Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 04-24-2008, 01:33 PM   #16
nasa is an unknown quantity at this point
Skuller,
Are you using the headunit that comes with the Accord? ie: you're using the car2pc to send audio that is played out your stock system... If so, that would explain the difference as I am not using the stock headunit.
nasa is offline   Reply With Quote
Old 04-24-2008, 01:42 PM   #17
skuller is an unknown quantity at this point
Quote: Originally Posted by nasa View Post
Skuller,
my mistake, I didn't pay attention to your system.
yes I am using the stock h/u
skuller is offline   Reply With Quote
Old 06-10-2008, 11:05 AM   #18
Car Diagrams
To help keep things straight, I am adding a couple of diagrams (my computer && the equipment added in my car). Some points I need to clarify, as I had them installed by a *professional*. But should be a good starting point....
Old 06-24-2008, 04:31 PM   #19
customaudioman's Avatar
customaudioman is on a distinguished road
I have an 03 accord coupe and would like to use my steering wheel controls in my carputer on streetdeck and wmp11.I bought the fusion brain a few months back for that reason, but in streetdeck I'm unable to program it to work( a lot of self programming use have to do just to use fusion brain). I was looking to get a universal steering wheel control interface by peripheral for $40.00. I think it IR which my sound card has an IR remote to it also, but since the sound card is in the trunk, I dont have the line of sight. Is the peswix eye long enough to reach the back where the sound card is? Will this setup work? I don't use my head unit. I use aftermarket amps which connects to sb external sound card. Carputer -- to soundcard-- to aftermarket amp-- to speakers.
customaudioman is offline   Reply With Quote
Old 06-25-2008, 07:17 AM   #20
No,
I don't remember the SWIX cable being that long... But I could be wrong -- I didn't have an IR sensor on my computer at the time, so using the USB one was my only option. With my setup, I use Girder to decipher the IR commands coming from the steering wheel. I don't know anything about doing that with a soundcard (not saying you can't, I just don't know a thing about it).
BTW: I use RR, and a basic Girder file is already created for it. I just had to add in the IR messages against the commands I wanted sent. I don't know if this is available for SD, but I would have to hope so....
Old 07-04-2008, 10:31 PM   #21
Goal (new): Integrate SN into system
I went and got a Space Navigator a couple of months ago, so now I want to put it to use. At this point I have it basically working , using the drivers from Cherrybomb ( https://sourceforge.net/projects/spacenavdrvr/ ) and a little configuration. I still need to tweak things to work like I would like (once I figure that out). At this point, I can switch screens via the SN and have it act as a mouse. However, I don't have a way to switch to the mouse setup when exiting RR (so I could use the SN as my mouse, all togather). Here's my configuration efforts so far:
Start Command(s):
SENDMSG;SpaceNavigatorDriver;HID;SpaceNavigator;Le d On
(turns on the pretty blue light, regardless of the skin being used)
config.xml:
<?xml version="1.0" encoding="utf-8"?>
<snConfig>
<devices>
<device type="hid" name="SpaceNavigator" vid="0x046D" pid="0xC626">
<command name="Led On" report="0x0004" value="0x0001"/>
<command name="Led Off" report="0x0004" value="0x0000"/>
</device>
</devices>
<deviceContexts>
<deviceContext name="Media" device="SpaceNavigator">
<axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 0 pan left/right -->
<axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 1 pan foreward/back -->
<axe threshold="500" type="binary" posAction="RR Play/Pause" negAction=""/> <!-- axe 2 push/pull -->
<axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 3 tilt foreward/back -->
<axe threshold="200" type="binary" posAction="RR Prev" negAction="RR Next"/> <!-- axe 4 tilt left/right -->
<axe threshold="100"
