The MP3car.com Store
Go Back   MP3Car.com > General > Show off your project > Worklogs
Thread Tools Display Modes
Old 04-27-2008, 05:29 PM   #1
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
Lupo GTI Carputer Install
ok, so i have been scouting the forums and searching for a few months now and i have purchased pretty much everything i need to build my car pc. i spent today installing the motherboard, PSU (M2-ATX), the dvd rom drive, the gps reciever, and most of the cabling required.
the sub and amp install was already in the car. i installed this a couple of months ago and had a fair idea i was going for a carputer so left room in the boot to build my pc.
here is a quick wiring diagram sketch i made up. although i will post some pictures up sometime this week.
Unphased A New and upcoming site for VW owners.
EaRNi is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 12:50 PM   #2
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
took a couple of photos today, i have built up the pc and got all the wiring in the right places.
this is the boot, where everything goes.
this is the box where i built my pc
i have wired it all up and the power supply works, it powers up on ignition and then powers down when i turn it off.
BUT...
when i connected it all up, the monitor just showed 'no input signal'
Any ideas?
Old 05-04-2008, 06:17 AM   #3
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
nobody cares
Old 05-04-2008, 08:17 AM   #4
Dilmahay's CarPC Specs
Vehicle: 1999 Nissan Silvia
My Photos: (27)
Have you got the monitor on the right input?
Have you set the computer to output the correct resolution?
Have you tried plugging it into a normal monitor?
Dilmahay is offline   Reply With Quote
Old 05-04-2008, 12:50 PM   #5
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
i will try plugging into a normal monitor tomorrow thanks
Old 05-06-2008, 11:53 AM   #6
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
ok so today i connected the pc to a proper desktop monitor powered by 240v and nothing shows on that either!!! any ideas?
Old 05-06-2008, 12:17 PM   #7
rdholtz's CarPC Specs
rdholtz's Avatar
Location: edge of the tropics: Palm Beach Gardens, FL, USA
Vehicle: 2006 Scion xB
My Photos: (199)
  • It appears that the P4 socket isn't connected to the power supply. If you're running a P4 or some AMDs, you need to power the processor through that. You can get a P4-to-Molex adapter here (and in the UK, I bet).
  • Is it going through POST (Power-On Self-Test)?
  • Is the hard drive making its normal working sounds, and the only thing different is "no video"?
  • Was this a working motherboard before this installation, or is it fresh from the box?
  • I don't see any fan on the processor, and the heat exchange fins aren't aligned with the fan you have in the side of the case. You're depending a lot on that one fan. Any chance the processor overheated?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB -- CarPC installation worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 05-06-2008, 05:04 PM   #8
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
i was told it was a fanless processor, although running a fan into the case would be a good idea, so i did. i have pulled the motherboard brand new out of the box but the led's light up and the fan works. the hard drive makes a noise when power is supplied for about 2 seconds then doesnt make a sound after that. whats the P4 socket?
and how do i know if it is going P.O.S.T.?
Old 05-06-2008, 05:36 PM   #9
rdholtz's Avatar
My Photos: (199)
The P4 socket powers the processor. If you click the link I sent for the cable, you'll see a picture of the plug. The matching socket on your board is right in from the parallel port. Some processors -- Intel P4 and some AMDs -- use it. Without it, you have a live board, but no CPU.
If you have a speaker plugged in to your board, you can listen to the POST code beeps to tell what's happening, or what the problem is. Google "POST code" and you'll likely find a list of what the beeps mean. They vary by manufacturer.
What's your processor? Does the manual suggest that you may need to power the processor?
I have an AMD Sempron Mobile processor. I had the same problem -- no joy -- and it turned out that I'd forgotten to power the processor. I'm hoping it's that simple for you.
Old 05-06-2008, 05:41 PM   #10
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
this is what i have, its an intel celeron i think http://store.mp3car.com/Intel_D201GL..._p/mtb-053.htm
im hoping its that simple too lol
my board has a 4 pin plug hole the same as the power supply, do i need a link between them?
Sponsored Links
Old 05-06-2008, 06:07 PM   #11
rdholtz's Avatar
My Photos: (199)
If you have that plug coming from the power supply, I'd plug her in and see.
Check the motherboard manual and find out if it's required. Check illustrations of installed systems, if there are any.
Old 05-06-2008, 06:12 PM   #12
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
motherboard manual says not but i will buy a cable to go between and see if thats the problem.
my pc is connected to my speakers through my amp so i would hear something no?
Old 05-06-2008, 06:20 PM   #13
rdholtz's Avatar
My Photos: (199)
Well, that probably isn't the issue. Maybe you could email the seller and ask if, in their experience, it's needed.
Nope. The little speaker plugged into the motherboard does the POST codes. I think the POST codes will tell you a lot. Plug in a speaker and Google "Intel POST codes".
A couple other things: is the memory installed correctly? Is it the correct memory?
Old 05-06-2008, 06:26 PM   #14
EaRNi's CarPC Specs
EaRNi's Avatar
Vehicle: Lupo GTI
My Photos: (1)
i bought mini-itx ram, off ebay i assume thats the right stuff?
where does the speaker plug in?
Old 05-06-2008, 06:36 PM   #15
rdholtz's Avatar
My Photos: (199)
Check the manual for specs. Was it a reliable seller?
It plugs into the Front Panel Header where LEDs and the switches plug in. It takes up four prongs, usually, but there are only two wires, usually red and black.
Sponsored Links
vB code is On
Trackbacks are Off
New Carputer Install - Advise needed Calatin Newbie 4 12-26-2006 11:08 PM
anyone need carputer install or fabrication? damixt Fabrication 10 09-29-2005 12:32 PM
Store to install carputer? enkne1 Newbie 1 08-06-2005 09:35 PM
carputer install: I dare you... Cat Monkey General MP3Car Discussion 42 01-27-2005 05:34 PM
Carputer install H3nrY Newbie 1 07-25-2004 09:45 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
