03-04-2008, 09:48 AM
#31
Sheepdog
Using Plastic Bottles
Unfortunately, the testing didn't go as well as I'd hoped. I only welded on test pieces, not on the duct components themselves. I found it's very difficult to weld thin pieces of plastic gracefully. The parts melt before they weld, leaving gaps, and welding the gaps makes more gaps. I suspect that welding thin materials is possible, but the results I achieved are far from pretty. It may be that I simply haven't discovered the proper technique, or it may be that I'm attempting the impossible.
Overall, the important issue is managing to get the extension and the duct parts connected in some functional manner that will provide structural integrity without any blockage to airflow. Because these systems have such thin walls, it may be that welding is not a good plan. It certainly isn't the only way. Perhaps one route is to simply use pop rivets to connect them at, say, six places around the periphery, and then seal the joints with something -- Liquid Electrical Tape comes to mind, although I don't know if it will stick to PE. One of the issues with PE is that very little sticks to it.
I'll keep attempting to weld thin sections to see if I'm just not using the right technique. The experimenting continues . . .
Reason: Added information
03-04-2008, 10:17 PM
#32
Try to insert something with more mass inside the thin tube, it needs to make good contact with the tube's wall and cool the inside of the tube, while you weld on the outside. A metal or PVC tube of the proper diameter will help. When you're finished, get the metal pipe out.
03-04-2008, 10:20 PM
#33
I just remembered a trick used in soldering jewelry and protecting pearls. use a potato, it is full of water that will cool the inside of the tube and can be easily shaped to fill your tube.
03-04-2008, 10:47 PM
#34
Sheepdog
Excellent! Thanks for the suggestions. I'll try them. I think I have a potato in the fridge, too . . . now the shop will smell like french fries.
I thought about this for a while, and realized that what I'm attempting is closely akin to welding sheet metal. The most common process used for that is spot welding, and it has an effect similar to pop riveting -- a series of small connections -- but requires no drilling or anything more than clean surfaces. So I'll try that, too.
03-05-2008, 01:43 PM
#35
Sheepdog
Screen Location
The more I got into reconfiguring the bezel, the harder it became to decide which approach to take for the best result. All along, I'd hesitated to open the case of the Lilliput, wanting to keep it stock. But that just isn't going to work, and the screen is already off warranty, so what's the problem?
Today I split the case -- gently -- and measured the screen without mounting brackets. It's 7" x 8-7/8". That changes a lot of things. First, it eliminates the need to make the bezel wider at the top, as the 8-7/8" dimension exactly fits between the duct outlets. With the case, I had a problem; without the case, no problem.
The more I work out moving the climate controls, the more I realize I'm creating a new issue: where can I cram the head unit? With the controls moved down very far, I don't have enough space for the HU below them, because structural components of the dash intrude into the bottom of the space. So that takes me back to looking at how I can fit the screen in above the controls without moving them, and the smaller size of the case-less screen helps.
One thing I should make clear here: I want to mount the screen so it is NOT part of the bezel. The screen will be mounted in the dash, like the head unit is now, and the bezel will continue to be no more than a cosmetic cover that snaps in on top of it.
So, to help fit things better in reality instead of just in theory, I made a mockup of the screen from two pieces of thin plywood -- 7/32" -- screwed together, making them the same thickness, not including the circuit board. Here's the mockup:
Click image to enlarge.
I've already held it in place, and it makes the whole visualization routine much easier. I don't have to hold the entire monitor in place, so there's no danger of trashing an expensive part in a moment of oops, oh s***.
I still have more bezel redesign to do, now that the issues have changed yet again. But, with this uncasing of the screen, I finally feel as if I'm on the right path.
I need to figure out where the screen buttons will go; I may simply choose to hide them, as others have done. I also have to devise a mounting system. First, though, I'll make some mock brackets to hold the mock screen, and then I can get some decent pictures. Maybe I should print out a mock image of the XP boot screen to paste onto the mock screen . . .
03-07-2008, 06:57 PM
#36
Sheepdog
More on Screen Location
To get the screen mockup to sit in its proper place, I built some temporary brackets from parts included in a Meccano kit I'd salvaged from a friend's discards. Meccano even comes with socket head screws and locking nuts, so it should be stable enough to bolt in and build around. Here's the back view (the bottom of the mockup is to the right):
Click images to enlarge.
