Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 06-19-2008, 05:23 AM   #16
soyfish's Avatar
soyfish is an unknown quantity at this point
More updates. So it is all in and more or less working! Time was starting to get pretty tight towards the end, so I'll just give a basic time line of events.
- Take out Seats and interior
- Run power lines
- Mount distro and breaker
- Wire PC and Amp to power
- Wire screen to PC (inc power off the M2)
- Mount screen
- Remove stock speakers
- Wire PC to amp, and amp to new speakers
- Test for any odd noises etc
- Take out speakers, prep doors for sound deadening
- Sound deaden
- Replace speakers, do a level check on the amp
- Replace seats, console etc
- replace door trims
- PROFIT!!!
More Pics :
Screen in, amp and PC mounted.
Power cable that came with the Xenarc.
I cut this at the cig plug end, and stripped back the insulation. The inner wire is positive, and the outer negative. I soldered this to the yellow and black wires on a male moex plug inside the PC.
Screen mounted in dash
To do this, i removed the back of the monitor casing, and drilled 4 holes in the plastic dash. Two where for the top, where I used the screws that previously held the back of the monitor on to secure it. Two where for the bottom that went through two pieces of wood that sat the monitor out just enough to clear the electronics at the back.
The two bottom bolts go through the wood and the monitor fascia. I used a file to shape the blocks to fit the plastic. It's certainly not completely secure from thieves, but what is? It's covered on insurance :P
The location of the stock radio
You can see to the right of that hole, I have hacked a bit of the plastic off to allow room for the cable into the monitor. You can sorta see a blue wire in the background. That's the wire that goes to the IGN line on the M2. I made a little blade type terminal that slides into the existing ACC line that went into the radio.
I also had to take the door off, and hack up, a little storage area under where the radio sat.
Moving onto the sound, first thing after taking the door trims off, was to prep it for the Dynamat. I rubbed it down with general purpose thinners and took off as much sticky stuff as I could
Then I wanted to fit the speakers temporarily so I could do a sound check, and make sure my wiring was all good. I had to hack a bit off the back of the stock speaker pods to fit the split driver in, but they fit well.
I then hit the speaker pods with sound deadening. (This is a rear speaker that didn't need modification.
Next step was to sound deaden the inner of the doors and mount the speakers.
The idea from here would be to trace the service holes onto some cardboard, and then cut some MDF to size. You then put some tape down on the door, put the wood in place in the holes, another layer of tape and then dynamat. I didn't have time however, and to be honest it sounds pretty good as it is. I did do one layer of tape to keep the water off the trims though.
Basically at this point, the speakers are wired in, PC is working, screen is mounted, amp is working, and its more or less done. It was just a matter of putting everything back in and enjoying it!
Thanks for everyone's help, especially to Rowan who gave me some great tips, Wilso for some wiring advice, my Dad for the use of his shed and the idea on how to mount the screen.
Please hit me up if you have any questions, as i know I have skipped over a fair bit, but time was tight and taking pics etc took a bit of a back seat.
soyfish is offline   Reply With Quote
Old 06-19-2008, 09:11 AM   #17
soyfish's Avatar
Quick question, I couldn't find it anywhere. How do you get the winamp visualizations running behind roadrunner?
Old 06-29-2008, 06:15 AM   #18
soyfish's Avatar
Some more Pics
USB Hub in the center console
Screen in use
Also a short youtube video of it in action
http://www.youtube.com/watch?v=QgZjXUQgggU
Holden VY Commodore Install Milo Show off your project 46 03-31-2008 07:25 AM
2004 Seat Leon - Costum install guvi Show off your project 36 01-17-2008 05:05 PM
Acura TL 2004 touchscreen install moahdib Fabrication 27 10-22-2006 11:00 AM
need tips for 2004 accord sedan install keghead General MP3Car Discussion 25 07-07-2006 05:48 PM
Holden VS Commodore Carputer Finished XtremeX Show off your project 18 12-22-2005 05:19 PM
