little more touchscreen friendly. The first one is "unclutter." It allows you to configure a timeout for the mouse cursor to disappear. It's in the Ubuntu repos:
Code:
$ sudo apt-get install unclutter
The second one is a Firefox addon called Grab and Drag. It lets you scroll by grabbing the page instead of the scroll bar...like the iPhone. It even has momentum settings, so you can give the page a push and let it scroll on its own.
I've been asked where my friend got the logos for the skin mockup. I copied them here for convenience.
Old 09-07-2008, 09:07 PM   #21
My AMP9 is alive:
http://www.youtube.com/watch?v=lej-ox-3x6Y
Old 09-16-2008, 08:58 PM   #22
I tweaked the desktop theme, increasing the font. It helps out with Rhythmbox and the touchscreen:
I've been messing around with virtual keyboards. I like matchbox-keyboard and Florence. They both detect when an input box gains focus and automatically pop up. Unfortunately, they require the Accessibility feature to be turned on, which causes this bug on Rhythmbox. So I ended up using xvkbd:
It doesn't come up automatically, so I added the icon on the top panel. The default layout for xvkbd needed to be changed to be more useful with the touchscreen. To get the layout in the screenshot, I added the following to my .Xdefaults:
Code:
xvkbd.windowGeometry: 780x280+10+300 xvkbd.compact: true xvkbd.modalKeytop: true xvkbd.*Alt_R.width: 1 xvkbd.*Meta_R.width: 1 xvkbd.*Caps_Lock.width: 45 xvkbd.*Multi_key.width: 1 xvkbd.*Shift_R.width: 75 xvkbd.*Control_L.width: 30 xvkbd.*Alt_L.width: 30 xvkbd.*Meta_L.width: 30 xvkbd.*Focus.internalWidth: 0 xvkbd.*Focus.bitmap: /usr/include/X11/bitmaps/target xvkbd.NormalKeys: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Delete \n\ Escape 1 2 3 4 5 6 7 8 9 0 - = \\ ` \n\ Tab q w e r t y u i o p [ ] BackSpace \n\ Caps_Lock a s d f g h j k l ; ' Return \n\ Shift_L z x c v b n m , . / Multi_key Shift_R \n\ MainMenu Control_L Alt_L Meta_L space Left Right Up Down Focus \n\ xvkbd.ShiftKeys: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Delete \n\ Escape ! @ # $ % ^ & * ( ) _ + | ~ \n\ Tab Q W E R T Y U I O P { } BackSpace \n\ Caps_Lock A S D F G H J K L : \" Return \n\ Shift_L Z X C V B N M < > ? Multi_key Shift_R \n\ MainMenu Control_L Alt_L Meta_L space Left Right Up Down Focus \n\ xvkbd.KeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc !\n1 @\n2 #\n3 $\n4 %\n5 ^\n6 &\n7 *\n8 (\n9 )\n0 _\n- +\n= |\n\\ ~\n` \n\ Tab Q W E R T Y U I O P {\n[ }\n] Back \n\ Caps A S D F G H J K L :\n; \"\n' Return \n\ Shift Z X C V B N M <\n, >\n. ?\n/ Com\npose Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\ xvkbd.NormalKeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc 1 2 3 4 5 6 7 8 9 0 - = \\ ` \n\ Tab q w e r t y u i o p [ ] Back \n\ Caps a s d f g h j k l ; ' Return \n\ Shift z x c v b n m , . / Comp Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\ xvkbd.ShiftKeyLabels: \ F1 F2 F3 F4 F5 F6 F7 F8 F9 F10 F11 F12 Del \n\ Esc ! @ # $ % ^ & * ( ) _ + | ~ \n\ Tab Q W E R T Y U I O P { } Back \n\ Caps A S D F G H J K L : \" Return \n\ Shift Z X C V B N M < > ? Comp Shift \n\ MainMenu Ctrl Alt Meta space left right up down Focus \n\
Old 09-21-2008, 08:45 PM   #23
I did a test fit of the motherboard in the case. It's a snug fit, but it will work. I just need to come up with a mount for the disk drive.
The Amp9 has a home:
I put together a case for the vallet switch and a remote turn on override. I'll keep this in my glove compartment:
On the back there's a connection for the remote turn on, line in, and mic in:
All that's left is to get a mount for the disk drive, move everything to the case, and mount the screen. I may complete the install next weekend.
Old 10-06-2008, 07:53 AM   #24
I installed the PC this weekend. It took the whole weekend. The biggest snag I ran into was ground loop noise. I couldn't get rid of it, so I caved and got a ground loop isolator...which did the trick. I took it for a spin and all worked fine. I really need to replace Rhythmbox as my media player though. It has everything I need, but it's just not great with the touchscreen.
This morning I realized that I'll have to reroute the cables, because when I kicked on the car's ventilation fan, I could hear interference through the speakers.
Old 12-15-2008, 06:29 PM   #25
9rpp is an unknown quantity at this point
great project mrob!
I'm embarking on a same project, but I'm using the Atom-based motherboard, and running centrafuse instead of Linux
Just wondering, with the AMP9 amp, what's the power output to 4 Ohm loads? Also, how are you powering your tweeters? Is it true that the amp (the low profile kit) can be fed directly from the battery's 12V?
9rpp is offline   Reply With Quote
Old 12-17-2008, 09:41 AM   #26
I'm simply powering all four stock speakers directly with the AMP9. I tied the inputs to make it two channels. It's plenty loud for me...much louder than the stock amp/radio. Yes, the amp can be powered directly from the battery.
Regarding the power, the amp is based on the Tripath TAA4100A chip. You can see the spec sheet here. I've been very happy with the amp.
Old 12-17-2008, 10:06 AM   #27
Kalenth's Avatar
Kalenth is infamous around these parts
Amazing DIY on that amp9... i'm in awe.
Kalenth is offline   Reply With Quote
Old 12-17-2008, 10:06 AM   #28
Ahh.. that's good to know.
so you only get four inputs to the speakers, and that they are connected to each of the output of your AMP9, correct? That would mean the tweeters are already taken care of by some built-in crossover.
It's so good to be able to discuss with someone who's working on the same thing.
I'm currently troubled by the enclosure, not sure if I want to stuff it in the double DIN slot or should I route it somewhere else. As you have mentioned in previous posts, the depth of the DIN slot is only 6.75" ?
Old 12-17-2008, 10:16 AM   #29
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I agree, i was lazy and bought motorcycle amps....
Do have a question.... why not go with Windows and a Front End that has better features?
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 12-17-2008, 10:56 AM   #30
The main reason is that I love to tinker...and Linux is *much* better for tinkering. I took on the project not just to have an entertainment system, but something I can always hack...at any level. Otherwise I would have simply picked up a commercial device.
I don't have a problem with Windows (I use it more than I use Linux). But for my purposes here, Windows is not a good fit.
I'm currently in the process of making my own front end...so I'm just using Rhythmbox until it's done.
S-10 Install,In progress,baby steps,first rip apart dash :) pRoFiT Show off your project 19 05-17-2007 03:49 AM
3rd Time's the Charm??? Mercury Cougar Dash Lilliput antimatter Fabrication 23 08-07-2006 01:21 PM
Honda Jazz (Honda Fit), help!? abitcrazy Newbie 12 07-11-2006 10:51 AM
pocket-size PC...would fit in dash Meatballman General Hardware Discussion 1 04-19-2000 04:33 PM