The large stampings are the OEM mounts for the head unit. I made lines on the back of the board 7" apart -- the same width as the HU -- and just took an educated guess at where the brackets ought to go vertically, then fastened them in with some 3/8" hex-head screws I had on hand. Then I set the mounts in place and figured out which Meccano pieces would allow me to get a vertical position. I determined "vertical" by aligning the screen with the door trim, which is vertical; that's one advantage to having a car shaped like a box . . .
I put everything together just hand tight, and then moved things around until I got the screen in the position I wanted. Then I took it out and tightened one side up. I did a fit check, liked what I saw, and tightened up the second side to match. Because I'm using the OEM brackets, it drops right in. It's a little front-heavy, so the OEM brackets have to be screwed in to keep it all locked in position. I put the HU down where it will be installed so I can see how it all looks. I like it.
Here it is in place, from the driver's side, passenger side, and looking in the open right door:
Yeah, I did decide to paste on a boot-screen printout.  The white area surrounding the boot screen is the part that will be covered by the bezel.
Now that I know how the screen will be placed, it's time to build brackets for the actual screen. Once it's installed for a test fit, I'll make sure this mockup is positioned just the same. Then, at last, I can begin the actual bezel-building.
Note: the bezel side panels you see are pieces of the extra bezel I sliced apart. I've stripped the silver paint off with acetone.
03-09-2008, 08:22 AM
#37
Sheepdog
Screen Mount
The brackets for the screen are going to be very different from the cobbled-together affairs I used to set the screen position. For the brackets I'll actually install permanently, I plan to use simple 22-gauge sheet steel. I'd use galvanized or stainless steel so no finishing would be necessary, but it wasn't available at either Lowe's or Home Depot, and I didn't want to scrounge around any further. I'll probably have to paint this after I finish.
Here's the driver's side bracket I want to replace:
Note that only the left two tabs are used in the Scion installation. This is a universal bracket used on a lot of Toyota head units, and the leg and tab pointing to the upper right don't attach to anything, so I'll eliminate them.
The mockup brackets were great for quickly getting the screen position set, but they won't work at all for the final installation. The Lilliput mounts on the edge of the screen, not the back, so I have to bring the bracket to the edge of the screen; that means the mounting feet will go in the other direction -- toward the center of the screen, not away from it. An advantage to this system is that it will make space to mount the circuit board behind the screen.
The first step was to sketch up what I thought would work and try it out in cardboard. It took a couple of tries to get it close. Here's the second version of that process, laying next to the system it's intended to replace.
It seemed to work just fine, so the next step was to refine the design and make a steel mockup of the result on some cheap, lightweight galvanized steel from Home Depot. I used a magic marker to paint the areas where marks would go, then used a steel scribe to make easily-read cutting lines in those areas. Once I had the basic shape cut out with sheet metal snips, I laid it up against the mockup, made sure the tab sizes, positions and angles matched, and used the vise to make the necessary bends so the tabs would work.
Making more fit checks with the existing mockup, I marked the hole locations with a spring-loaded centerpunch, matched drill bits to hole sizes, and got busy with the drill. Here's the resulting piece, plus a picture of it standing up in position next to the bracket it replaces. You can see that the new bracket is a whole lot less complex than the Toyota bracket and Meccano parts it replaces:
I stuck it into its location, and, yep, it fits great, but a little further refinement is necessary. The lower tab -- the one you you see on the left -- needs to be longer to accommodate the mounting fastener. If you look closely, there are two holes in the tab on the OEM bracket; the inner one is for the attachment screw, and the outer one is for a locating pin molded into the support. In mine, I only drilled for the locating pin because the tab is too short.
I think it would be a good idea to add a flange along the top edge for strength. All that's required for that is a little more material and a single bend. I also have to make a mount for the printed circuit board; it will be riveted to these side brackets.
Once those changes are devised, I can transfer the design to the heavier sheet steel and make the final brackets.