type="exponential"
startPulse="1"
endPulse="20"
posAction="RR Volume Up"
negAction="RR Volume Down" /> <!-- axe 5 Twist -->
<buttons>
<button downAction="Context Down"
upAction="" />
<button downAction="RR FullVisu"
upAction="" />
</buttons>
</deviceContext>
<deviceContext name="Mouse" device="SpaceNavigator">
<axe threshold="500" type="binary" posAction="" negAction=""/> <!-- axe 2 push/pull -->
<axe simulateMouseMove="y"
threshold="50"
divisor="30" />
<axe simulateMouseMove="x"
threshold="50"
divisor="30" />
<axe threshold="200" type="binary" posAction="Context Up" negAction=""/> <!-- axe 5 twist -->
<buttons>
<button simulateMouseButton="left" />
<button simulateMouseButton="right" />
</buttons>
</deviceContext>
<deviceContext name="Menu" device="SpaceNavigator">
<axe threshold="200" type="binary" posAction="RR Music" negAction="RR GPS"/> <!-- axe 0 pan left/right -->
<axe threshold="200" type="binary" posAction="RR Radio" negAction="RR Weather"/> <!-- axe 1 pan foreward/back -->
<axe threshold="500" type="binary" posAction="RR Gauges" negAction=""/> <!-- axe 2 push/pull -->
<axe threshold="200" type="binary" posAction="" negAction=""/> <!-- axe 4 tilt left/right -->
type="exponential"
startPulse="1"
endPulse="20"
posAction=""
negAction="" /> <!-- axe 5 Twist -->
<buttons>
upAction="" />
upAction="" />
</buttons>
</deviceContext>
</deviceContexts>
<contexts>
<context name="Media"
deviceContext="Media" />
<context name="Desktop"
deviceContext="Mouse" />
<context name="Menu"
deviceContext="Menu" />
</contexts>
<actions>
<sendWindowMessage name="Context Up"
type="CopyData"
window="SpaceNavigatorDriver"
message="CONTEXT;Up"/>
<sendWindowMessage name="Context Down"
type="CopyData"
message="CONTEXT;Down"/>
<sendWindowMessage name="RR Volume Up"
type="CopyData"
window="RoadRunner"
message="VOL+"/>
<sendWindowMessage name="RR Volume Down"
type="CopyData"
window="RoadRunner"
message="VOL-"/>
<sendWindowMessage name="RR Mute"
type="CopyData"
window="RoadRunner"
message="MUTE"/>
<sendWindowMessage name="RR Play/Pause"
type="CopyData"
window="RoadRunner"
message="PLAY"/>
<sendWindowMessage name="RR Next"
type="CopyData"
window="RoadRunner"
message="NEXT"/>
<sendWindowMessage name="RR Prev"
type="CopyData"
window="RoadRunner"
message="PREV"/>
<sendWindowMessage name="RR FullVisu"
type="CopyData"
window="RoadRunner"
message="Full_Visu"/>
<sendWindowMessage name="RR Music"
type="CopyData"
window="RoadRunner"
message="Audio"/>
<sendWindowMessage name="RR GPS"
type="CopyData"
window="RoadRunner"
message="GPS"/>
<sendWindowMessage name="RR Radio"
type="CopyData"
window="RoadRunner"
message="Radio"/>
<sendWindowMessage name="RR Weather"
type="CopyData"
window="RoadRunner"
message="RR_Weather"/>
<sendWindowMessage name="RR Gauges"
type="CopyData"
window="RoadRunner"
message="RR_Gauges"/>
<keyPress name="Copy">
<key>17</key>
<key>67</key>
</keyPress>
<keyPress name="Paste">
<key>17</key>
<key>86</key>
</keyPress>
</actions>
</snConfig>
skin file additions (only with menu.skin && menu2.skin with Dfx so far)
TMR, 1
Additions to ExecTBL:
"TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Medi a",Audio_Player.skin
"TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Menu ",Menu.skin
"TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Menu ",Menu2.skin
"TIMER","SENDMSG;SpaceNavigatorDriver;CONTEXT;Mous e",Games.skin
Old 10-03-2008, 07:15 AM   #22
Goal:(new) Reduce Boot Time
Starting Stats
Boot Time break down:
OPUS startup (12 seconds -- specs say 10, but not timing out that way)
BIOS - 10 Seconds
Windows - 36 Seconds
Road Runner - 30 Seconds (? varies from boot to boot)
2003 2004 2005 Honda Accord CarPC Adam2312 Newbie 161 02-09-2009 10:25 PM
2003 Honda Accord Ex V6 puter Google Show off your project 22 09-05-2008 12:41 AM
2003 Honda Accord 3.0 Coupe bastid General MP3Car Discussion 6 07-01-2007 03:07 PM
RR w/Blue Devil Skin - XM Problem Bump Road Runner 1 12-20-2006 10:10 AM
MP3 player using in Honda Accord Coupe 98 geyes Newbie 1 05-01-2005 01:57 PM