Reason: Added information, clarified
03-09-2008, 10:09 PM
#38
Sheepdog
More on the Screen Mount
I added the material for the upper flange on the design and transfered the shape to 22-gauge steel. A fine-point pencil worked just fine for writing on it. Then I traced over the lines with a straightedge and a steel scribe. I used sheet metal snips to cut two blanks, including the one with the pattern. The blanks are 4-3/4"x8". I want these brackets to be exactly alike except for the final bend, and that's most easily accomplished by fabricating them together. I used a file to get two very clean, very straight edges that matched. Then I drilled two 1/8" holes through them, and riveted them together.
There's one curve in the pieces that isn't at a bend, so I drilled a 1/4"hole there; that makes a radius at that point, and eases the cutting. Here's the marked, riveted assembly with the extra hole drilled; the matched edges are to the back and right side.
Then it was time to head for the band saw. This could be done with a saber saw, but I have a small convertible bandsaw that works either vertically or horizontally, and that machine makes the job even easier. Staying just outside the cut lines, I made the cuts, then headed to the workbench to do all the finish filing by hand with a flat metal file. Here's the cleaned-up, still-assembled piece:
I added the 3/32" holes where the brackets attach to the screen, and then I drilled out the rivets and did a little cleanup finish-filing on the edges. I rounded the corners slightly, and made sure there were no rough edges to snag anything -- including me -- as I work with them. There are two small cables that come out of the lower corner of the screen, so I notched one bracket for that. Here are the pieces, ready for me to bend flanges and tabs. The notch is in the top corner.
One last job to do before bending: trace the final shape, so I'll have it in case anything goes wrong and I have to re-fabricate, or in case someone else is crazy enough to follow in these footsteps.
03-10-2008, 12:03 AM
#39
Raw Wave
very nice work. so are you going to relocate the ac or not now. and i thought it looked a little shallow in the bottom for the stock hu to fit there properly can you kind of post a llittle follow up on that. im getting more and more tempted to buy and aftermarket hu but i dotn wanna spend ~$50-$75 on a steeringwheel control unit that will most likey be useless with the CAR2PC adapter i bought for the XB. also how were u planning on extending the HU if you did. I was thinking of running the stock HU tucked backwards a bit in its current location setting all the EQs and SSP to 0 and center and simply running the carpc as the only audio input but i fear i will need the volume control or mute button at one point or another. I was also going to get the HD radio setup and just forget about using cds except thru the carputer. what do you think
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
03-10-2008, 02:00 AM
#40
Sheepdog
Quote: Originally Posted by lostreception
. . . so are you going to relocate the ac or not now.
No, I think I can do everything without moving the climate controls. That means I could theoretically take it all back to stock with about an hour's work or less: if I have to go back to stock, I'd pull the screen and PC, reposition the HU and put the "auxiliary box" back in. I'd pull the audio extension cables, but I might leave the under-carpet cables, except for the monitor cable. I'm also planning an auxiliary battery in the back, and I'd probably pull that, too.
Edit: Oh, and I'd have put the OEM bezel back in, too.
. . . and i thought it looked a little shallow in the bottom for the stock hu to fit there properly . . .
Yeah, it's a little shallow there until you cut away part of the plastic shelf that supports the "auxiliary box"; then the HU just barely fits.
. . . im getting more and more tempted to buy and aftermarket hu but i dotn wanna spend ~$50-$75 on a steeringwheel control unit that will most likey be useless with the CAR2PC adapter i bought for the XB.
I want to keep the stock HU because it works so well, and it's $0 cost. I think the sound quality is great for a stock unit, and certainly good enough considering the xB isn't all that quiet a car.
The cables would need about 8" to 12" of extension. There are four cables to deal with. Extensions for the power and speaker cables are available from several sources, including MP3Car.com; the extension would be made by soldering the Toyota "into-car" kit to the Toyota "into-radio" kit, making a plug-and-play extension. The steering wheel controls cable and the antenna cable would have to be sourced elsewhere, and I haven't found that source, yet.
You know, that's a really interesting idea. You'd still have the volume control on the steering wheel, and you could run a remote on/off switch as a way to take care of the mute function.
But what if we just extended the HU mounts a little bit and just moved the HU back, say, about 2"? If we put the screen on slides or on a hinge at the bottom, we could move it out of the way when we needed to get to the HU. That would mean a whole different bezel arrangement, but that might be do-able. Hmmmm . . . .
I took my HU apart; there are three components: faceplate, DVD, and the tuner/amplifier. Behind the faceplate, the top half is only the DVD player, and I think it could simply be disconnected and left off. The bottom is the rest of the electronics. If there were an extension cable, we could mount the faceplate down lower in the bezel and let the electronics work remotely; then we'd just use the DVD in the PC instead of in the HU. The key would be in adapting the connection between the faceplate and the tuner/amplifier.
03-10-2008, 03:45 PM
#41
Raw Wave
I took mine apart too but only removed the faceplate and i tried calling pioneer about getting that 16 pin or so connector in male and female so i could try to remote the faceplate but the guy on the phone wasnt able to source an individual part like that. other wise id make a removable faceplate  i still have a few ideas left tho im just not good with soldering micro electronics
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
03-10-2008, 10:56 PM
#42
Sheepdog
I wonder if you could find the comparable parts in the Mouser catalog. They're at www.mouser.com. Mouser has an absolutely amazing collection of parts, and they might be able to help.
03-11-2008, 07:18 AM
#43
Sheepdog
Screen Mounts, continued
After thinking about lostreception's comments, I realized the mounts I'm making don't allow for any positioning flexibility, and I'm considering a change to allow adjustment of the tabs. This would be ideal if there is a way to leave the headunit in place and just move the faceplate. But that would mean two sets of tabs fastened at the same points -- the HU mount and the screen mount -- and then the position of the monitor would change slightly. Adjustability would also let me refine the position after drive testing, and would let me get a perfect fit after I finish the bezel.
I think I can devise a system where each side of the screen mount has one panel, and the tabs are on separate panels. Two fasteners with slots in both panels would lock them in place, and it would let me change both depth and angle of the tabs. Only a small amount of adjustment would be fine: maybe 1/4" horizontally and vertically. I just need to play with some designs to see what's required. I won't have to scrap what I've done, but there will be significant changes. It appears that by cutting off the tab portion of the existing bracket panels, and making new tab panels, I can get what I need.
The interesting part of this is that it would move me back closer to the Meccano approach I used in determining the screen's position.
03-12-2008, 11:51 PM
#44
Sheepdog
Screen Mount Sides Finalized
I decided to pull in my horns a little on the positioning flexibility issue. Building in adjustability also means making parts over, and I want to move ahead, not sideways. This mount is made of relatively thin material, and I can do a little flexing on it if I have to. Once the screen is installed, I can add shims under the feet if necessary for alignment. The one thing I don't want is to flex the installed screen and find I cracked it.
I countersunk the holes for the screen mounting screws. Then I bent the tabs into their final position and drilled the holes for the locating pins they ride on. Those are the only holes I needed for a test fit. I'll drill the mounting holes, and they'll be done. Here are the almost-finished side brackets:
I assembled the brackets to the screen and took it to the car for a test fit. It fits great, just the way I wanted it, with no space conflicts. Oh, boy, am I gonna like this . . .
Edit: Whoops. Just realized I forgot to bend the strengthening flange on the bracket sides -- the edges facing each other in the picture. I can still do that in the bender, because there's just enough gap at the end of the bender to let the tab fit in there during the process. That's next, and then the bottom rail and the PCB mount.
03-13-2008, 10:06 AM
#45
Sheepdog
Screen Support Rail
I realized that I don't want to task those tiny screen mounting screws with too big a job. I originally had them supporting the entire weight of the screen, but they aren't really intended to be structural components. So I built a bottom rail that will take the support role; now the mounting screws will just hold the screen in the brackets. This rail is the same 22-gauge steel as the rest of the bracket. I made the main bend in the sheet metal bender, then had to do the ends in the vise, making sure the overall width was exactly the 8-7/8" width of the screen. Here's that part, and then a picture of it assembled into the side brackets:
You can see that I did put the final bend in those brackets.
Now I'll make the PCB mount and get it all assembled for another test fit.
| Thread Tools |
| Display Modes |
Linear Mode
